Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: misteurz et 20 invités
1536
Message » 12 Avr 2003 9:15
Angelus a écrit:Bonsoir à tous!
Bon, j'ai une question vitale à vous poser concernant le DTS :
pourquoi est ce que cohabitent (sur le net) deux couples de valeurs différents quand on parle de DTS ,à savoir :
- Mi-débit: 754 kbps ET 768 kbps
- Plein débit: 1509 kbps ET 1536 kbps
D'après ce que j'ai lu sur le site de DTS, le DTS a donc un debit de 1509 kbit/s (ça on savait), et c'est le DTS 96/24 qui a un debit de 1536 kbit/s.
DTS (FAQ) a écrit:9. How Does 96/24 Work?
The DTS coding system has a “core + extension” structure. The “core” represents the DTS data as has been known since the first home decoders. The “extension” can carry data for future applications or enhancements of any sort. All DTS decoders recognize and use the core data. Basic decoders ignore the extension data, while advanced decoders can make use of it. This allows for full backward compatibility for any scheme using the extension. DTS has recently used the extension field for two purposes. In the first case, it has been used to carry an additional channel for 6.1 dis-crete. In the second case, the extension field carries the additional spectral data added by 96-kHz sampling. For a program in DTS 96/24, existing decoders read the core at 48-kHz and reproduce the standard spectrum. DTS 96/24 decoders read both core and extension and reproduce the extended spectrum. The data rate for 96/24 is 1.536Mbit/s, the higher of the two DTS rates presently used. While numerically this might suggest twice as much compression, there is in fact negligible additional compres-sion on the core data. This is because there is relatively little information in the range 24-48kHz, so it can be coded very compactly. The 96/24 stream passes through the S/PDIF just as standard DTS does.
Voir la FAQ DTS
C'est peut-être aussi la même différence qu'il y a donc entre le 754 kbit/s (DTS mi-débit) ET 768 kbit/s (DTS96/24 mi-débit) ?
Laurent Image
Laurent B.
Inscription Forum: 13 Mai 2001 2:00
Message » 12 Avr 2003 17:58
:o
Pourquoi pas mais alors comment explique tu que sur un Encodeur DTS classique, autrement dit en 48kHz, le bit rate est donné à 1536kbps?! :-? Ya un hic
Sur une doc DTS j'avais clairement lu que le DTS24/96 avait un bit rate conjugué et le total dépassait les 2Mbps ... je vais essayer de remettre la main sur cette doc pdf...
DTSman
Contributeur HCFR 2022
Message » 12 Avr 2003 18:07
DTSman a écrit::o
Ca veut simplement dire que la partie du flux DTS natif inclue dans un flux DTS 96/24 est plus compressée que sur un DTS simple plein débit.
C'est d'ailleurs l'un des principaux arguments des détracteurs de ce nouveau format qui disent que la partie réellement utile du spectre audio (de 20 à 22 Khz ) est sacrifiée au profit d'une bande de fréquence (de 22 à 44) considérée comme beaucoup moins importante.
ajds
Inscription Forum: 02 Fév 2000 2:00
Message » 29 Avr 2003 22:11
Merci pour vos posts
Donc je resume, les ampli qui decode le nouveau codec DTS :
Le DTS 24/96
(bande-son surround 5.1 encodée sous 24 Bits et à la fréquence d'échantillonnage de 96 Khz)
Pioneer 2011
Pioneer Ax-10
Marantz SR7300
Marantz SR8300
Marantz SR9300
Yamaha DSP-AZ2
Yamaha DSPAZ1
Onkyo TX-DS989 Ver. 2
Onkyo TX-NR900
Onkyo TX-NR800
Denon AVC-A1SE version upgradée
Denon AVC-A1SR
Denon AVC-A11SR
Denon 3803
SONY STR-DB1080QS
STR-VA333ES
Et titre dans ce format :
Queen
picatchum92
Inscription Forum: 13 Mar 2003 2:00
Message » 08 Mai 2003 16:32
uuupppppppppshummm :lol:
picatchum92
Message » 08 Mai 2003 16:40
il *devait* y'avoir un DVD en DTS 24/96 de prokoviev (pas sur de l'ortho) de pierre et le loup ou on avait meme des pistes ou on pouvait isoler les differents pupitres de l'orchestre
je sais pas ce que c'est devenu... reponse dans la semaine peut etre :)
Babook
Inscription Forum: 27 Mai 2002 22:11
Localisation: Paris, la ville entre St Ouen et Ivry s/ Seine
Message » 08 Mai 2003 16:47
Je commence à douter de plus en plus sérieusement de l'avenir de ce format : aujourd'hui quasiment tous les intégrés et préamps moyen/haut de gamme sont équipés de décodeurs et les titres disponibles se comptent toujour sur les doigts de la main.
Par ailleurs, a bien y réfléchir l'argument des détracteurs du format me semble tout à fait valable : compresser plus fortement la bande utile pour faire de la place à la bande étendue semble plutôt une mauvaise chose.
ajds
Message » 08 Mai 2003 21:08
ajds a écrit:Je commence à douter de plus en plus sérieusement de l'avenir de ce format : aujourd'hui quasiment tous les intégrés et préamps moyen/haut de gamme sont équipés de décodeurs et les titres disponibles se comptent toujour sur les doigts de la main.
Oui, c'est vraiment étrange cette histoire. Pourquoi n'y a t'il pas plus de titres alors que les décodeurs commencent à être intégrés partout ?
Peut-être que c'est l'encodeur qui coûte cher à l'achat ?
Laurent Image
Laurent B.
Message » 08 Mai 2003 21:58
Sur un DVD Video, l'emploi d'une piste DTS 24/96 laissera encore moins de place pour la video. Sachant que cette dernière est parfois limite, mieux vaut ne pas trop tirer la qualité vers le bas. De plus les éditeurs préferent mettre une piste DTS ES plutot que DTS 24/96.
Le DTS 24/96 aura peut être plus d'avenir sur le DVD-A mais là aussi cela a du mal à décoller.
DTSman
Message » 08 Mai 2003 22:22
picatchum92 a écrit:Merci pour vos posts
Le DTS 24/96
Pioneer 2011
Pioneer Ax-10
Marantz SR7300
Marantz SR8300
Marantz SR9300
Yamaha DSP-AZ2
Yamaha DSPAZ1
Onkyo TX-NR900
Onkyo TX-NR800
Denon AVC-A1SR
Denon AVC-A11SR
Denon 3803
SONY STR-DB1080QS
STR-VA333ES
Queen
d'aprés le site marantz, dts 24/96 pour le sr 6300 aussi
mac gregor
Inscription Forum: 10 Fév 2003 17:15
Message » 08 Mai 2003 23:48
DTSman a écrit:Le DTS 24/96 aura peut être plus d'avenir sur le DVD-A mais là aussi cela a du mal à décoller.
ben le pb sur le DVD-A c'est que c'est DTS 24/96 contre un format sans pertes MLP : le choix est vite fait.
ajds
Message » 09 Mai 2003 10:30
c'est pas une question de place sur les DVDs videos puisque la piste 24/96 prend pas bcp plus de place qu'un dts plein debit
non
c'est juste qu'au cinema, toute la postprod se fait en 48 khz (bah ouais, les grosses SSL Avant et Neve DFC c'est du 48 khz) donc pkoi faire une conversion vers 96khz pour le DVD ?
Babook
Quelle connexion pour 24/96 ?
Message » 17 Jan 2004 1:21
bonjour
les connexion digital permetent'elles le debit d'un dvd 24/96 ?
Il me semblait que ces connexions classique digital optique ou coxial ne permetait pas un tel debit ?
Cela est'il vrai ?
Merci a +
le.fabiolo
Inscription Forum: 14 Aoû 2002 11:20
Message » 17 Jan 2004 2:21
Par les sorties numériques peuvent transiter le DTS 24/96 et du PCM 24/96 en stereo uniquement.
DTSman
Message » 17 Jan 2004 18:59
coool effectivement
je ne men repellais plus quand j'ai fait un test avec un dvd 24/94 mon lecteur dvd classique pionner 525 le voyant 24/96 c'était allumer !!!
C'était d'ailleur la seul fois que je l'ai vue !!!!
Exit'il beaucoup de titre 24/96 ?
Merci dstman de l'info car j'attend mon marantz SR9300 pour la semaine prochaine !!
:D :D :D
a+ fab
le.fabiolo
