Et du 7320 :
http://www.p4c.philips.com/files/3/32pf ... ss_eng.pdf
http://www.p4c.philips.com/files/3/32pf ... fu_fra.pdf
Je ne vois pas de différence avec le 5520 !
Picture/Display
• Aspect ratio: 16:9, Widescreen
• Brightness: 500 cd/m²
• Contrast ratio: 500:1
• Diagonal screen size: 32 in / 80 cm
• Display screen type: LCD WXGA Active Matrix
TFT
• Picture enhancement: Pixel Plus™, Digital
Crystal Clear, Contrast Plus, Progressive Scan,
3D Combfilter, Active Control + Light sensor, 3/
2 - 2/2 motion pull down, Color Transient
Improvement, Colour Temperature
Adjustment, Digital Noise Reduction, Jagged
Line Suppression, Luminance Transient
Improver, Sharpness Adjustment
• Screen enhancements: Anti-Reflection coated
screen
• Viewing angle (H / V): 176 / 176 degree
• Panel resolution: 1366 x 768p
• Response time: 18 ms
Supported Display Resolution
Computer formats
640 x 480 60, 72, 75, 85Hz
800 x 600 56, 60, 72, 75,85Hz
1024 x 768 60Hz
1280 x 768 60Hz
• Video Formats
640 x 480i 1Fh
640 x 480p 2Fh
720 x 576i 1Fh
720 x 576p 2Fh
1280 x 720p 3Fh
1920 x 1080i 2Fh
Sound
• Sound Enhancement: Dynamic Bass
Enhancement
• Sound System: Mono, Nicam Stereo, Virtual
Dolby Surround
• Output power (RMS): 2 x 15 W
• Equalizer: 5-bands
Convenience
• Ease of Installation: Auto Programme Naming,
Automatic Channel Install(ACI), Automatic
Tuning System (ATS), Autostore, Fine Tuning,
Plug & Play, Program Name, Sorting
• Ease of Use: Auto Volume Leveller (AVL),
Graphical User Interface, Program List, Smart
Picture Control, Smart Sound Control
• Remote control type: RCFE05SPS00
• Teletext: 10 page Smart Text
• Teletext enhancements: 4 favourite pages,
Program information Line
• Picture in Picture: Picture in graphics, Twin page
text
• Remote Control: Amp, DVD, TV
• Screen Format Adjustments: 4:3, Movie expand
14:9, Movie expand 16:9, Subtitle Zoom, Super
Zoom, Widescreen
• Clock: Sleep Timer
• VESA Mount: 200 x 100 mm
Tuner/Reception/Transmission
• Tuner bands: Hyperband, S-Channel, UHF, VHF
• TV system: PAL, PAL B/G, PAL D/K, PAL I,
SECAM, SECAM B/G, SECAM D/K, SECAM L/L'
• Video Playback: NTSC, PAL, SECAM
• Aerial Input: 75 Ohm coaxial (IEC75)
• Tuner Display: PLL
• Number of Preset Channels: 100
Connectivity
• Number of Scarts: 2
• Ext 1 Scart: Audio L/R, CVBS In/Out, RGB
• Ext 2 Scart: Audio L/R, CVBS In/Out, S-video in
• Other connections: Antenna IEC75, Audio
constant level out, DVI-I
• Front/side connections: Audio in, CVBS in,
Headphone out, S-video
59 messages • Accèder à une page • 1, 2, 3, 4
Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Annor, aska290 et 94 invités
smy a écrit:......Je ne vois pas de différence avec le 5520 !....
le 5520d à un tuner TNT et pas le P+
le 7320 sans d pas de tnt (dans le pss) mais il a le P+
mais il existe un modèle 7320d (cf dossier Fnac)
- alfa
- Inscription Forum: 27 Avr 2003 14:33
alfa a écrit:le 7320 sans d pas de tnt (dans le pss) mais il a le P+
C'est le 7520D, dans le dossier fnac.
Donc la différence 5520/75(3)20, c'est le Pixel + ?
300 Euros d'écart pour le Pixel +, c'est violent.
- smy
- Inscription Forum: 15 Aoû 2003 10:14
oui 7520d tu as raison (Philips et les multiples références )
le 5520d et 7520d sont avec tuner TNT, le 75 à le P+ et la différence est de 300 €
et les specs du 7520d toujours pas dispo chez Philips
- alfa
Et philips ne permet tjs pas des resolutions PC en 1:1, c'est fou, ca
- fjpchina
- Inscription Forum: 27 Fév 2004 8:40
fjpchina a écrit:Et philips ne permet tjs pas des resolutions PC en 1:1, c'est fou, ca
La dalle est effectivement censée être une 1366 x 768, et la résolution DVI 1280 x 768... Il y a quoi, des bandes noires sur les cotés ?
- smy
Une mise a l'echelle surement, helas
- fjpchina
Le manuel est enfin dispo....
Bon, c'est pixel + mais c'est connexion -.
plus que 2 péritel ! et toujours la pauvre malheureuse DVI sur laquelle on branche tout, avec une résolution PC toujours aussi limitée.
Un module Cam pour les chaines numériques cryptées.....qui ne risque pas de servir car on sera en mpeg4......(?).
Donc Bof Bof......
Donc Bof Bof......
- snips1
- Inscription Forum: 05 Juil 2004 19:40
Voici les specs.
Les différences 5520/7520
- Contraste de 500 sur le 5520, 600 sur le 7520 (ce n'est pas la même dalle ?)
- Pixel + sur le 7520
Picture/Display
• Aspect ratio: Widescreen
• Contrast ratio: 600:1
• Diagonal screen size: 32 inch / 80 cm
TFT
• Picture enhancement: Pixel Plus™, Progressive
Scan, 3D Combfilter, 3/2 - 2/2 motion pull down,
Color Transient Improvement, Colour
Temperature Adjustment, Digital Noise
Reduction, Jagged Line Suppression, Luminance
Transient Improver, Sharpness Adjustment,
Pulse Killer Chip, Active Control + Light sensor
screen
Resolution Refresh rate
• Video Formats
640 x 480i 1Fh
640 x 480p 2Fh
720 x 576i 1Fh
720 x 576p 2Fh
1280 x 720p 3Fh
1920 x 1080i 2Fh
Sound
Enhancement
Dolby Surround
Convenience
PLL Digital Tuning, Plug & Play, Program Name,
Sorting
• Ease of Use: Auto Volume Leveller (AVL), Easy
toggle Dig/Analog modes, Graphical User
Interface, Program List, Smart Listening, Smart
Picture Control, Smart Sound Control, Watch
analogue/record digital
• Remote control type: RCFE05SLS05
text
Zoom, Widescreen
• User Interface: 7 day Electronic program Guide
• DVB: DVB Terrestrial
Connectivity
• Other connections: Antenna IEC75, DVI-I,
Common Interface
• Front / Side connections: Audio in, CVBS in,
Headphone out, S-video in
• Audio Output - Digital: AC3 over SPDIF
(Optical)
Picture/Display
TFT
screen
• Video Formats
640 x 480i 1Fh
640 x 480p 2Fh
720 x 576i 1Fh
720 x 576p 2Fh
1280 x 720p 3Fh
1920 x 1080i 2Fh
Sound
Enhancement
Dolby Surround
Convenience
Sorting
text
Zoom, Widescreen
Connectivity
Common Interface
(Optical)
- smy
Toujours pas de nouvelles ? Personne n'a vu ces modèles ?
- smy
Je crois qu'ils sont enfin dispos. Qqun du forum les a vu ?
- smy
J'ai vu le philips à côté de l'Hitachi 32ld7200, mais à la F..C, donc conditions de grande distrib. Avantage sans contestation à l'Hitachi, au niveau de la netteté et des couleurs qui bavaient un peu sur le 7520, mais ça vient peut-être des réglages (c'était sur les Indestructibles) Pas vu de rémanance, sur aucun des 2.
- LEGNOZ
- Inscription Forum: 03 Avr 2005 20:18
Vu aujourd'hui les deux à la F..C des ternes, et je suis déçu par la qualité, même si le branchement était largement en cause... Mais bon, j'hésite toujours pour le 7520 et son pixel+, et sa connectique naze, ou les Hitachi/LG...
- smy
Pour moi aucune hésitation.
Vue la connectique , c'est hitachi sans aucun problème sur le papier.
Le soucis , c'est la dispo du modèle...Mais l'arrivée imminente des nouveaux sony va peut être mettre un peu de piquant au marché...Je croise les doigts
- atetang
- Inscription Forum: 26 Mai 2005 20:43
Je viens de lire les 39 pages sur l'Hitachi (je n'avais jamais eu le courage), et je trouve fou qu'il y ai un tel emballement pour ce modèle, et si peu pour les deux nouveaux Philips. Bon, sur les 39 pages, il y en a 30 sur les retards de livraison, c'est sur !
Les prix des Philips sont tout de même très intéressants, non ? Même si on paye la faiblesse de connectique. Et je ne vais pas rentrer dans le débat du Pixel +
- smy
59 messages
• Page 2 sur 4 • 1, 2, 3, 4
