bonjour
je suis a la recherche de tout renseignement ( photos et fiche technique )concernant les enceintes genesis 400
les avis aussi sont les bien venus
12 messages • Page 1 sur 1
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Google Adsense [Bot] et 458 invités
des photos :
http://www.soundsgoodtomehouston.com/gen400.htm
Denon avr x 4500 , pré amp tubes Zero Zone PRT-07B, Dac S.M.S.L. SU-8 v2, Nuprime sta 9. Sony ubp x700 4K ; tv 4K Sony 49x 8005c,projo Optoma full hd. Deux B&W asw610, Klipsch RF5,RC7, RS3,bose cube. Pièce dédiée 6.2.2 . câbles VDHl, hp Maxitrans,
- elmer***
- Inscription Forum: 02 Mar 2006 10:13
Description en english :
The Genesis 400 is a dipolar design which radiates sound from both the front and the back. This kind of loudspeaker has many advantages over a conventional type, the most important of which are ease of room placement and an open and musically accurate soundstage presentation. The Genesis 400 is finished in a beautiful rosewood veneer.
There are five drivers in each of the 400's consisting of two ribbon tweeters, one three inch midrange dome and two eight inch metal cone woofers. Each driver in this three way loudspeaker system has been designed to be a perfect piston within its useable frequency band.
The tweeter, described by many reviewers in both the American and foreign press as possibly "the world's best," is a one inch planar ribbon design. It is hand-crafted from an extremely thin laminated membrane of aluminum and Kapton and measures a mere 0.0005 inch thick. The advantage of incorporating such an extremely thin membrane is its inherent low mass. The result of this design is a driver that has the speed of the best ribbon/electrostatic designs without the high distortion and poor dispersion that is typically associated with them.
The three inch midrange dome on the Genesis 400 is constructed from an amalgam of titanium and silicon carbide. This strong and lightweight design eliminates breakup modes through the entire middle frequency range and provides tremendous dispersion and dynamic range while maintaining its coherent musical quality.
The bass of the Genesis 400 is clean and powerful. It is produced by two eight inch metal cone woofers. By incorporating a stiff, machined, twin layer aluminum cone into our woofers, the problem of wobble, cone bending and non linear distortions associated with cones not possessing the stiffness of aluminum has been eliminated. Our aluminum cones are a magnitude stiffer than any plastic cone on the market today and virtually eliminate these problems.
In order to take advantage of the finest properties of each driver, a sophisticated fourth order Linkwitz Riley crossover is used between the tweeter and midrange. The advantage of a Linkwitz Riley network is nearly perfect phase coherence and seamless integration of drivers. To extend the 400's bass response to 30 Hz, capacitive and inductive tuning is incorporated rather than the traditional acoustic suspension or ported box design. Use of a sealed cabinet and LC tuning gives the 400 its extended and tightly controlled bass performance.
MINIMUM ROOM REQUIREMENTS
The Genesis 400 is equally at home in a small or medium to large sized room and are an excellent choice for both music and home theater.
ASSOCIATED EQUIPMENT REQUIREMENTS
At four ohms nominal impedance they are reasonably efficient and can easily be driven with an amplifier as small as 100 watts per channel.
These speakers are among the very few affordable loudspeakers in the world that can reproduce a musically correct holographic image in your home. The 400's set new standards of spectral coherence, three dimensional imaging and startling dynamic range.
Dimensions;
45 inches tall
12 inches front to back
13 inches wide
Weight 75 pounds each
Frequency response: 33 Hz to 36 kHz +/- 3 dB
Sensitivity: 89 dB one meter one watt
Loudspeaker impedance 4 ohms
Crossover design: Passive 3-way, 4th order Linkwitz Riley phase coherent design.
Dimensions;
45 inches tall
13 inches wide
- elmer***
Salut, la Genesis 400 n'est pas la plus grande réussite de la gamme , ( jai eut la genesis 5 , la genesis APM1, et la gigantesque genesis 2.5)
meme si elle garde un peu du son de ses grandes soeurs sont principale défaut c'est que contrairement à ces dernieres le grave n'est pas amplifié donc elles demandes une amplification costaud et pas trop agrréssive car le tweeter mylard genesis ne pardonne rien de ce coté la non plus..
tout dépends a quel prix on te la propose , sinon une genesis 5 commence a se trouver pas "trop" cher sur le net et avec un petit 50watts à tubes elles peuvent faire des merveilles
- captaincaverne
- Inscription Forum: 22 Nov 2007 15:17
merci pour les info
c super
c super
- noisette34
- Inscription Forum: 09 Juin 2008 11:36
captaincaverne a écrit::D Salut, la Genesis 400 n'est pas la plus grande réussite de la gamme , ( jai eut la genesis 5 , la genesis APM1, et la gigantesque genesis 2.5)
merci pour tes conseils
tu tombe très bien car justement les modèles que je rêve d' avoir sont justement les 2.5 mais impossible a trouve
tu doit êtres un des rare en France a en avoir une paire
sa fait combien de temps que tu les as
a ton avis a combien se négocie telle aujourd'hui
- noisette34
j'ai du les revendre pour raison de manque de place , c'est le magasin Audio-team à Nice qui les a repris ,j'ai entendu une fois que leur nouveaux propriétaire comptait peut etre les revendre ? en tous cas ils ont une paire de Genesis 350 en ce moment en dépot vente avec les nouveaux ruban de medium des 350SE c'est surement un peu plus cher mais c'est de sacré enceintes
- captaincaverne
tu a entendu qu'il voulais les revendre il y a combien de temps
et tu sais pas a quel prix
ou une idee
ou une idee
- noisette34
je ne sais plus mais surement dans les 20000 euros.. un oeil quoi
par contre je suis passé au magasin Audio team hiers a Nice et ils ont une paire de Genesis 400 qui a l'air en bon etat à 2700 , je pense que vu l'age des bestiaux on peut encore pas mal négocier sur le prix..
et je retire l'avertissement faite sur la puissance que demande ces amplis ..
puisque je viens de voir ta config avec le Macintosh
- captaincaverne
et toi quand tu avais les 2.5
tu utilise quel ampli
- noisette34
Electrocompaniet AW250 puis bloc mono JA50 , le tube se marie bien avec
- captaincaverne
le ja 200 me tente bien
en plus audio team nice en a un
et il attende l'arrive d'une paire de genesis 2.5
esque tu as deja ecoute les genesis 2.5 sur les ja 200 ?
- noisette34
12 messages
