Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 126 invités
une nouvelle carte son ASUS ... Xense
Message » 22 Sep 2010 20:19
Asus a sortie au US une nouvelle carte son la xonar Xense, en fait c'est un packaging avec casque senheiser!
http://www.hardwarezone.com.sg/tech-news/view/59675
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132018&Tpk=xense 300 $
Quelqu'un a des infos?
thesb
Inscription Forum: 26 Déc 2008 11:59
Message » 22 Sep 2010 20:52
AlexScan
Inscription Forum: 27 Déc 2005 20:57
Message » 22 Sep 2010 20:53
Output Signal-to-Noise Ratio (A-Weighted): 118 dB
Input Signal-to-Noise Ratio (A-Weighted): 118 dB
Output THD+N at 1kHz: 0.00039% (-108dB) for Front channel of Line-out
Input THD+N at 1kHz: 0.0003% (-110dB) for Line-in
Frequency Response (-3dB, 24-bit/96kHz input): <10Hz to 46KHz
Audio Processor: ASUS AV100
24-bit D-A Converter of Digital Sources: PCM1796 for Front-Out (123dB SNR, Max. 192kHz/24bit); CS4362A for other 6 channels (114dB SNR, Max.192kHz/24bit)
24-bit A-D Converter for Analog Inputs: Cirrus-Logic CS5381 x 1 (120dB SNR, Max. 192kHz/24bit)
High Fidelity Headphone Amplifier: TI 6120A2 (120dB SNR, -117dB THD+N @ Vcc+-12V, RL=600Ω, f=1kHz)
Sample Rate and Resolution: 44.1K/48K/96K/192KHz @ 16/24bit
S/PDIF Digital Output: 44.1K/48K/96K/192KHz @ 16/24bit
ASIO 2.0 Driver Support: 44.1K/48K/96K/192KHz @16/24bit with very low latency
I/O Ports Analog Output Jack: 6.30mm jack*1 (Headphone out); 7.1ch analog output (via bundled audio splitter cable)
Digital S/PDIF Output: High-bandwidth Coaxial/TOS-Link combo port supports 192KHz/24bit
Dolby® Technologies: Dolby® Digital Live, Dolby® Headphone, Dolby® Virtual Speaker, Dolby® Pro-Logic II
Xear 3D™ Virtual Speaker Shifter: Virtual 7.1 speaker positioning
FlexBass™: Professional Bass Management/Enhancement system
Other Effects: 10-band Equalizer/27 Environment Effects
etc ...
AlexScan
Message » 22 Sep 2010 21:04
Pas mal , on dirait une Xonar D2X avec un vrai ampli casque , plus orienté jeux que HC, vu que les DAC sont moins performant pour les 6 canaux complémentaire en HC ...
AlexScan
Message » 22 Sep 2010 21:23
je trouve sympa l'idée du casque en plus ... :idee:
thesb
Message » 23 Sep 2010 13:34
êtes vous au courant de quand il sera disponible en france car depuis 2 semaine tout les jours je fais une recherche pour le trouver sur un site Français ...
Merci d'avance
obi-wan76
Inscription Forum: 13 Sep 2010 21:12
Message » 23 Sep 2010 16:47
C'est pas dit que ça vienne ... prend un essence ST ou STX et le casque séparément ...
Pour ça le Service Marketing ASUS France ... c'est pas des bons ... pour être gentil encore!
thesb
Message » 23 Sep 2010 22:41
Oaui sauf que Thesb le tout serai plus cher.
Plus cher car je me fixe sur cette annonce trouvé sur internet :http://www.itrgames.com/articles/108925/asus-sennheiser-lancent-solution-audio-gamers.html
Il est fait mention "Il sera disponible courant septembre au prix de 249,90 euros" et le prix est bien en Euros donc donc une sortie de prevue en Europe en tout cas, mais le problème c'est que c'est marqué courant septembre et qu'on approche de la fin ...
obi-wan76
Message » 23 Sep 2010 23:23
8) reste plus qu'a attendre
thesb
Message » 25 Sep 2010 16:45
Ah, premiere apparition sur un site français.Par contre c'est du particulier :http://www.priceminister.com/offer/buy/109884293/asus-xonar-xense-carte-son.html
Espere-on que sa sorte sur un site non vendu par des particuliers, un petit materiel.net ou autre sa serait top d'ici la fin de la semaine qui vient .
obi-wan76
Message » 30 Sep 2010 19:45
obi-wan76
