crazyeightykillers a écrit:savez vous ou peut on se procurer ce lecteur(sur un site français bien sur)? merci
http://www.moovika.fr/boutique2/mediapl ... p-316.html
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: albator91, bab1c, banjo65, gallak, gamerone2008, Gaël, guillaumodore, gwendal55, jcre17, ludo3159, minifrix, mirak, papounay, Patbon21500, Patoche21, Pilou57, rere130, rezoli, Solitaire555, subsonic, sylvain-best, Tommyknockerz99, tony51, Wend, yoann2004, Yvounet et 271 invités
1 - The Kaiboer does support DTSpassthrough however you need a receiver capable of decoding DTS in order to have sound. If the Kaiboer is connected directly to your TV without a receiver, it will likely not work...
2 - You could check to use PCH A-110 firmware on tha Kaiboer (there are threads discussing the flash to other models) which support DTS downmix but you will risk your warranty in this case...
source
19 messages
• Page 2 sur 2 • 1, 2
Retourner vers Lecteurs et Box Multimedia |
