La salle est vraiment superbe : éclairage, mise en valeur des produits
Il n'y avait pas une nouveauté annoncée lors de ce salon ???
J'ai du zapper un truc !
Modérateurs: Le Bureau de l’Association HCFR, Les Relations PROs de l'Association HCFR, Publications HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 30 invités
DAC TOTALDAC
- Fabrice-Ensemble
- Inscription Forum: 10 Sep 2005 17:14
Merci pour ceux qui ont participé à cette salle.
Les futures nouveautés sont bien cachées dans le descriptif du système:
http://www.totaldac.com/ecoute.htm
- vincent_brient
- Pro-Commercant.
- Inscription Forum: 10 Oct 2003 19:03
vincent_brient a écrit:Le compte rendu de Munich de Stereophile, le plus grand magasine mondial qui écoute et mesure .
https://www.stereophile.com/content/herbs-first-morning-munich
As some of you might know, I am a rabid fan of Vincent Brient's discrete resistor ladder DACs that he builds in France in the shadow of France's Mont Saint-Michel monastery. Today, I finally I got to meet Vincent in person and experience his two-way d150 horn loudspeakers (46,000 Euros/pair). I was impressed by both of them. The d150's sound was relaxed very wide open and delightfully coherent. These beautiful turned-wood horns were driven, not by a compression driver, but by a full-range cone driver; which is crossed over to a 15" bass driver at 150Hz. I was immediately impressed by how smooth, vivid, and 3-dimensional the sound was. Sensitivity is claimed to 98dB/W/1m.
The d150s were supplemented by two Totaldac subwoofers (6500 Euros each), which feature 18" drivers mounted high up. Think big, full, open, and exceptionally coherent. I would have nominated Brient's system for best sound at show, but is was only the morning of my first day, so I moved on.
Félicitations Vincent pour la mise en oeuvre musicale qui semble avoir été à la hauteur des attentes
et du matériel en action !
- BL89
- Inscription Forum: 17 Juil 2013 1:12
vincent_brient a écrit:Merci pour ceux qui ont participé à cette salle.
Le server Nas et le D1 Driver dont nous aimerions avoir des photos...
- La Bastille
- Inscription Forum: 21 Avr 2008 21:38
La Bastille a écrit:vincent_brient a écrit:Merci pour ceux qui ont participé à cette salle.
Le NAS est au sol à côté de l'enceinte de droite.
Le d1-driver utilise un boitier de DAC et il était positionné dans le meuble.
- vincent_brient
- Pro-Commercant.
Une autre des salles Totaldac avec en écoute: GIGAFILTER + Totaldac reclocker + DAC Totaldac d1-seven, ampli Holton Audio, câbles Tellurium Q et enceintes Soulsonic HOLOGRAMM-X:
https://soundrebels.com/hifideluxe-2018-cz-2/
"it played phenomenally, that is, full of concert swinging sound."
- vincent_brient
- Pro-Commercant.
L'avis de The Absolute Sound, l'autre gros magasine américain. Le système utilisait alternativement du vinyl ou un DAC Totaldac.
"Best Sound (cost no object)
There was a complete lack of grain and glare;
the presentation had utterly natural timbre and tremendous ability to pull me into the music rather than to think about the sound.
A terrific system expertly set up."
http://www.theabsolutesound.com/articles/the-2018-munich-high-end-show/
- vincent_brient
- Pro-Commercant.
Tout nouveau puisque mon TTD va être commandé sous peu : D1 Core + Server + quelques options.
Plus tard, ce sera la seconde alim pour le server.
J'ai lu quasiment tout ce fil déjà . Très instructif pour se familiariser avec le dac, ses déclinaisons plus hdg, ses options, son fonctionnement...
Si vous avez des conseils, des suggestions...
Merci et bonne soirée
- omega-system
- Inscription Forum: 04 Juin 2018 21:17
Bonjour Omega-système,
félicitations ! superbe entrée matière.
et donc qq suggestions :
en 1... profiter de ta musique
en 2... profiter de ta musique
et en 3... profiter de ta musique
en espérant n'avoir rien oublié.
- BL89
Merci !
Je vais tâcher de ne pas oublier !
- omega-system
Autre conseil : les laisser branchés en permanence
OPPO BDP-93 -> TOTALDAC D1-server ->Gigafilter -> TOTALDAC D1-dual -> NCORE NC400 -> Dynaudio Confidence C1 Platinum
- ucdfan
- Inscription Forum: 06 Mai 2008 9:47
Oui, j'y songeais.
Mieux vaut laisser tout complètement sous tension ou bien mettre en veille ?
Oui, j'y songeais.
- omega-system
La veille suffit. Pas très écolo, mais ça marche !
Et comme le dit BL89 : profiter de la musique
- ucdfan
Salut omega-system,
J'ai fait le même choix que toi il y a un an (D1 Core + serveur + double alim.) ... après de longues recherches ! Depuis ... je ne me suis pas posé trop de questions.
J'écoute de la musique !
On attend ton retour !
davis
davis
- davis
- Inscription Forum: 08 Mai 2015 10:44
Retourner vers Actualités des Enseignes
