Hi, I would like to know if anyone had this problem:
With very dark images I can see two vertical stripes (one per side) external
to the image, also without any entering signals with just the black screen
selected from the projector menu. I can better see them if I'm projecting on
the wall at 1 mt distance.
I asked information about to a Mitusbishi technician and He told me that is
a normal issue!!!
Thank you for your comments.
Meteor[/img]
6 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Clement1138, Driggs et 187 invités
Help: Mitsubishi Hc900 Verticale stripes
- Guanabats
- Inscription Forum: 17 Déc 2004 15:46
euh l'autre il parle même pas notre langue !
- Dark Anthony
- Inscription Forum: 07 Sep 2003 12:00
facile a comprendre mais je n'ai pas de hc900 ! donc je ne connais pas son defaut.
peut etre que les specialistes HC900 peuvent intervenir !
a+
Pierre
a+
Pierre
- PETER77
Guanabats a écrit:Hi, I would like to know if anyone had this problem:
a normal issue!!!
Meteor[/img]
Hello Guanabats
I test for you, with my HC900
At 1mt on a white wall, with black screen selected from the VP.
I can see the matrice, but no vertical stripe at the left or right side.
Par contre la non uniformité de l’éclairage apparaît.
Il faut dire qu’a cette distance les fuites de lumière viennent perturber le carré lumineux plus proche des gris que des noirs à cette distance.
Cette constatation faite lors de test avec des mires voir le tableau comparatif des VPS de Mlill n’est pas perçu lors de la projection.
- DRIX
- Inscription Forum: 31 Oct 2004 15:09
Ciao e grazie.
I’m writing for the “Official thread Mistubishi HC 900” www.avforum.it.
You have in France the HC900 from more time than us.
Thank you for the test you have done for us.
If we will have other problems surely we will ask your help.
GRAZIE
Meteor
GRAZIE
Meteor
- Guanabats
Guanabats a écrit:Ciao e grazie.
GRAZIE
Meteor
Va bene
Is was a pleasure.
- DRIX
6 messages
