» 06 Aoû 2015 13:08
Merci Stephane
cherche traducteur pour les caractéristiques
21.0.2 (8/5/2015)
1. Changed: Reworked television device change handling. Hopefully this will fix the "no tuner available" error on some systems after waking up from sleep.
2. Changed: mc2xml option is moved to the top of EPG mode selection page in Television Setup wizard.
3. Fixed: The "Click here for more information about mc2xml" link in Television Setup wizard was a dead link.
4. Fixed: Updated the licensing for version 21 (internal change).
21.0.1 (8/4/2015)
1. NEW: Added the sample rates 705600 and 768000 to the Output Format dialog.
2. Changed: Updated Slovak translation (thanks Peter Lukac).
3. NEW: Added an image playback mode 'Display images using a 2D renderer' to the options of Images. Will use a 2D space for rendering instead of a 3D space. Mostly for Linux / Mac, but please test.
4. Fixed: The Onion would return "No text" for many of the articles in Theater View.
5. Changed: Removed the splash screen because it never showed launching off an SSD anyway, but it would still slow the launch down a little.
6. NEW: Theater View background image slideshows include sidecars that are next to the file.
7. NEW: Added the MCWS/v1/Playback/PlayPlaylist function to play a playlist in a specified zone.
8. NEW: Sending files to a particular zone disables Zone Switch from engaging.
9. NEW: Volume Leveling uses the additional Headroom provided by Internal Volume for a more consistent experience on highly dynamic tracks or when downmixing.
10. NEW: Added a 'Clean results' checkbox to the Fill Properties From Filename tool that will fix spacing, capitalization, etc.
11. NEW: Added an expression function Row() that outputs the current row number of a record.
12. NEW: Added the command 'ZoneSwitch...' to the Audio options page.
13. NEW: Added "Play in Media Center" to the root of the explorer context menu.
14. Changed: Made the search suggestions a little wider and fixed the sizing to account for high DPI.
15. Changed: Marked "<unknown album>" and "<unknown name>" for translation.
16. Changed: Marked a bunch of strings in the TiVo server for translation.
17. Changed: Updated French translation (thanks p.v.).
18. Changed: When a zone is cleared, it will clear all the linked zones as well (applies to MCWS/v1/Playback/ClearPlaylist but also other areas as well).
19. Changed: Added a few more 'o' character variations to the diacritical ignoring code.
20. NEW: Middle-click on a link column will open the link in a new tab.
21. Fixed: Recording of a television program on a grouped channel would incorrectly favor an STB tuner (even if the STB channel was not on top of the group).
22. NEW: MCWS Browse/Children contains more information about the type of the entry, and the PlaylistID if appropriate (only when requesting Version 2).
23. NEW: Keyboard shortcut 'D' for onscreen information display (equivalent to remote control info button) that toggles among "playback position"/"program name"/"program description".
25. Changed: Updated Japanese translation (thanks Kazuo).
26. Changed: Added a few more diacriticals to the list of things for ignoring during sorting.
27. Changed: Switched Theater View back to looking only at artist instead of album artist (auto) when doing cover art lookup.
28. Changed: Added a tuner selection page when re-scan for television channels (only applicable in channel types for which multiple tuners are in the same profile), so you can scan for channels using one device, and re-scan using a different device more easily.
29. Changed: Carnac understands the naming template Move Name (Year).
30. NEW: mc2xml is integrated into the program, so it can be used for all your EPG retrieval needs.
merci d'avance
