Je vends:
1 monobloc de puissance Marantz MA 700.(Idéal pour alimenter un ou deux caissons passif ou une centrale );200 W RMS (sous 8 ohms) , 300 W sous 4 ohms, DTH de 0.02% Fréquence 5 Hz-100kHz (+0, -1dB).
Coté 4.79/5 par Audio Review (34 opinions). Etat neuf,
emballage d'origine, mode d'emploi.
Je le vends 290 €
MA-700 Monoblock Power Amplifier
The Marantz MA-700 THX-certified Monoblock Power Amplifier provides the ultimate in clean, high-power amplification in the most demanding home theater and high end audiophile music systems. The MA-700 combines the performance of a no-compromise pure monoblock design with operational features that make it ideal for use in any home theater or audio system, and is especially suited to custom installations.
• 200 watts into 8 ohms, 300 watts into 4 ohms, RMS with true low impedance drive capability
• Bridged Transformer Less (BTL) capability provides 600 watts into 8 ohms using two bridged MA-700 amplifiers
• Input volume level trim allows easy level balancing in multi-amp systems
• Auto Power On function
• High current power supply section with oversize power transformer and large-capacity audiophile-grade electrolytic storage capacitors
• Heavy duty banana plug-compatible speaker connectors
• AC convenience outlet
• Gold-plated RCA input and output jacks
• 3 years parts and labor warranty
• Compact size (5 1/4" H x 5 3/4" W x 18 3/4" D) allows easy cabinet or shelf mounting
5 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: EGA63 et 43 invités
Petites annonces pour Lecteurs DVD, BR, HD-DVD, Graveurs de salon, DD Multimédia, Magnétoscopes....
Monobloc de puissance Marantz MA 700 (200 W RMS)[VENDU]
- CSK
- Inscription Forum: 16 Oct 2000 2:00
Le MA 700 est vendu
- CSK
5 messages
