Type : PROJECTEUR + SCALER
Marque : SONY + FAROUDJA
Modèle et options : VPH-D50QM + NRS
Prix de vente : 649€
Département où la marchandise est visible : Saint-Denis (Belgique)
Possibilité d'expédition : Non
Montant des frais d'expédition : Pas Applicable
État de la marchandise : Occasion
Première main : Non
Prix neuf : + de 20.000€
Facture disponible : Non
Date et lieu d'achat : Pas d'idée
Garantie et date d'expiration : Plus sous-garantie
Numéro de série : Avec l'appareil
Emballage d'origine conservé : NRS, oui
Description générale : These equipments allow connecting to HD (BD, NMT or HDDVD) through DB15 pass-through from FAROUDJA with conversion from YUV to RGBHV or directly in YUV to the projector. The FAROUDJA performs a very high upscaling on all SD sources.
A home made ceiling support for the CRT is also included.
The projector has been painted (white and cream)
FAROUDJA NRS 1280*720:
http://www.hometheaterhifi.com/volume_8 ... -2001.html
http://www.meridian-audio.com/faroudja/ ... Series.pdf
Specifications:
Inputs: Composite (BNC). S-Video, YCrCb-Component (BNC), and HD/Computer Passthrough (D15M); RS232 Port
Outputs: YPrPb , RGB (5 BNC, Including H and V Sync), D15
Aspect Ratios: 4:3, Anamorphic 16:9, Letterbox, Anamorphic Image on a 4:3 TV
Controls: Brightness, Contrast, Color, Tint, Noise Reduction, Detail, Image Shift, 13 Pattern Generator
Special Features: DCDi, scanLock Bandwith expansion, Blanking control.
SONY VPH-D50QM painted (white and cream) with ceiling support
582 hours. no shipping by post
Tube Wear Rating of 9, following Curt’s rating:
http://www.curtpalme.com/TubeCondition_RatingChart.shtm
http://www.curtpalme.com/SonyD50.shtm
features
quick and easy setup
optical alignment of the projector does not require disassembly of this projector. simply open the upper panel cover and adjust the lens angle by rotating the horizontal and vertical screws with the supplied adjustment plate.
increased brightness & increased bandwidth
the vph-d50 incorporates 7" crts that offer brightness of 160 ansi lumens and bandwidth of 75 mhz. the benefits of increased bandwidth allow for a rgb resolution of (sxga) 1280 x 1024 and a wider frequency response.
universal air coupling
enables the projector's screen size flexibility, to reproduce images ranging from 60 to 250 inches. fine adjustments can be performed quickly and easily with the vph-d50. the crt and lens angle can be independently changed horizontally and vertically while observing the reproduced image.
memory for picture control data recall
the projector has 42 memory blocks (50 in total) that can be assigned to an input signal, so that the best possible registration and picture control data for each input signal can be memorized. this greatly reduces setup time.
better registration system
two registration adjustments, key balance and pin balance, have been added for better registration control. when completed prior to zone adjustments, these minimize any necessary zone adjustments.
horizontal scanning frequency
the new crt accepts a horizontal scanning frequency of 64khz. this expands video applications to include quadruplers, as well as increasing the acceptable input frequency.
standard inputs
in addition to the composite video and y/c video inputs, the vph-d50 can accept both hdtv (y/pb/pr or rgb) signal and component (r-y(cr)/y/r-b(cb)) signal at the same time, without any optional ifb board.
picture orbit function
a picture orbiting function prevents crt burn, which is an inherent problem with crts. when a still image is projected for a prolonged period of time, the image can burn into the crt. in order to decrease burn-in, the system rotates the image at an indistinguishable speed and range.
7 on-screen languages
for a broader user range. languages used for the on-screen display can be selected among english, japanese, chinese, german, french, italian and spanish, based on the user's preference.
video memory function
up to 10 control setting recalls for each signal input, 6 factory presets, and picture control settings can be adjusted and memorized according to viewer preference. up to ten different memory settings are available for easy recall. picture control settings include functions such as contrast, hue, and brightness. all video memory inputs can be changed.
multi screen brightness uniformity
when a number of projectors are simultaneously used for a multi-screen display, a cascade or daisy chain connection of the abl terminal on each projector is possible. once the abl activates on a projector, the others will automatically follow, maintaining uniform brightness on the entire screen.
rs-422a interface computer control
the rs-422a remote interface enables a computer to control the projector operation, allowing for system expansion.
index function
control individual pjs in multi-unit applications. a "built-in" index function allows an index number to be assigned to each projector in a multi-unit application.
conserve energy
when there is no signal input for more than 10 minutes, the projector will automatically enter into the power save mode, and the projection image will become muted. as soon as a signal is fed to the projector or any of the control keys are pressed, the projector will resume operation.
specifications
system : ntsc / pal / secam
crt : 7" (phosphor size 5.5-inch) high luminance air coupled (color corrected: red/green) static focus tubes
lens : double focus f/1.0/135mm
screen coverage: 60-250 inches (viewable area measured diagonally); factory preset 100 inch
light output : ansi 160 lm (64khz:50hz, 6500k), ansi 130 lm (15khz:60hz, 6500k), peak white: 800 lm, all white: 200 lm
tv lines : 700 tv lines (video), 1000 tv lines (hdtv)
resolution: 1280 x 1024 (rgb, measured at fh:64khz, fv:60hz)
scanning frequency : h: 15-64khz v: 38-150hz
rgb bandwidth : 75mhz (-3db)
test signals : cross hair, hatch (9x9/17x17) reverse, dot (9x9), h/h reverse, me/me reverse, all white, window, window and line, color bar, pluge, stair-step, sub-pattern, cross (9x9)
power requirements : ac 220v to 240v, 50/60hz
power consumption : 450w, standby 7w
operating temperature : 14-104°f, (0-40°c)
dimensions (wxhxd) : (603 x 345 x 671mm)
weight : (54kg)
Site web du constructeur :
5 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: alfachris, flozelarm, ibanana, Lisadrian, LSD, peter75, THX72 et 11 invités
Super peinture sur le projo! Ca le change de sa couleur traditionnelle!
- Cinemaniac
- Inscription Forum: 01 Mar 2002 2:00
C'est pour mieux se fondre au plafond. WAF compliant
- lcaufrie
- Inscription Forum: 07 Sep 2002 9:56
Zarlator, Il semblerai que le MP que j'essaye de t'envoyer ne marche pas. Tu peux me contacter directement sur lcaufrie@mail.mobistar.be
- lcaufrie
Vendu
- lcaufrie
5 messages
Retourner vers Projecteurs et Ecrans |
