satellite 1005
Specifications HTS/HTC1001
Design Satellite/Centre speaker
Drive Units closed box 75mm (3in.) UNI-Q® array with 15 mm (0.6 in.) tweeter
Frequency range 120 Hz - 22 kHz
Power Handling 100 W
Amplifier N/A
Sensitivity (2.83V/1m) 86dB
Maximum output (SPL) 104 dB
Impedance 8 ohms
Internal volume 0.5 litres
Weight 1 kg (2.2 lbs)
Dimensions (H xW xD) Satellite
Centre
165 x 110 x 78 mm
6.5 x 4.4 x 3.1 in
107 x 181 x 78 mm
4.2 x 7.1 x 3.1 in
Cabinet finishes Silver
Satellite 2005
Specifications HTS2001.2
Design Satellite speaker
Drive Units Reflex ported 100 mm (4in.) UNI-Q® array with 19 mm (3/4 in.) tweeter
Frequency range 80 Hz - 27 kHz
Amplifier N/A
Sensitivity (2.83V/1m) 88dB
Impedance 8 ohms
Internal volume 1.5 litres
Weight 2 kg (4.4 lbs)
Dimensions (H x W x D) 198 x 130 x 150 mm
7.8 x 5.1 x 5.9 in
pour le caisson les difference sont aussi flagrante :
http://www.kef.com/KHT/KHT1005/sub_specs.htm
http://www.kef.com/KHT/KHT2005.2/sub_specs.htm
En résumé il ne doit y avoir photo entre les deux.
A mon avis le 1905 peut driver le pack 2005, mais bon qui peut le plus, peut le moins.
Good luck
