Cher Client,
Nous voudrions vous informer que nous avons une nouvelle
version de AnyDVD qui est maintenant disponible. Voici
la liste des améliorations et rectifications:
6.2.0.1 2007 11 20
- Note to people considering to invest in HD media: Please buy HD DVD
instead of Blu-ray. HD DVD is much more consumer friendly (e.g., no region
coding, AACS not mandatory, no BD+). Don't give your money to people,
who throw your fair-use rights out of the window.
- New: Installer now terminates processes using ElbyCDIO
- New: Added LBA to dirlist.txt for debugging
- New: Added PowerDVD version information to AnyDVD_Info file
- New (HD DVD & Blu-ray): Support for all MKBv4 titles
- New (Blu-ray): Workaround, so PowerDVD Ultra continues to play, if
AnyDVD is enabled
- New (Blu-ray): AnyDVD ripper copies BD+ titles
- New (Blu-ray): Removed "BD+ not supported" warning, as all available BD+
titles can be copied with AnyDVD ripper, or can be watched on HTPC without
HDCP using PowerDVD 3104 and AnyDVD.
- New (DVD): Improved Layer break removal in AnyDVD ripper
- New (DVD): Added more debugging information of AI Scanner
- Change (DVD): If logging is enabled, AI Scanner is set to "Deep Scan"
for better debugging
- Fix (DVD): CSS and APS problem with certain discs,
e.g. "Hairspray", US
- Fix (DVD): AI Scanner could cause a "CloneSpec 0" error with Alpha-DVD
protected discs, e.g. "Mr. & Mrs Smith", Germany
- Fix (DVD): AnyDVD ripper estimated wrong output size with FluxDVD protected
DVDs, e.g. "Curse of the Golden Flower", UK
- Changelog merged with beta versions
- Some minor fixes and improvements
- Updated languages
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Emmanuel Piat, metal_duc, pierrot le fou, Tazz24 et 99 invités
AnyDVD HD !
Salon: Jvc NZ7, Xtrem 1.1gen2, Lg 77g3, chambre samy 65s95b, Lg 55cs chambre enfant/ source: pana ub9000 +pchc+chinoppo+z1000pro,atv4k/ 3 Arendal monitor 1723S, 4 Divatech diva18 sur et back, 6 Svs prime elevation atmos/ Denon Avc-a1h/ sub arendal 1723 1S
- david555
- Superviseur Forum Univers TV & Contributeur HCFR
- Inscription Forum: 02 Oct 2005 18:13
C'est impréssionant, ils n'arrêtent jamais, chapeau Slysoft
- Sonic69
- Inscription Forum: 30 Oct 2002 23:12
evasram a écrit:C'est impréssionant, ils n'arrêtent jamais, chapeau Slysoft
Bin tant que l'empire sony contre-attaque...
- michael1971
- Inscription Forum: 24 Juin 2007 12:04
en effet impressionnant cette dernière version de Slysoft ..
elle permet bien la lecture via power dvd 7.3 ultra avec any d'activé.. je viens de tester..
- wool
- Inscription Forum: 13 Oct 2006 21:15
6.3.0.0 2007 11 30
- New (DVD): Some discs are mastered incorrectly and have invalid file
sizes. AnyDVD now corrects the file sizes in the VIDEO_TS directory.
- New (DVD): Added support for new copy protection as found on
"This is England" (R2, UK)
- Change (DVD): Default AI Scanner level is now "thorough", as some
discs did not work correctly with the previous default setting.
- Fix (HD DVD): Black screen with re-release of "Planet Earth" series.
- Fix (DVD): CSS decryption problems with some protected discs on
region code mismatch
- Fix (DVD): Although CloneDVD2 worked with "Hairspray" (US), AnyDVD
ripper aborted with a "VobSet 1" error. This is fixed now.
- Updated languages
- Updated languages
- david555
vive any dvd hd
bonjour merci anydvd-hd donc slysoft de nous défendre contre les géants de l'électronique car leur guerre stupide vient de prendre fin en ce qui concerne le hd-dvd et le bluray warner devient blurayBD+ à partir de mai exclusivement, heureusement que vôtre logiciel existe et nous permet de gôuter au joie de la hd sur notre matériels obsolète car ils nous prennent vraiment pour des C--- ses majors. longue vie a slysoft qui malgré tout respecte le plus les consommateurs lambda que nous sommes :
- XACTI HD2
- Inscription Forum: 19 Avr 2007 11:03
XACTI HD2 a écrit:bonjour merci anydvd-hd donc slysoft de nous défendre contre les géants de l'électronique car leur guerre stupide vient de prendre fin en ce qui concerne le hd-dvd et le bluray warner devient blurayBD+ à partir de mai exclusivement, heureusement que vôtre logiciel existe et nous permet de gôuter au joie de la hd sur notre matériels obsolète car ils nous prennent vraiment pour des C--- ses majors. longue vie a slysoft qui malgré tout respecte le plus les consommateurs lambda que nous sommes :
+1 malheureusement, c'en est même désolant, je dirais même rageant
- Sevydrago
- Inscription Forum: 09 Mar 2003 20:52
Je teste en ce moment même la sauvegarde d'un HD-DVD sur mon disque dur en utilisant AnyDVD, et ca a l'air de marche nickel.
Par contre une fois que j'ai les fichiers sur mon disque, j'en fait quoi? Mon but étant de pouvoir les lire avec ma PS3, éventuellement en les reconvertissant en un autre format (ex: MKV).
Merci de votre aide
Voici mon aide:
Les modifications de structure, de format, de support etc, sans le consentement du propriétaire des droits sont dorénavant du domaine de l'opération illicite. Ce qui est ici une opération de sauvegarde personnelle risque d'ouvrir sur cette moulinette totalement illégale +
Si SONY avait voulu ouvrir la lecture des formats HD DVD, cela aurait été su depuis longtemps !!
Attention à ne pas "glisser" faussement naïvement sur cette piste dans ce sujet, sur ce forum.
Pastor
Merci de votre aide
Voici mon aide:
Pastor
- ohmax
- Inscription Forum: 18 Avr 2002 12:27
[modéré]
Comme l'a dit pastor, "Les modifications de structure, de format, de support etc, sans le consentement du propriétaire des droits sont dorénavant du domaine de l'opération illicite".
Merci donc de ne pas aborder ces sujets ici.
[/ajds]
[/ajds]
- vador
- Inscription Forum: 03 Mar 2005 21:06
parceque ton anydvd n'est pas a jour. En gros le film que tu as dans ton lecteur necessite une MAJ d'anydvd
- david555
Bonjour, c'est la derniere version 6.3.0.3 que j'utilise, de quelle MAJ peut t'il etre question autrement??? Ou est donc le problème?
Vador
Vador
- vador
Attention dans ses dernières versions AnyDVD HD se connecte par Internet à un serveur Slysoft pour récupérer les clés AACS des derniers titres sortis.
Et je crois que cette connexion ne marche que pour un AnyDVD payé (pas en version trial donc)
Mais normalement une nouvelle version d'AnyDVD HD contient toutes les clés dispos à la date de sortie.
Enfin c'est ce que je crois avoir compris, mon PC étant connecté à Internet et ayant payé la licence je ne me pose pas trop la question.
- ph75
- Inscription Forum: 16 Juil 2006 13:18
bonsoir le bd+ va surement évoluer la technologie appartient a macrovision désormais. j'espère que anydvd pourra toujours suivre.
- XACTI HD2
Pastor,
Merci pour ton intervention, mais suite à plusieurs longues soirées passées devant l'ordi à trouver une solution j'ai jetter l'éponge. En creusant un peu à gauche et à droite, on trouve beaucoup de choses, et je me rends compte que les formats HD-DVD et BR sont quand même complexe, et au final vu la taille des médias utilisés, nous ne sommes pas prêts de faire des "copies de sauvegarde" à la maison.
Conclusion: plutôt investir son temps à choisir les films, lire des reviews, les acheter, et les voir sur grand écran en FullHD, que de se prendre la tête avec des codecs
- ohmax
[Modéré par guyome : d'après la loi DADVSI, il est interdit de ripper DVD/HD-DVD/BD, que vous possédiez l'original ou non.
Cordialement,
Guillaume, Staff Multimédia]
Cordialement,
- CHRISTOPHE K
- Inscription Forum: 04 Juil 2004 12:34
