Ceci est un message en anglais qui nous vient d'un Danois : Sony "addict" comme certains autres (et j'en suis).... Je vous laisse juge:
Dear All,
> I am sorry, but I must share this experience with all of you.
> Friday last week I - finally - received my own sample of
> TA-DA9000ES together with SCD-XA9000ES. I spent almost the
> entire weekend on the installation of this in my private
> living room. It took a lot of time, partly because I also
> used new Supra cables for :BiWirering of all speakers, power
> supply, for video connections, coax digital connections, and
> sub woofer connections. (I actually spent tons of money also
> on best new cables). My set up is incorporating: DVP-NS999ES,
> RDR-GX7, Old VHS, VPL-HS20, SS-X30ED x 4 pcs, SS-CNX70ED and SA-WX900
> But end result was stunning. Much better than my wildest
> expectations !!
> Sound quality:
> The best and most detailed A/V reproduction I have ever
> heard. My old STR-VA333ES sounds grainy, unclear and
> metallic/aggressive compared to this. The dynamics was
> impressive. Not only at high volumes, but also at low
> volumes. The openness was great. And no feeling of the normal
> Sony aggressive "sound".
> Playing SACD:
> Via Multi Channel inputs, using best Van Den Hul cables it
> was clearly the best I ever heard. Much better than my old
> SCD-XA777ES and drastically better than the DVP-NS999ES.
> Using the Elton John: "Goodbye Yellow Brick Road" sound was
> more clear, detailed and less metallic. But changing to the
> I-Link connection using one old 1,5 meter I-Link cable I
> almost got a shock. Elton was stepping out of the speakers,
> you could hear clearly how many layers of Sound On Sound was
> used and for the first time I could clearly identify a chorus
> in the background. Using Van Den Hull cables it was almost
> sounding defective !
> Picture quality:
> I did connect all video sources directly to the amp. One
> monitor Video component cable to the projector. No picture
> quality reduction could be noticed like we often see with
> other models. In opposite, the quality of even my old VHS went up.
> Ease of operation and design:
> Easier than expected. Very logic. Easier than VA333ES. The
> special new front panel design is in reality very good. You
> quickly learn to appreciate it in the daily use. Despite the
> size of this monster amp, even my wife likes the operation
> and design !
> The power:
> Its can be very, very loud. I have not yet tried max. power.
> Playing Eric Claptons DVD: "Live from Hyde Park" the dynamics
> was so tight and the volume got so high - like never before -
> that I - for the first time ever - got nervous about
> potential damages to the structure of my house ! But even at
> these levels distortions was at very low levels. As Hakan
> would have said: "det var grymt bra".
> Conclusion:
> TA-DA9000ES is a true flagship product from Sony. Incorporating the >best award winning S-Master technology. Its not a little better than the >cheaper brother models, its much better. Trust me, I have used the
> 5000, 3000 and 2000 models quite a lot. They are very good
> too but........
> Special note about the SA-WX900 subwoofer:
> I have disconnected and removed the bottom wood plate. And I have
> connected the 4 supplied spikes. This lifted the cabinet some
> 4 - 5 cm from the floor, and the bottom mounted woofer got
> more room to breathe. Result was much better deep bass.
> Better precision, and much less resonance's in the room.
> Especially playing music and playing loud, it was like using
> a much better construction. I strongly recommend this
> treatment, if you do not have very heavy / deep cloth on the
> floor. A new 4 meter shielded subwoofer cable from Supra also
> improved the sound quality.
7 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: david_35, gegeflipp75, Google Adsense [Bot], Redgeman, Rodz, Salurem, serenade et 181 invités
Un témoignage qui vient du Nord: en VO désolé
- Funky Bearcat
- Inscription Forum: 28 Mai 2003 15:44
faudra qu'il explique comment la qualité de l'image de son magneto peut etre accru en passant par le 9000 ?
Tcha
Tcha
- WhyHey
- Inscription Forum: 29 Avr 2002 12:31
Est-ce que cela peut venir d'un video up-converter?
Je crois que le TADA9000ES permet d'entrer en S-vidéo et de sortir en composante...
- Funky Bearcat
il n'y a pas d'up converter dans le 9000, le Z9 yam oui, mais le sony non ... donc c'est le double effet kiss cool, en particulier l'effet du trou ...
- WhyHey
Je ne dit rien sur Sony car ils ont du très très bon matos, mais on peut remettre en question les CR des gens qui ne jurent que par 1 seule marque.
Pour être comme ça il faut soit être aveuglé, soit avec un beau-frère qui y bosse.
- Austin
- Inscription Forum: 08 Oct 2000 2:00
Mouais !
D'un côté ce CR est remarquable, d'un autre, il est un peu trop élogieux...
Il ne semble même pas y avoir un seul défaut, c louche...
Cette partie de son CR m'intrigue tout de même... à moins d'être un pro, comment peut-il être aussi familier et habitué à ces modèles tout récents.
M'enfin je veux bien être crédule, car pour l'instant, pas de sous pour acheter tout ça
Je jugerai avec mes oreilles, si un jour j'en ai la possibilité.
le danois a écrit:Trust me, I have used the 5000, 3000 and 2000 models quite a lot. They are very good too but........
- ganymede44
- Inscription Forum: 05 Juil 2003 17:07
WhyHey a écrit:faudra qu'il explique comment la qualité de l'image de son magneto peut etre accru en passant par le 9000 ?
Tcha
Etonnement que je partage. Passionné de montage vidéo sur PC depuis longtemps, j'ai à peu pres tout essayé. Y a pas de miracle, dès que tu intercales quoi que ce soit, tu perds en qualité. Dans le cas contraire c'est que la perte est négative donc le rendement supérieure à 1 ... bref le mouvement perpétuel
Je parle évidemment dans une installation normale et pas quand il s'agit de transporter le signal sur des dizaines de mètres où là, évidemment, un coup de boost au départ permet de passer la difficulté mais tjs pas de miracle, au bout du cable le signal ne peut pas être meilleur que la source !
Quand au CR ... bhen oui, il est Fan de Sony .... l'en faut ! Perso je l'étais, j'en suis franchement revenu en Audio et HC.
Bonne écoute !
- jean-louis
- Inscription Forum: 05 Sep 2003 22:09
7 messages
