CS6 Specifications
Driver complement and description 3-way system with 1" tweeter coaxially mounted with 4" three-layer diaphragm midrange; 10" woofer with 10-pound magnet; 12" passive radiator; all drivers use metal diaphragms, short coil/long gap motors and cast aluminum chassis; cast concrete baffle
Bandwidth (-3dB) 27 Hz-25 kHz
Amplitude response 29 Hz-18 kHz ±2 dB
Phase response minimum ±10°
Sensitivity 86 dB @ 2.8 V-1m
Impedance 4 ohms (2.4 ohms minimum)
Recommended power 100-500 watts
Size (W x D x H) 13 x 18 x 50 inches
Weight (each) 156 pounds
Warranty 10 years
Archi
