Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: bab1c, cee1970, curieux31, delennsheridan, ean27, guillaumodore, Gunm35, gwendal55, Knives86, macech, Miky10, minifrix, misichavichus, NicolasBuf, nonath2, Olivier Dutel, Patbon21500, shenos, Sibara, symus35, thivame et 213 invités
DViCO TViX Xroid A1 (Android 2.2 + Sigma Designs SMP8657)
On peut ajouter un double tuner HD pour enregistrer la télé ou c'est juste un lecteur ?
- Davids777
- Inscription Forum: 26 Aoû 2008 19:39
Pas possible d'ajouter un Tuner TNT, c'est seulement un lecteur.
Nouveau firmware disponible :
http://demod.dvico.com/Down/TViX_Xroid_A1_1.1.2.fwp
Release Notes for Rev 1.1.2 since Rev 1.0.23
1. Improves TViX Share
- The SEND(UPLOAD) function has been added.
< How to use the SEND feature >
1) Click friend's nickname on the FRIEND tab.
2) Click 'Request Send permission' and your friend will accept your nickname or click ' Allow send' and inform to your friend.
3) In Media tab, click your nickname (green icon) -> view files
4) Click a file or folder to upload and select 'send' menu
5) Select nickname you want to send a file.
6) upload will be progressing.
7) You can find uploaded file or folder in your download directory. ( ex, HDD_1 \STORAGE\Downloads)
* We'll display download and upload progressing in TViX share, so you can know when upload will be finished from your friend.
- Auto accept option in TViX Share has been added.
If you check the Auto accept option (Default is off) on the share's setting, anyone can connect your unit without approval. We already prepared tvix12 nickname for your testing.
- Overwrite function of TViX share has been added.
In case same file has existed, sometimes download has been stopped for this reason. This problem has been solved.
- Supports Auto upgrade of the TViX share. If version is different, TViX share will update the latest version automatically.
2. Supports TViX Torrent.
- You can search torrent file and download it without PC.
Lists of search are 100 at this version, but we'll increase it soon.
- You can also add your .torrent file.
You can download a torrent file from web browser of TViX or PC and then you can add this file.
- Default path of download is HDD_1\STORAGE\Torrent
- Maximum number of download is 5.
3. The scenario of MOVIE, MUSIC and PHOTO buttons was changed.
- Press MOVIE button on the remote controller, you can open MOVIE folder of first device directly.
- Press MUSIC button on the remote controller, you can open MUSIC folder of first device directly
- Press PHOTO button on the remote controller, you can open PHOTO folder of first device directly.
- It is available at main screen or file list mode when you press these keys.
4. Main icon scenario was changed.
- Press MOVIE, MUSIC or PHOTO icon at the main screen, displayed root folder of first device.
- To change device, Press MENU button or UP FOLDER.
5. Supports Resume/Bookmark page.
- Resume/Bookmark page has been added as a separate UI.
- Press BOOKMARK button on the main screen or file browser to open this page.
- Press OK button, and resume or bookmark file will be started.
- To delete a list, press DELETE button on the list.
6. Supports Dynamic 3D animation GUI.
- Main icon has been improved as Dynamic 3D animation.
- Updated much more wallpaper, so you can change your wallpaper easily.
7. Trick Playback of Blu-ray/ .ts/ .m2ts/ mpeg files have been supported.
8. Added warning box at TViX share or TViX torrent.
- If you don't want to display this popup, please uncheck 'Always show this warning'.
9. Fixed the problem that vertical application was not control with mouse or Remote.
10. Fixed the problem that slideshow was occurred Memory error sometimes.
[ Below issues are improving now. we'll release new firmware after supporting it soon.]
- Supports 1080P 24Hz
- Supports Easy network browsing.
- Supports 3D MKV subtitle and OSD.
- Supports APE audio format.
- Support easy firmware updating and network firmware updating
- Supports multilingual virtual keyboard.
- Supports Upnp connection.
- This version is not available audio multi-tasking.
- Idargos
- Inscription Forum: 25 Avr 2009 18:02
Cà ne dis pas si il lit le 24/96! D'autre part un défaut du S1 est l'arrêt de la lecture dès que l'on recherche un autre fichier Serait-ce pareil avec le A1 ?
Pour info, mon simple WD Live Hub avait cette fonction
alfachris - Membre HCFR
- Inscription Forum: 12 Aoû 2003 21:36
Désolé mais je ne peux pas te répondre Alfachris, mon utilisation du Xroid est dédiée à 100% à la vidéo.
- Idargos
Idargos a écrit:Désolé mais je ne peux pas te répondre Alfachris, mon utilisation du Xroid est dédiée à 100% à la vidéo.
moi j ai bien envie de l acheté rien pour mes mkv est ce que c'est utile
le reste je m en fout
- PITO59
- Inscription Forum: 05 Juin 2009 22:52
TVIX Xroid Wifi > GROS PROBLEME ATTENTION ! <
C'est mon premier achat de Tvix Dvico et je suis totalement décu, franchement rien ne marche dessus !
Je le branche --> mon Hd fait planter le Tvix il se met a figer et redémarre alors que le Hdd est Neuf "Seagate Barracuda 2TO eco " du coup je fais la derniere mise a jour, super j'ai un beau wallpaper maintenant mais toujours le même probleme le Dvico ne bouge pus une fois le disque dur inséré. J'ai testé le Hdd sur un Pc ca tourne Nikel )) bref je me décourage pas je tente d'acceder à mon autre disque dur réseau via la fonction UPNP "pour info c'est un WD Live book à 100 euros qui est connecté en RJ45" et bam ! le Tvix ne peu pas se connecter en UPNP ???
Et oui il y a une belle icone mais visiblement elle est la pour faire déco...
Bref pour un bouzin à 300 euros c'est une honte . Même mon A...TV qui coute 3 fois moins chère fais mieux !
C'est un cadeau qu'on m'a fait et bah franchement pour une société qui se veut être Haut de Gamme dans les lecteurs multimédia c'est dramatique de sortir de lecteur en Production un produit à moitié fini ! nan mais franchement l'Upnp c'est pas le pérou, même ma Box internet le fait !!!!
Si quelqu'un à une idée sur le disfonctionnement de l'appareil je suis preneur car la il va vite finir à la poubelle !
NB:il aurait du l'appeler DROIDE2CASSE au lieu de Xdroid !!
- TvixXroid
- Inscription Forum: 22 Déc 2011 2:24
TvixXroid a écrit:Je le branche --> mon Hd fait planter le Tvix il se met a figer et redémarre alors que le Hdd est Neuf "Seagate Barracuda 2TO eco " du coup je fais la derniere mise a jour, super j'ai un beau wallpaper maintenant mais toujours le même probleme le Dvico ne bouge pus une fois le disque dur inséré. J'ai testé le Hdd sur un Pc ca tourne Nikel ))
Sans doute un problème d'incompatibilité avec ce disque dur, tu n'en as pas un autre pour essayer ?
TvixXroid a écrit:bref je me décourage pas je tente d'acceder à mon autre disque dur réseau via la fonction UPNP "pour info c'est un WD Live book à 100 euros qui est connecté en RJ45" et bam ! le Tvix ne peu pas se connecter en UPNP ???
L'uPNP va arriver prochainement, c'est annoncé.
TvixXroid a écrit:Bref pour un bouzin à 300 euros c'est une honte
Le Xroid A1 est à 220€ (et même 180€ sur certains sites), il n'a jamais été à 300€.
- Idargos
PITO59 a écrit:moi j ai bien envie de l acheté rien pour mes mkv est ce que c'est utile
Pas de problème de lecture avec les rares MKV que je possède.
- Idargos
Jai craqué et j'ai aussi commandé le mien chez ExportPrivé à 179 €. Par contre les frais de port Du coup j'ai pris l'envoi à 8€ et je vais etre patient 15 jours
- manelisa
- Inscription Forum: 14 Mai 2003 18:21
Bonjour a tous,
Voila j'explique mon soucis j'ai acheter un Tvix Xroid recemment et j'ai le meme soucis que TvixXroid juste au dessus !!! je ne sais plus quoi faire !!!
"mon Hd fait planter le Tvix il se met a figer et redémarre alors que le Hdd est Neuf "Seagate Barracuda 2TO eco " du coup je fais la derniere mise a jour"
j'ai exactement la meme config que lui
Si quelqu'un aurai une solution ou une idée !!???
- melkuss
- Inscription Forum: 02 Jan 2012 15:51
Même configuration et même disque dur, c'est probablement là que ça coince. Il faut faire un essai avec un autre disque dur pour confirmer un problème avec le Seagate Barracuda 2TO eco.
Perso j'ai un Samsung 1,5 TO, pas de problème.
- Idargos
Arf, Je Viens D'essayer avec un hitachi 750GB toujours le meme soucis... ca pourrait venir d'ou à votre avis???
- melkuss
C'est le Xroid qui a fait le formatage des disques durs ou ils étaient déjà formatés ? S'ils étaient déjà formatés qu'elle type de formatage, NTFS ? Partition principale ou étendue ?
- Idargos
NOn je l'ai formaté sur mon Pc! En FAT32 et en une seul partition je pense
- melkuss
