comme neufSpecs
Optical
Projection system 3 LCD panels, 1 lens projection system
LCD panel 0.7 inch TFT LCD panel, 1,440,000 pixels, (480,000 x 3)
Projection lens 1.3 times zoom lens
Lamp 120W UHP Lamp LMP-H120
Screen coverage 40 to 150 inches (measured diagonally)
Signals
Colour system NTSC 3.58, PAL, SECAM, NTSC 4.43, PAL-M, PAL-N Switched automatically or manually
Acceptable video signals 15k, DTV (480I,480p, 1080I, 720p)
Acceptable computer signals 'fH: 19 to 72 kHz, 'fV: 48 to 92 Hz
General
Speaker Max. 2 x 2 W (stereo)
Power requirements AC 100 to 240 V, 50/60 Hz, 1.9-0.8 A
Power consumption Max. 190W, standby 5W
Dimensions 340 (W) x 154 (H) x 300 (D) mm
Mass Approx. 3.9 kg
Inputs/Outputs
Video input Phono type, composite
Y/C Video input Mini DIN 4 pin
Audio In Stereo mini jack
PJ Multi 32-pin multi connector Analog RGB/ component/ Composite/ S-Video/ Audio
Memory Stick slot
7 messages • Page 1 sur 1
7 messages
