Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Blxc87, Lobito94 et 40 invités
Lecteurs et platines vidéo (lecteurs DVD, HD-DVD, Dvdscopes, Laserdiscs, etc.)
ARCAM DV78 -compte rendu-
Message » 05 Déc 2005 11:03
je me propose un petit compte-rendu du lecteur DVD/CD ARCAM DV78.
Même en ces temps où la HD bas son plein ce petit test pourra en interresser certains :wink: .
Commençons par le début:
1. Design
2. Caractéristiques
Video outputs:
Composite video on 1 x gold plated phono, 1V pk-pk into 75 Ohms.
S-Video on 1 x 4 pin mini DIN, Y 1V pk-pk in 75 Ohms, C 0.3V pk-pk into 75 Ohms.
Component video Interlaced or Progressive on 3 gold plated phono sockets. Y 1V pk-pk in 75 Ohms, Pb 0.7V pk-pk in 75 Ohms, Pr 0.7V pk-pk in 75 Ohms.
SCART socket with RGB video, all 0.7V in 75 Ohms, composite video 1V in 75 Ohms, and stereo audio.
Auto switching of TV with aspect ratio control.
Audio outputs
Analogue audio outputs One pair of stereo outputs on gold plated phono sockets
Output level 2.2V rms for 0dB signal (4V rms with HDCD discs)
Frequency response 20Hz to 20kHz (+0.1dB, -0.5dB)
THD+N <0.005% for 1kHz 0dB signal, measured 22Hz-22kHz unweighted
Signal to noise ratio 105dB measured 20Hz-20kHz, unweighted
Digital audio output (IEC958) PCM/Dolby Digital/MPEG/DTS on gold plated phono (coaxial) and TOSLINK (optical)
Supported sampling rates Up to 48kHz/24 bit (TOSLINK) 96kHz/24 bit (coaxial)
Disc types replayed DVD-Video, CD Video, SVCD, CD - Audio (inc. CD-R, CD-RW) with PCM, HDCD, WMA or MP-3 encoding, DVD-R, DVD-RW, DVD+R, DVD+RW
General
Power requirements 100/115V or 230V AC, set by voltage selector switch on rear panel
Power consumption <35 VA
Size W/D/H mm. inc. feet 435x350x80
Weight 5.2kg nett
8.0kg packed
3. Mon CR
Tout d'abord un petit rappel sur ma config:
-Diffuseur: Panasonic TH42PA50E
-Source: Arcam DV78
-Preamp: Rotel rsp-1066
-Ampli: Rotel rmb-1066
-Frontales: Mission M73i
-Centrale: Infinity Beta c360
-Surround: Magnat Vector Needle 11
-Cables: Choseal
Pour info, j'ai déjà eu comme source DVD/CD:
-Kiss DP1000
-Yamaha S550
-Rotel RDV-1060
-Primare V25
Commençons donc ce CR à proprement dit.
What Hi*Fi? a écrit:L'Arcam DV78: le meilleur du ciné et de la musique en un seul appareil
...voyons cela :mdr: .
a. le son
J'ai la chance de pouvoir tester en direct l'arcam avec une autre très bonne machine: la primare v25, primare étant une grosse pointure en Hifi, le match allait être serré.
écoute CD en coax:
-Première écoute à froid du DV78:
très bon, scène ouverte, spacialisation excellente, de la pêche, bonne basses... enfin bien quoi.
-On écoute la primare v25:
mon amie me dit dans la seconde: tiens le son est plus rond, je préfère... grrrr :evil: effectivement c'est ce qu'il me semble aussi
-On réecoute l'arcam:
bah c'est plus si évident... plus j'écoute moins je vois la différence...
-Encore quelques minutes d'écoute supplémentaires...
... pour moi l'arcam est un peu plus sec moins rond que le primare. et là je me dis: bah oui mais l'arcam n'est pas rôdé. ah ahhhh... c'est pour ça.
écoute CD en stéréo:
Mêmes conclusion que précédement avec moins de dynamique qu'en coax pour les deux platines.
écoute DVD
C'est bizarre mais j'ai l'impression que la spacialisation des effets est meilleure... syndrôme de la nouveauté... je reste sur ma première impression l'écoute d'un film étant plus compliquée qu'un cd...
VERDICT: Ex-Aequo arcam-primare... ce qui est une bonne chose.
J'ajoute aussi que mes enceintes et que mon préamp sont AMHA des facteurs limitatifs pour les performances audio de ces deux platines, notamment en écoute stéréo pure car à mon sens le rsp-1066 n'a pas de by-pass.
Je ne suis pas un intégriste HiFi donc cela me contente parfaitement, je suis loin d'écouter du jazz ou du classique tous les jours. Je suis plutôt musique en tout genre: pop (James blunt, Calogero, De Palmas...), r&b-rap, et autres (Keri Bremnes, Dire Straits, Delta Goodrem...).
b. l'image
---> YUV progressif.
Tout simplement la meilleure image qu'il m'a été donné de voir sur un plasma SD.
C'est impressionnant.
J'ai essayé,
des dvd de qualité:
-Les indestructibles
-Vaillant
-Némo
-Final Fantasy
-Star Wars III
et des moins bons
-The Killer
-A better Tomorrow I&II (zone 1)
je n'ai pas plus mauvais en terme d'image.
pour en en venir à la conclusion suivante: rahhh c'est trop beau :cry:
La fluidité semble bonne aussi, on sent parfois le changement de couche (1/4s).
Seul bémol, moi qui aime que la couleur pète bien à l'écran, on se retrouve avec une image plus fade que sur le primare, ceci dit on peut régler son diffuseur en fonction... en fait ça ressemble à une image type cinéma... on s'y habitue très vite en fait, surtout sur un plasma.
VERDICT: vainqueur arcam.
c. Qualité & Inconvénients
-qualités-
Le chassis du lecteur est pas mal (5.5 kg), solide, finition impeccable, mais elle est en dessous du primare: 10 kg dans le titane, finition au millimètre, design épurée.
L'OSD/menu est très bien clair lisible et bien pensé.
L'affichage est complet.
La télécommande non rétro éclairée est de bonne facture.
Les connections dorées sont solides.
Le tiroir semble solide.
Les boutons de façade sont pas mal sauf celui de mise en fonctionnement qui ressort trop quand on éteint complètement le lecteur.
L'affichage peut se couper complètement (amélioration du son normalement).
Toutes sortes de DVD passent tranquilement
-défauts-
Le lecteur semble sensible aux courants électriques:
mon installation electrique étant ce qu'elle est (pas terrible), je perd le signal numérique entre le lecteur et le préamp pendant 1/2 seconde lorsque certains interrupteurs sont actionnés dans la maison !!! grrrr :evil: (au début j'ai cru que c'était la lentille qui était morte :cry: ). Un cable optique peut palier à ce problème mais le seul cable optique que je possède est bas de gamme et ça se ressent vraiment.
Le lecteur détecte mal les cd HDCD
En fait je crois que le couple Arcam DV78 et Rotel rsp-1066 n'est pas à 100% compatible.
Avec les autres lecteurs DVD que je possède ou ai possédé ces phénomènes ne se produisaient pas. En fait des fois le rsp-1066 garde le signal DTS alors que j'ai éjecté le DVD (ça m'est arrivé une fois !). Etrange mais pas trop dérangeant....
Voilà j'en ai fini.
J'en concluerai que ce lecteur est une bombe, certes très cher pour un SD (1095 euros neuf prix public - je n'ai pas payé, mais alors pas payé du tout ce prix là pour mon lecteur tout neuf)
mais ce qu'il fait il le fait parfaitement.
...forcé de constater que c'est VRAI.
ARCAM rules. :mdr:
Kakashi-Sensei
Inscription Forum: 03 Juin 2004 9:09
Message » 05 Déc 2005 12:40
J'ai oublier de dire que pour ceux qui possède le lecteur il en est au firmware v5.25 (pour voir sa version il faut taper sur setup puis 4792 puis aller sur version et taper sur OK).
Si vous voulez les mises à jour---> envoyer un MP et je vous l'envoie.
Fred :mdr:
Kakashi-Sensei
Message » 07 Déc 2005 13:02
Ca alors ! :o
Pas de commentaires, personne sur ce forum a un arcam dv78... suis-je le seul ? :cry:
incroyable... :mdr:
Kakashi-Sensei
Message » 08 Déc 2005 13:58
Kakashi-Sensei a écrit:Bonjour à tous,
a. le son
écoute CD en coax:
Bonjour, je me permets une petite question: comment se fait il que l'on puisse distinguer en liaison numérique coax ce type de différence, étant donné que le convertisseur est dans l'ampli HC? Je pensais, qu'il donnait le ton. Le flux numérique peut-être différent d'une machine à l'autre?
Ce n'est pas une intention polémique du tout de ma part; sur les machines que j'ai testées chez moi, je n'avais pas pu faire la différence. Par contre, j'avais senti une différence entre coax et optique. (il est vrai qu'elles avaient certaines caractéristiques proches ratio S/N, et diaphonie notamment.)
Sinon, je trouve ton CR très intéressant, merci.
seb67300
Inscription Forum: 30 Nov 2004 12:18
Message » 08 Déc 2005 18:01
a. le son
écoute CD en coax:
La différence entre deux platine branchée en coax sur un même ampli existe belle et bien.
Les blocs optiques de chaqhe platine sont différents, le traitement de la lecture directe est différente, la correction des erreurs est différente. Sur une platine DVD lisant du CD la lecture ne se fait pas en x1 (vitesse normal de lecture d'un cd).
Après ce n'était qu'une première impression, mais je peux t'assurer que le rendu sonore à toujours été différent entre mes différents platines (yamaha s550, rotel rdv-1060...).
C'est peut-être psychologique mais ma copine a senti le changement sans que je ne lui dise rien.
Voilà...
Fred.
Kakashi-Sensei
Message » 11 Déc 2005 20:22
Seul au monde
Je suis seul au monde
...à avoir ce lecteur :cry:
:mdr:
Kakashi-Sensei
Message » 15 Déc 2005 1:14
Ultime up avant que ce post atteigne les tréfons du forum... :cry:
Kakashi-Sensei
Message » 15 Déc 2005 9:15
J'ai vu sur ebay une DV 79 en import usa à 550$ (sans doute des frais de douane en plus), mais j'ai racheté la platine Onkyo DVsp 800 de tinitoon 91. Je te didai ce que j'observe comme différences, mais c'est carrément HS...
seb67300
Message » 15 Déc 2005 22:24
J'ai résolu mon problème électrique en achetant 2 multiprises para-surtenseur (7 euros l'unité)
Trop content :mdr:
Kakashi-Sensei
Message » 17 Déc 2005 13:41
On trouve plus d' aficionados d'arcam par delà la manche... tant pis je vais continuer de converser avec les english sur AVforum... m'aïe télor ise riche :mdr:
Kakashi-Sensei
Message » 17 Déc 2005 14:40
non tu n'es pas le seul a avoir de l'arcam
moi j'ai la dv 79
Perso je trouve que c'est une platine dvd
une image de fou
mais la des que j'ai fini ma salle hc je verrai ce qu'elle donne avec un video projecteur car pr l'instant elle est sur un loewe aconda :roll:
Ueshiba
Inscription Forum: 18 Juin 2004 19:40
Message » 17 Déc 2005 15:20
Ce sont des lecteurs faits pour de grandes images (dixit arcam) et sur mon plasma en YUV c'est la grande classe :mdr:
Kakashi-Sensei
Message » 17 Déc 2005 16:07
je le pense aussi
par contre j'aimerais connaitre la difference entre le dv 79 et le fmj niveau image
Ueshiba
Message » 17 Déc 2005 16:17
Je suis pas sur qu'il y ai une réelle différence. Je pense qu'il faut plutôt voir du coté son.
Dans tous les cas de figure le FMJ est meilleur (le prix est plus élevée aussi !)
Kakashi-Sensei
Message » 17 Déc 2005 16:45
c'est ce que je pense,
la difference doit se faire au niveau de la qualite des composants, de la fabrication et surtout du son
c'est pourquoi je pense mon dv 79 le temps que la hd se democratise reellement.
Et je pense de nouveau choisir un lecteur arcam, car compare au marantz pour moi y a pas photo au niveau du pique
Ueshiba
Retourner vers Lecteurs DVD / HD-DVD / Laser Disque
