http://www.plasmahouse.com/SYNTAX-LT-37 ... T37HV.HTML
Vu sur internet,un écran LCD full-HD pour monis de 1320 dollars
product detailed description
The future is right before your eyes! Replace your old TV with the Syntax Olevia LCD with breathtaking WXGA resolution. This is a masterfully slim, high quality 37" HDTV-ready LCD TV that has been crafted for performance---and sculpted for extraordinary beauty! Syntax's 37" digital wide screen LCD TV delivers amazing image quality; It displays full WXGA resolution (in the cinematic 16:9 wide-screen format) with an outstanding 800:1 contrast ratio. Also features mesmerizing 170-degree wide viewing angle, speedy 16ms response time, with real-time graphics and smooth transitions.
Combine razor-sharp video with spectacular audio---the Syntax Olevia includes twin 10-watt stereo speakers, delivering superb surround sound. Also includes TV Tuner equipped with a multiple video / audio inputs and outputs, including VGA and DVI input, S-video input, component inputs, and much more. Experience the TV of the future. Experience the Syntax Olevia. Great money-saving special now available on this item.
37" 16:9 Cinema-Style Widescreen Aspect Ratio
HDTV Display Ready (480i, 480p, 720p, 1080i, 1080p)
800:1 High Contrast Ratio
Wide UXGA 1920 x 1080 Resolution
High Brightness 750 cd/m2
12ms Response Time
Dual Built-in TV Tuner
PIP & Picture Grid Views
Digital YC 3D Comb Filter
HDTV, Progressive Scan Inputs
176 / 176 Degree Wide Viewing Angles
VGA (DB15) & DVI HDCP Inputs
20W + 20W Surround Speakers
Detailed Specifications:
General
Active Screen Size (inches) 37" TFT LCD
Aspect Ratio 16:9
Contrast 800:1
Pixel Resolution (H x V) 1920 x 1080
Response Time 12 ms
Viewing Angle 176 (H) / 176 (V)
Digital YC 3D Comb Filter Yes
Progressive Scan Yes
2:2 / 3:2 Pull Down Yes
Digital Picture Noise Reduction Yes
Resolution Scan VGA, SVGA, XGA, SXGA, WXGA, WUXGA
De-Interlacer Yes
Adjustable Color Temperature Yes
VGA Auto Frequency Correction Yes
TV Auto Frequency Tuning Yes
Wall Mounted Type VESA 200, WM-15D / WM-20D
Horizontal Frequency 30 - 80 KHz
Vertical Frequency 50 - 80 KHz
PC Frequency Support 1920 x 1080 @ 60 Hz (Max)
Tuner Box Removable for optional ATSC tuner Replacement
Power Consumption AC 240 Watts (Max)
Safety Certification CE, FCC, UL, CUL, CB, TUV
Energy Star Yes
Audio Inputs/Outputs
Surround Yes
Mute Yes
Audio Output RCA (R/L) preout and subwoofer preout
Earphone Out Stereo Mini Jack x 1
Speaker 20 Watt x 2
Auto Sound Level Control Yes
Auto Voice Correction Yes
Video Inputs/Outputs
HDTV Component Input Y, Pb/Cb, Pr/Cr x 2 (480i, 480p, 720p, 1080i, 1080p)
Composite Video Input RCA x 2
S-Video Input 4-pin DIN x 3
Audio Input RCA L/R x 6
DVI-Input DVI - I x 1
VGA Input DB15 x 1
TV System Support NTSC
TV Tuner Input TV / CATV RF x 1, NTSC Only
TV System Support (optional) PAL / SECAM (Regional Specific)
Service Port RS232 x 1
Convenient Functions
TV / Video Switch Yes
Dual Tuner* Yes
Channel Return Yes
MTS Yes
PIP / Split Screen / Grid Yes
Viewing Aspect Ratio 16:9, 4:3, Zoom
Clock / Alarm Yes
Sleep Timer Yes
Favorite Channel Yes
Setting Yes
V-Chip Parental Control Yes
Close Caption Yes
Language English, French, German, Italian, Spanish,
Portuguese, Swedish, Simplified Chinese and Traditional Chinese
Dimensions
45.6" (W) x 25.6" (H) x 13.7" (D) with Stand
45.6" (W) x 23" (H) x 5.6" (D) without Stand
90 lbs with Stand
75 lbs without Stand
Que vaut-il ? Est-il importé en France ?
4 messages • Page 1 sur 1
Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 330 invités
ça a l'air vraiement top d'aprés les caractéristiques.
il accepte du 1080P par les composantes
de plus il a l'air d'avoir un tuner qu'on peut extraire et changer en fonction du besoin. c'est vraiement le top
- arboze
- Inscription Forum: 18 Fév 2005 13:31
en plus 1319$ = 1 115 euros
imbattable en terme de prix
maintenant faut voir la qualité
- arboze
finalement je viens de voir le PDF et ça devient nettement moins interressant
la réso est de 1366X 768 et non de 1920X1080 et ça change tout
surtout qu'il n'accepte pas le 1080p
le contrast n'est pas le même et le temps de réponse aussi
PS : ton lien n'a pas l'air d'etre sérieux
http://www.hdtvsolutions.com/pdf/syntax37.pdf
- arboze
4 messages
