11 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: christian.vuil, delennsheridan, gallak, Gaël, govez, Izif74, jaoued, jeanfrancois03, juc, matrox445, Smooth Jazz, Stade81, Stephan974, thermique85, wariojp, zeh et 144 invités
DViCo PVR M-6640N
DViCo PVR M-6640N
Unrivaled Dual Tuner PVR with Multimedia Player
M6640N is a portrait of future PVR with multimedia playback capabilities. For a PVR, it has dual tuners which enable you recording two RF channels simultaneously and it supports the time-shifting which can pause the live broadcasting. You can upgrade your HDD capacity any time with just simple insertion. In addition, M6640N has an unrivaled multimedia playback capability including playback 1080p full-HD movies, the oncoming generation of HD audios, high resolution photos with thumbnails and lossless high-resolution music files. It also includes Wi-Fi 11n module which enables you connect your local network or internet, so you can playback all the contents on You-tube and other internet media sites, as well as your remote PC in another room.
Dual tuner HD PVR (Personal Video Recorder)
With its dual digital tuner, M6640N is able to record two different digital HD broadcastings simultaneously and to pause live broadcasting (Time-shifting). And it provides Electronic Program Guide (EPG), so you can simply select two channels to be recorded on the EPG.
Universal Jukebox That Supports Most Of The Media Formats.
By supporting superb H264 video compression & MKV container format, you can enjoy full HD videos. On top of this, oncoming HD media backup files as well as DVD backup files are supported. It functions as a universal jukebox that allows you to enjoy videos and music of ultimate quality through full HD picture and next generation HD audio output. It can also playback today’s high-res photos and lossless music files.
HDMI 1.3, 11n Wi-Fi and UPnP support
HDMI 1.3 support allows you to set up and use video and audio signals conveniently with just one cable. Wired/wireless network connection is easily enabled with uPnP support, and you can easily play various multimedia files on the network. 6640N has built-in Wi-Fi 11n module, so you can enjoy all the contents on your PC or NAS storage with wireless connection.
- Realtek RTD1283
- Récepteur / enregistreur TNT HD double tuner (2 enregistrements simultanés)
- Time-shifting
- Enregistrement programmable avec EPG
- Compatible H.264 (Profil 4.1), MKV et RMVB
- Module sans fil 802.11n intégré
- Compatible avec la dernière génération de flux audio HD
- Fichiers audio sans perte (24bit/96kHz FLAC, WAVE PACK)
- Services Web tels que YouTube, Picasa, Flux RSS (Internet Media Service)
- HDMI 1.3
- Lecteur de carte mémoire SD / MS Card (copier et coller)
- Compatible UPnP pour une connexion facile au réseau.
- fonction NAS
- Mises à jour firmware facile
Fiche produit officielle :
http://www.tvix.co.kr/ENG/products/PVRM6640N.aspx
- Christophe CHEREL
- Pro-Fabricant
- Inscription Forum: 06 Juil 2001 2:00
bonjour,
quel est la différence avec ce modèle ci (à priori un 6600 donc sans tuner tnt hd hors il est indiqué dual tuner TNT HD):
http://www.hdland.fr/boutique/fiche_pro ... g_fr&num=0
Et est-ce qu'il sera bientôt en démo à la boutique ?
- Le_Fredo
- Inscription Forum: 07 Fév 2006 16:50
En fait, c'est un 6600N avec tuner TNT HD et Wi-Fi. Nous allons modifier la fiche produit mais comme nous ne sommes pas encore certain de la référence Française, nous attendons de recevoir les machines. Pour le moment, il n'y a aucune info officielle de la part de DViCo France à ma connaissance. L'info ne figure que sur le site coréen.
- Christophe CHEREL
- Pro-Fabricant
Le_Fredo a écrit:Et est-ce qu'il sera bientôt en démo à la boutique ?
Oui.
- Christophe CHEREL
- Pro-Fabricant
Bonjour.
Plusieurs questions:
1- peut on enregistrer un programme TV tout en regardant une video? (ca a l'air bete comme question, mais il me semble que ce ne soit pas possible)
2- peut-on commencer à regarder un enregistrement avant qu'il ne soit terminé?
Merci de vos précisions
- sdeville
- Inscription Forum: 10 Sep 2009 9:55
Topic à supprimer ?
- TKB
- Inscription Forum: 08 Jan 2007 21:26
Oui, apparemment cet appareil est le 6632 en France
- Davids777
- Inscription Forum: 26 Aoû 2008 19:39
TVIX PVR M-6640N de Divco
Ma question concerne la date de sortie en France du dernier né des Divco : TVIX PVR M-6640N.
A partir de quand sera-t'il dispo à l'achat sur le net ou en magasin "physique".
Il était annoncé pour fin 2009 et en cette mi-janvier 2010, toujours rien. Qq'un a-t'il des news ?
La principale différence entre le TVIX PVR M-6640N et le TVIX PVR M-6632N est-elle une question de norme du double tuner HD : norme ATSC pour le 6632 et norme DVB-T pour le 6640, ou y-a-t'il autre chose ?
Merci de vos réponses.
- Albator38000
- Inscription Forum: 19 Jan 2010 16:22
Tu risques d'attendre longtemps le 6640 car il ne sortira jamais en France, l'équivalence française est le 6632 qui lui est dispo depuis fin septembre/début octobre 2009.
Tu peux aussi avoir en référence un 6600 avec double tuner, c'est la même chose
- Idargos
- Inscription Forum: 25 Avr 2009 18:02
Merci Idargos pour te réponse.
Ok je vais opter pour le 6632
Bonne journée.
Bonne journée.
- Albator38000
Enregsitrement
Est ce que ce produit, ou son équivalent en France, supporte la connexion avec un récepteur satellite?
Est ce que l'enregistrement ne peut se faire qu'avec la TNT?
Sinon qu'en pensez-vous du produit : Dane-Elec So Smart PVR (techniquement et fonctionnellement)
- so7lob
- Inscription Forum: 09 Fév 2010 10:22
11 messages
