Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Luc021, niaro et 111 invités
Subs XTZ 1x12" ou 3x12"
Je confirme que le service de Videopole est excellent. J'attends que mon Velodyne CH12Q claque pour le remplacer par un XTZ12 mais il résiste... J'en suis presque triste.
- coincarre
- Inscription Forum: 12 Sep 2011 20:36
Tu n'as qu'à le laisser en mode auto et il va vite lâcher ton ch12
- christian.legaig
- Inscription Forum: 11 Juin 2015 21:03
mon ampli n'ayant qu'une seul sortie sub je voulais brancher le 2eme caisson à la sortie du premier mais il me semble qu'il n'y a pas de sortie RCA juste 2 entrée
quelqu'un peut me le confirmer merci
- bola31
- Inscription Forum: 03 Aoû 2010 23:07
XTZ a écrit:When connecting multiple subwoofers using RCA signal connections, you will need to use “Y” cables (signal splitters) to route your receiver/processor output to each woofer if it does not have multiple “SUBWOOFER” output jacks. Another option is to use an XLR to RCA adapter to convert your receiver/processor RCA signal ouptut to an XLR connection, which allows you to use the XLR “DIRECT PASS-THRU”.
When connecting multiple subwoofers using XLR signal connections, you may wish to use the XLR “DIRECT PASS-THRU” output connection to simplify your installation. This will allow you to run 1 long XLR cable from your processor’s “SUBWOOFER” output jack to the 1st subwoofer’s XLR input, and an additional shorter XLR cable connects the 1st subwoofer’s XLR “DIRECT PASS-THRU” output to the input of the 2nd subwoofer in the signal chain. If installing a multi subwoofer system containing three or four subwoofers, additional short XLR cables can be used to connect the “XLR DIRECT PASS-THRU” output of the 2nd subwoofer to XLR input of the 3rd subwoofer, and another short XLR cable to connect the “XLR DIRECT PASS-THRU” output of the 3rd subwoofer to XLR input of the 4th subwoofer. If your processor does not provide an XLR output, you may use an RCA to XLR adapter cable to connect your receiver to the 1st subwoofer in a multi subwoofer system, and use regular XLR cables to make the connections between additional subwoofers, as noted above.
- Rugbystick
- Inscription Forum: 13 Jan 2007 14:50
je les espère lundi, au plus tard mardi...
Frédéric
Frédéric
- Videopole
- Inscription Forum: 01 Fév 2012 14:27
bola31 a écrit:mon ampli n'ayant qu'une seul sortie sub je voulais brancher le 2eme caisson à la sortie du premier mais il me semble qu'il n'y a pas de sortie RCA juste 2 entrée
Pas de sortie RCA sur le caisson pour faire comme tu le souhaites.
Par contre tu peux utiliser un câble en Y à partir de ton ampli pour raccorder chaque entrée Line In 1 des deux caissons.
- Sebass
- Inscription Forum: 01 Déc 2005 14:37
La lecture de ces dernières pages me laisse circonspect.
Vidéopole est un grand philanthrope. Il ne marge presque pas.
Il contraint juste le constructeur à ne plus faire de remise pour se rendre incontournable en France et fait en plus sa pub gratos sur un forum...
- sebcom1
- Inscription Forum: 17 Fév 2004 1:24
Oui je vais acheter un doubleur rca audioquest dommage car la plupart des caisson on une sortie rca mais bon le doubleur en fera autant
- bola31
sebcom1 a écrit:La lecture de ces dernières pages me laisse circonspect.
Il assure le service après vente... faut bien que tout le monde y trouve son compte.
La négo entre XTZ et videopole ne nous concerne pas vraiment et il est bien normal que videopole protège sa pépite... n'importe quel revendeur malin cherche à obtenir l'exclu.
De mon côté très satisfait de mes échanges avec videopole
- eldugglu
- Inscription Forum: 28 Aoû 2003 18:04
bola31 a écrit:Oui je vais acheter un doubleur rca audioquest dommage car la plupart des caisson on une sortie rca mais bon le doubleur en fera autant
Oui cela sera exactement pareil au final.
- Sebass
eldugglu a écrit:sebcom1 a écrit:La lecture de ces dernières pages me laisse circonspect.
Je ne dis pas le contraire et c'est de bonne guerre... mais ce qui est pénible avec les pro du forum en général c'est le double langage, le fait de devoir lire en permanance entre les lignes et le manque d'objectivité.
fin du HS n ce qui me concerne
- sebcom1
Et bien, je ne vois pas autant d'acharnement sur le thread SVS avec Futureland...
- Rugbystick
Pas faux
- Sebass
Reçu les 2bébés ils sont magnifiques, la forme et bizarre au premier coup d'oeil mais cela me gêne pas,j'ai pu les testé un peu sur de la musique la basse et très propre me rappelant mon ancien sb13ultra, j'attends la fin du rodage et surtout les calibré avec l'arc pour en parler un peu plus
- bola31
