Type : Ampli de puissance
Marque : Crown
Modèle et options : CST 4200
Prix de vente : 700€
Département où la marchandise est visible : 95
Montant des frais d'expédition : 30€
Prix neuf : 1800€
Facture disponible : non
Date, pays et lieu d'achat : France sept 2014
The Crown-Audio CTs 4200 is a 4-channel power amplifier housed in a 2RU rack, offering 190 watts per channel at 8 ohms, designed for fixed installation use.
This amplifier features multiple simultaneous channel operation modes, 70 volt and 100 volt support, a switching power supply, and a variable speed fan cooling system. There is a comprehensive set of front panel indicators for each channel, along with advanced, well-designed thermal protection and fault isolation circuitry. The rear panel offers individual channel level trim controls, and 4-position operating mode switches.
4-channel installation power amplifier in 3 RU rackmount enclosure with 180W of power per channel at 8 ohms
Crown switching power supply for reduced weight
Selectable constant voltage 70V/100V or 4/8 ohm low impedance operation per channel pair with dedicated 4-position switches
Multi Mode output topology allows for simultaneous dual and bridged operation
FIT(Fault Isolation Topology) circuitry isolates faulty channels; adjacent channels remain unaffected
TLC thermal protection circuitry engages internal channel compressor, dynamically reduces amplifier gain to reduce heat levels and prevent overheating
Front-to-rear forced airflow cooling vents, continuously variable speed fan cooling
Automatically inserted 35 Hz high-pass filter for channel pair in 70/100V operation
Advanced protection circuitry includes guards against shorted outputs, open circuits, mismatched loads, general overheating, DC, under/over voltage, high frequency overloads and internal faults
Comprehensive front panel indicator array includes individual channel LEDs for Bridge, Ready, Signal, Clip, Thermal and Fault; dedicated Power and Data indicators
Blue power indicator LED flashes when amplifier shuts down during under/over voltage condition on AC mains
Site web du constructeur :
Commentaires : Suberbe ampli d'une série méconnue de la gamme Crown... 4x200 watts, idéal pour une bi-amplification active...Prévu pour les installations fixes, cet ampli a une connectique spécifique...entrée "phoenix"...j'offre 2 jeux de câbles XLR/Phoenix montés par mes soins!
A noter que les potentiomètres de gain sont à l'arrière, et que le ventilateur à vitesse variable est inaudible...
4 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Bidibule et 61 invités
Ampli CROWN CST 4200 (4X200watts) 700€!
alfachris - Membre HCFR
- Inscription Forum: 12 Aoû 2003 21:36
superbe ampli que j'utilise pour bi amplifier mes compression bms… bien regler 0 souffle.
- wilmo76
- Inscription Forum: 05 Déc 2005 19:34
....Toujours en vente..avec une petite baisse! Et je rappelle que l'ampli est neuf..
4 messages
