Je pense que tu fais référence a cela quand tu m'as dit que cela n'était pas bon chez moi.
I've installed the new nVidia driver 430.39. It is now once again allowing madVR to switch HDR mode. It has also rectified the long lingering audio problem - Multi channel vs stereo auto switch dependent on AVR state on and off.
As expected, nVidia no longer supports 3D. It has been completely removed from the driver install. So far I have installed 3D vision from an older driver. I get a notice that 3D vision does not match the new graphics driver after installing it. I also ran the 3D .reg file in madVR. The 3D option no longer shows up in Windows display properties or NCP. I did attempt to play a 3DMVC.iso in PowerDVD. 3D mode does not engage. I also tried MPC-BE. It displays some strange SBS and then does engage 3D mode. This is a frame packed MVC iso. It shouldn't go into SBS mode imo.
I don't want to spend anymore time fussing with this new driver and I will be reverting back to 416.81 video drivers. Instead of editing those drivers and applying the 388.59 audio driver (bug free) as I've been doing in the past, I will be attempting to use the newer 430.39 audio driver which at this time appears to also be bug free. This combo will update me to the newest working audio and video drivers that meet my demands.
*edit*
The audio bug still exists using the 430.39 driver. It doesn't survive a reboot. I will be using 388.59 audio driver with 416.81 video driver as usual.
Je suis d'accord. c'est troublant...
Et pourtant , je trouve vraiment une différence flagrante de qualité et une absence de flou 3D sur les mouvements entre un film codé SBS et un 3D MVC que je vois en SBS avant activation de la 3D sur le VP.
Par contre, y a quand meme des effets de ghosting parfois sur qq plans clairs mais c'est lié a la techno 3D.
A l'occasion, je vais tenter de revenir a un ancien driver vu que de toute facon avec ma GTX1080, je ne suis pas touché par les problemes qui existaient en HDR 10 bits.
Après... la 3D, c'est finit et on n'aura plus d'autres sources a se mettre sous la dent donc ca ne sert pas a grand chose. c'est bien dommage dalleurs meme si je regarde quand meme de préférence la version 2D a la version 3D (sauf pour les animés où pour moi, la 3D c'est un must tellement c'est bien sur grand écran VP ==> par contre, sur TV, je passe mon tour...)
