Type : Bloc de puissance
Marque : Cary
Modèle et options : Model 7.250
Prix de vente : 4000€. Baisse à 3800€
Valeur neuf : 7500€
Département où la marchandise est visible : Suisse/France
Possibilité d'expédition : à discuter, c'est un tank !
État de la marchandise : Parfait état
Première main : non
Facture disponible : non
Poids: 52 Kg
Extrêmement rare en occasion, une vraie usine à watts
C'est à regrets que je vais m'en séparer pour descendre en gamme
Pris du site de Cary :
The Model 7.250 is a seven-channel power amplifier rated at 250 watts per channel into an 8 ohm load and 400 watts per channel into a 4 ohm load. The rear panel has XLR and RCA inputs and a remote turn on trigger. The Model 7.250 is powerful, accurate, and capable of driving any home theater system to reference levels with ease.
Circuit Type Solid State, Class A/B
Power Output:
7 x 250 watts @ 8 Ohms
from 20 Hz to 20 KHz
7 x 400 watts @ 4 Ohms
Input Sensitivity
1.25 Volts RMS Unbalanced
2.5 Volts Balanced
Frequency Response 20Hz - 20KHz +/- 0.1 dB
Signal-to-Noise Ratio >100dB "A" Weighted
Input Impedance
>10K Ohms unbalanced
>20K Ohms - Balanced
Voltage Gain 28 dB
AC Power Requirements 117/234 Volts AC @ 50/60 Hz
Break-In Time 100 hours of playing time
Finish Black epoxy coated steel chassis
Silver anodized aluminum faceplate
(black optional)
Weight 105 lbs
Dimensions 8.7” H x 17.7”W x 19.6”D
Audio Input 7 RCA, 7 XLR
Audio Output
7 pairs of heavy-duty, gold-plated binding posts
THD Less than 0.05% at rated output
Crosstalk
Greater than -90dB from 20Hz to 20KHz
Damping Factor Greater than 270 from 10Hz to 400Hz
Slew Rate
40V/mSec
Remote Trigger 3-32v DC at 5mA or greater
Rack Mounting Optional brackets are available for mounting the amplifier in a standard 19 inch equipment rack.
Test:
Images:
8 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: THX72 et 55 invités
Up ! Et j'etudie toute proposition raisonnable
Seb
Seb
- sebrenaud
- Inscription Forum: 31 Aoû 2009 11:39
8 messages
