Vu dans le dernier CCS aux alentours de 1500€:
http://www.atlantictechnology.com/system_P-2000.htm
preamp 7.1 avec tout ce qui faut dedans (DD EX DTS ES, DPL II...)
A ce prix ca peut valoir le coup de jeter un oeil....
Qq infos
P
Bass Management
High-Pass Slope Crossover Frequency
(Small Speaker Setting) (Adjustable 40/60/80/100/120/150Hz)
12 dB/octave (2nd order)
Low-Pass Slope: (Subwoofer) 24 dB/octave (4th order), 40-150Hz as above
Tone Control
Bass Center Frequency/Range 30Hz / ± 6dB
Treble Center Frequency/Range 10KHz / ± 6db
Channel Separation: (at 1kHz) 82dB
Crosstalk Between Inputs: (at 1kHz) 86dB
Preamplifier Digital Section
Frequency Response
Direct Inputs: 10 Hz to 20 kHz +0 / -0.2 dB
Analog-DSP Inputs: 10 Hz to 20 kHz +0 / -0.5 dB
Digital Inputs: 10 Hz to 20 kHz +0 / -0.4 dB
THD+N (at Rated Input & Output) 6-Channel Direct Inputs: 0.0035% (80 kHz BW)
Analog-Direct Inputs 0.0035% (AES17 filter) Analog-DSP Inputs: 0.005% (AES17 filter)
Digital Inputs: 0.006% (80 kHz BW)
IMD (CCIF) @ 15 kHz & 16 kHz: 6-Channel S/E Inputs: 0.003% All Other Analog Inputs 0.002%
Digital Inputs: 0.005%
S/N Ratio: (ref. 2.0Vrms A-weighted) All Direct Inputs:102dB Analog-DSP Inputs: 99dB
Digital Inputs: 101 dB
AM/FM Tuner Section
Video Section
Bandwidth
Composite & S-Video: 6 MHz -3dB
Component Green 50MHz -3dB
Component Red 50MHz -3dB
Component Blue 50MHz -3dB
All video inputs and outputs are 75 ohms, 1.5 Vp-p. Component inputs and outputs work with any Standard requiring ultra-wide bandwidth including Component-RGB, HDTV, line doublers, quadruplers, and scalers.
Digital Audio
All digital audio inputs and outputs are to S/PDIF electrical (75 ohms, 0.5 Vp-p),
S/PDIF optical (Toslink), or AES / EBU (110 ohms, 5 Vp-p) standards as appropriate.
Processor: Crystal CS49326
Audio Converters
Digital Audio Inputs: CS8415A Digital Audio Interface up to 96kHz
Analog to Digital: CS5360 up to 24-bit/48kHz
Digital to Analog: CS4396 up to 24-bit/192kHz
Dimensions
Width 17.12 inches / 435 mm
Height 4.6 inches / 117 mm
Depth 14.76 inches / 375 mm
Weight 17.6 lbs. / 8 kg
Trigger Outputs 1, 2(Zone) Sequential Delay 50 mA @ 12 VDC
14 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: d2r2.off, Google Adsense [Bot], manolo57420, misteurz, moglo, MUS1156, Salvador Hard-on, zalem, zarkka et 226 invités
Un nouveau preamp "abordable" Atlantic Tech P2000
- pedro
- Inscription Forum: 08 Déc 1999 2:00
c'est le Sherbourn PT 7000
http://www.sherbourn.com/products/PT-7000.php
- Damned
- Inscription Forum: 03 Nov 2000 2:00
Pour ceux qui ont encore la NRDS de septembre, il etais en test..
(moi je ne l'ai plus, je les balancer... )
- the thing
- Inscription Forum: 04 Oct 2003 23:49
c'est intéressant ça ...
Dans les 1500€ ça devient intéressant avec une alim thoroïdale en plus ...
Sherbourn n'est pas connu pour faire de mauvais produits, donc c'est à suivre !!!
a+
Stéphan
a+
Stéphan
Before trying to improve I.A, we should better fix the natural stupidity
- deuch
- Inscription Forum: 08 Mai 2000 2:00
J'ai encore la nrds de septembre et le préamp P-2000 est donné (si on peut dire ça ) pour un prix indicatif de 2600€
- Caplam
- Inscription Forum: 02 Fév 2003 11:29
S@lut à tous ! !
Ils sont 3 clônes :
=> Atlantic Technology
=> Sherbourn
et
.........??? Je ne me rappelle plus le dernier ! !
En gros, les critiques de l'époque => pas terrible ne Hifi ! !
Olivier.
Ils sont 3 clônes :
=> Sherbourn
et
Olivier.
OO7livier - Modération Home-Cinema & Rencontres
- Inscription Forum: 21 Nov 2002 14:32
Pahlawan a écrit:S@.........??? Je ne me rappelle plus le dernier ! !
Le dernier c'est le design original, ceux qui ont conçu la bête et cédé ensuite la licence de production, il s'agit de l'Outlaw Model 950.
- ajds
- Inscription Forum: 02 Fév 2000 2:00
Bien joué ! !
J'étais en train de rechercher pourt compléter ma réponse ! !
très intéressant.
personne n'a testé?
très intéressant.
personne n'a testé?
- Three-Eyes
- Inscription Forum: 02 Juil 2001 2:00
A noter, le dernier test d'un des clones, le Sherbourn PT-7000 qui se fait totalement détruire dans la revue anglaise homecinemachoice.
http://www.homecinemachoice.com/frame.h ... iewid=3344
Je savais que les anglais n'ont pas la langue dans leur poche mais la, ils font forts quand même !
Au niveau du son, il obtiens une note globale inférieure au couple rotel rsp-1066+Rmb-1095 (3.5 étoiles pour le sherbourn, 4.5 étoiles pour le rotel).
Ils disent que le pre-pro est largement inférieur à la section pré d'un Pio AX10 et que ca vaut à peine la section de décodage d'un intégré de milieu de gamme.
Mortel le test !
Mortel le test !
- ajds
Bsr,
... et 5 étoiles pour le Pioneer AX10.
Mais puisqu'on est dans le domaine des "nouveaux" ou "futurs" processeurs, je pense que le prochaine millésime du AX10 risque d'être particulièrement novateur avec la fonction d'analyse, prise en compte et correction des réflexions de la pièce d'écoute...
Quelle machine aurait-on là si à cela pouvaient être adjoints les 7*200W "numériques" du Sony 9000.
En 2005 peut-être?
Hugo
En 2005 peut-être?
Hugo
- Hugo S
- Membre d'Honneur - Président de l'Association & Relations PROs
- Inscription Forum: 04 Mai 2000 2:00
Pourtant encencé dans CCS... Les testeurs n'ont pas les mêmes oreilles apparement.
Une telle critique a de quoi refroidir cependant.
- Three-Eyes
Et d'ailleurs si l'on regarde certaines marques largement encensées sur ce forum (teac 3500, sherwood...) bonjour la claque sur HC Choice.
Quant aux autres produits pour lesquels les pros de la feuille font la fine bouche, ils obtiennent des notes généralement de bon niveau (cf . les Denon séries 2 et 3).
Vraiment étonnant....
raison de plus pour n'écouter que ses propres oreilles.
- ShZ
- Inscription Forum: 11 Déc 2002 22:22
Bsr,
... ou acheter un boîte de coton tiges (pour BB, les meilleurs) à certains "testeurs" bien de chez nous.
Hugo
ShZ a écrit:...
Hugo
- Hugo S
14 messages
