Si cela peut servir
Les as tu testés ?
Pour moi c'est pas mal en 48"
Si cela peut aussi aider en allant plus loin en lisant un peu sur AVS
Les écran 48 pouces sont tous fabriqués Samsung
Les 55 / 65 pas tous les autres sont fabriqué de type "AUO" et ceux la ont des defauts et des reglages un peu particuliers.
Samsung,lg and all the brands say that they do not know about panels,do not know about issues in firmwares,always the negative is the answer,they need that the customers be stupid and pleasant and spenders in ignorance!
Samsung manufactures ALL the panels in 48,completly all.
Look at this
48 inch LCD Panel List (23 models) - Panelook.com
but if you eliminate the full hd resolution and choose 3840x2160 there is only samsung manufacturer
SAMSUNG LSC480FN01 Overview - Panelook.com
but for 55 inches,the things changes radically!
these are auo panels,total 8 models with 3840x2160 ! and only 2 models from samsung
AUO 55 inch TV LCD Panel List (57 models) - Panelook.com
these are samsung panels,just 2 models
LSC550FN01SAMSUNG55"CELL3840×2160 0 3500:1 No B/L 000
LSC550FJ02SAMSUNG55"CELL3840×2160 0 4000:1 No B/L 000
so only 2 panels from samsung and 8 from auo, stadistic.... 20% for samsung 80% for AUO
https://www.avforums.com/threads/samsun ... 84/page-47
