Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: pehun et 6 invités
Les Processeurs Vidéo (Scaler, Désentrelaceur, Enhancer) et tous les appareils traitant l'image (y compris les ampli HC)
Scaler DVDO IScan VP50 firm 1.06(lien 1ere page)
Message » 19 Aoû 2006 20:17
lien pour le 1.06
http://www.anchorbaytech.com/support/so ... t.1.06.php
Edit
néon
Ca y est ! DVDO lance enfin son premier scaler capable de traiter correctement les signaux HD !
C'est le VP50 et les specs sont les suivantes :
Josh de DVDO - extrait de avsforum a écrit:The iScan™ VP50 is a high-definition video processor and A/V hub that converts standard or high definition from your HD-DVD player, Blu-ray Disc player, HD-DVR, game console, or PC to any output resolution between VGA and 1080p, including popular HDTV resolutions such as 720p and 1080i.
•VRS Precision Deinterlacing™ technology by ABT – 480i/576i/1080i Motion, Edge & Source Adaptive Deinterlacer
o Five-field motion adaptive deinterlacing
o Edge adaptive processing to produce smooth diagonal edges
o Three frame video processing delay (Max)
o Game Modes with very low latency (sub-1 frame delay/2 frame delay with Edge adaptive processing)
• Arbitrary cadence detection (any:any) to detect non-standard cadences in input signals.
o Reliable 2:2 pull-down detection for 50Hz countries
o Detection of 2:2 to/from 3:2 crossfades and out of phase 3:2 crossfades
o Detection of multiple source types within a frame for example video titles over film
o Bad edit detection and compensation to minimize artifacts caused by sequence breaks in film content
•VRS Precision Video Scaling II™ technology by ABT - 10-bit Scaling with Enhanced Sharpness Control
•ABT’s Precision Gamma Correction™ - Individual R/G/B Adjustments
•ABT’s Precision A/V Lipsync™ - Intelligent digital audio delay technology to match Audio and Video timing
•ABT’s Rightrate™ – High-Performance Framerate Conversion
•ABT’s AutoVFR™ – Intelligent Component Video Inputs with Automatic Video Format Routing
•ABT’s AutoCUE-C™ – Automatic Chroma Upsampling Error detection and correction
• 4 HDMI Inputs which process up to 1080p-50/60 signals
• Pass Through (up to 1080p-60)
• Analog HD Transcoding and Processing
Input Aspect Ratio Controls
•Presets: 4:3 full frame, 4:3 letterbox, Panorama, 16:9 full frame or user-defined aspect ratio (10)
•Flexible Horizontal and Vertical Zooming & Panning controls
•Overscan Adjustment per input
Output Aspect Ratio Controls
•Presets: 4:3, 16:9, 2.35:1 or custom output aspect ratio
•Separate Display/Screen Adjustments
•Underscan Adjustment to eliminate Overscan inherent in a display
10 User-Defined 'Display Profiles' – For multiple display, framerate, and image shift configurations (10)
•10-bit 300MHz Instrumentation Quality DACs (2x Oversampling for 1080p)
•Full-frame Timebase Correction
•High performance, multi-standard video decoder (10-bit: 480i/576i; 12-bit: 480p/576p/720p/1080i)
•High-quality super-adaptive comb filter with 2D Y/C separation
•Flexible Digital and Analog Audio switching and routing – 4 HDMI audio/video inputs, 5 assignable audio inputs (4 digital, 1 analog) with 1 HDMI audio/video output and 2 active digital audio outputs.
•Software Upgradeable
• Predefined output resolutions for Plasma, DLP, LCD, LCOS, and CRT-based displays:
480p (720x480)
576p (720x576)
720p (1280x720)
1080i (1920x1080)
1080p (1920x1080)
VGA (640x480)
SVGA (800x600)
XGA (1024x768)
SXGA (1280x1024)
848x600
852x480
1024x576
1024x1024 (ALIS)
1280x768
1280x960
1365x1024
1366x768
1400x788
1400x1050
1440x960
1440x1152
• User customizeable output resolution from 480p (720x480) to 1080p (1920x1080)
Technical Specifications
Inputs
Twelve Video Inputs Available
• Two Composite (NTSC/PAL/SECAM)
• Two S-Video (NTSC/PAL/SECAM)
• Two Component (YPbPr or RGB/S) processes 480i/p, 576i/p, 720p, 1080i
• One RGBHV/Component (BNC-style connectors) processes 480p, 576p, 720p, 1080i, VGA/SVGA/XGA/SXGA@60Hz
• Four HDMI processes 480i/p, 576 i/p, 720p, 1080i, 1080p, VGA/SVGA/XGA/SXGA@60Hz
• One Optional SD-SDI (Serial Digital Interface) processes 480i/576i
Nine Audio Inputs
• Four HDMI
• Two Coaxial Digital
• Two Optical Digital
• One Analog Pair (L/R)
Outputs
One Analog Video Output
• Using High Quality BNC-style connectors
• Configurable for YPbPr, RGBHV, RGB/S, or RGB
One Digital Audio/Video Output
• Using HDMI (High Definition Multimedia Interface) connector
• Configurable for YCbCr or RGB
• Also carries audio
Two Digital Audio Outputs
• One Coaxial Digital
• One Optical Digital
Controls
Front Panel
• Infrared remote control with direct access codes or manual controls on front panel
• Functions accessible via either On Screen Display (OSD) or 2 line, 20 character front-panel LED display
• RS232 port for software downloads and automation.
• Fully programmable controls for each separate video input with non-volatile memories:
- Automatic input source detection & input priority selection
- Picture controls with memory for each input: Brightness, Contrast, Saturation, Hue, Y/C Delay, Sharpness
• Output Controls: Analog/Digital, Format/Resolution, Aspect Ratio, Sync Type, Colorspace (RGB or YPbPr),
Frame Lock, Display Profiles (10)
• 35 Built-in test patterns for ease of set up
Miscellaneous
• Rack Mount Kit included (1RU)
Power
• Universal AC mains input: 100 – 240 VAC @ 50-60 Hz
• Consumption <30W
• Sleep Mode – automatic 30 second timeout indicated by power indicator color change
Physical Dimensions
• 10.4”x17”x2.2” (26.3cmx43.4cmx5.5cm) with feet
• 10.4”x17”x1.8” (26.3cmx43.4cmx4.6cm) without feet
Available Accessories
• SD-SDI Input Module
• Silver Front Bezel
FAQs:
Q: What are these new 'Game Modes' ?
A: These modes can reduce the amount of video delay to less than a single frame. In many competitive processors the effects of applying complex algorithms to the video image results in upwards of a seven frame delay. This can inhibit the real-time performance for gamers who want instantaneous response to react to stimuli and to realize peak performance from their application. The VRS Precision Deinterlacing™ Game Modes will reduce frame delay down to slightly less than one frame of video.
Q: What comes on the DVD that ships VP50?
A: The DVD that comes with the VP50 includes many test patterns to assist the you in optimizing the setup and to evaluate the performance of your iScan VP50 (or any other video processing). This DVD was produced by Stacey Spears and Don Munsil (S&M) and I strongly believe that this will be the Reference DVD that everyone uses to compare video processing from now on.
The Static Patterns include:
Picture Controls (Brightness/Contrast, Color/Tint, Y/C Delay, and Resolution)
Geometry (Frame Geometry, Image Cropping, Cross Hatch - Coarse, Cross Hatch - Fine, and Focus)
Gray Scale (10IRE - 100IRE Windows and Gray Ramp)
Half Patterns (Black/White, Color 7 Bars 75, Color (7) Bars 100, Color (8) Bars 75 and Color (8) Bars 100 - These are the 'other half' of the test patterns which are built into the iScan VP50)
The Motion Patterns include:
Chroma Upsampling (ICP, 2-2, and 2-3)
Source Adaptive (Film, Film Detail, and Synthetic Wedge - Each test patterns has 2-2, 2-2-2-4, 2-3-2-3, 2-3-3-2-2, 2-3-3-2, 3-2-3-2-2, 3-3, 4-4, 5-5, 6-4, 8-7-8-7 cadences as well as a sped up cadence and bad-edits)
Edge Adaptive (Jaggies at 45/20/10 degress, Jaggies at all degrees, Video sequences which have very difficult diagonals: 'Ropes', "Ship' , 'Hockey', and Bridge')
Mixed Mode (Horizontal Text and Vertical Text)
Montage
There is also a Demo Loop which goes through all of the deinterlacing evaluation content.
The Source Adaptive 'Film' and 'Film Detail' content should be familiar to everyone, they are the infamous Cafe scene (ever wonder what happens after the bum gets the newspaper?) and Super Speedway, respectively.
Q: Can I purchase an iScan VP50 with the SDI input module installed.
A: At this point, this card is purely a user/dealer-installable upgrades. Both are very easy to do and the installation of either will not void your warranty.
Q: Does the iScan VP50 use the same SDI input module as the iScan HD, HD+, VP20 and VP30?
A: Yes, the iScan VP50 uses exactly the same input module.
Q: Can the iScan VP50 take an HDMI input signal and output that same signal over the analog outputs?
A: If the input signal has HDCP (High-bandwidth Digital Content Protection) legally we must turn off the analog outputs. If the input signal does not have HDCP, then the iScan VP50 CAN output this signal as an analog signal (either RGB or component) at any resolution between VGA and 1080p.
Q: What features does the VP50 have, which the iScan VP20/VP30 do not have?
A: • Precision Video Deinterlacing™ by ABT for SD (480i/576i) and HD (1080i)
VP20/VP30 use the SiI504 for SD deinterlacing and both are upgradeable to the ABT102 (Precision Deinterlacing Card).
•HDMI Inputs can process up to 1080p
VP20/VP30 can process up to 720p/1080i
There will be more features/differentiators added to this list
Q: If I connect an HDMI (audio/video) source to the iScan VP50 will I be able to get audio out via the optical/coaxial digital outputs?
A: In most cases the audio that is available on the HDMI connection will be available on the optical/coaxial audio outputs. Exceptions include MLP (DVD-Audio) and DSD (SACD) which SPDIF connections are incapable of carrying due to bandwidth limitations.
Je vous traduis tout ça au plus vite ;-)
Déjà, les différences avec le VP30 actuellement disponible :
Josh a écrit:Q: What features does the VP50 have, which the iScan VP20/VP30 do not have?
Le VP50 dispose de l'algorithme de désentrelacement de ABT (appelé Precision Video Deinterlacing et actuellement l'un des meilleurs pour la SD et disponible pour le VP20/VP30 en carte d'extension pour la SD seulement) pour la SD ET pour la HD (1080i).
Les entrées HDMI sont en mesure d'accepter un signal 1080p (idéal si on dispose d'un lecteur HD DVD ou BluRay en mesure de sortir directement le flux 1080p)
D'autres fonctionnalités et différentes viendront s'ajouter à cette liste dont :
- en premier lieu le réglage du gamma absent des VP30/VP20 :
Josh a écrit:ABT’s Precision Gamma Correction™ - Individual R/G/B Adjustments
- la mise à jour des algorithmes de traitement au travers de mises à jour logicielles :
site DVDO a écrit:Ability to update all processing algoriths through software updates
- la détection de cadences HD 24p et 25p (cf ci-dessous) :
site DVDO a écrit:Progressive Source Input Cadence Detection (Source-Locked Output without Deinterlacing)
Une autre différence par rapport au VP30/VP20. Il peut prendre un signal audio en provenance d'une entrée HDMI pour l'envoyer en coax ou optique. Le VP30/VP20 ne pouvait le faire QUE si le signal en entrée n'est pas HDCP (autant dire que c'est impossible car c'est généralement le cas).
Et le lien vers la page du DVDO VP50.
Que demander de plus :lol: :lol: :lol:
UPDATE :
en entrée HDMI, il ne sait prendre que du 1080i à 50/60hz ou du 1080p à 50/60hz. Par contre, voila ce qui est indiqué dans le manuel disponible sur le site DVDO :
manuel a écrit:
For 50Hz sources, if the original source material is progressive at 25Hz (uses 2:2 pulldown), the output
framerate can be source locked at 25Hz, 50Hz or 75Hz. The 25Hz setting outputs each original
25Hz frame, the 50Hz setting repeats each original 25Hz frame 2 times, and the 75Hz setting repeats
each of the original 25Hz frames 3 times. You can also set the output frame rate to a specific value
(unlocked mode).
For 60Hz sources, if the original source material is progressive at 24Hz (uses 3:2 pulldown), the output
frame can be source locked to 24Hz, 48Hz, 60Hz or 72Hz. The 24Hz setting outputs each original
24Hz frame, the 48Hz setting repeats each original 24Hz frame 2 times, while the 72Hz setting repeats
each frame 3 times. As with 50Hz sources, you can also set the output frame rate to a specific
value (unlocked mode).
Donc avec les HDDVD et les BluRay, il faudra sortir en 60hz entrelacé vers le VP50 (si comme "prévu" ils sont tous encodés en 24p) qui pourra ensuite retrouver le flux original 24p, voir le sortir en doublant ou triplant exactement chaque frame pour faire du 48hz ou du 72hz.
Richard.
Richard Lemesle
Inscription Forum: 26 Jan 2003 16:03
Message » 19 Aoû 2006 22:44
MSRP $2,999
Si l'importateur FVS fait comme a son habitude, ca signifirait un VP 50 a 3000€ en France et une marge de negociation pas enorme.
On s'eloigne un peu plus encore des tarifs plutot 'democratique' des processeur dvdo.
Mais avec le surcout de la carte ABT sur le VP30, c'etait quand meme previsible :(
shacard
Inscription Forum: 16 Oct 2000 2:00
Message » 28 Aoû 2006 15:26
Pour ceux qui veulent pre-commander un VP-50, le forum AVS fait une offre speciale :
http://www.dvdo.com/AVS
La semaine derniere, une bonus de 400$ etait retire du prix public du VP (2999$)
Cette semaine, c'est 300$ et ainsi de suite (100$ de moins chaque semaine)
Sauf qu'il faut rajouter 250$ de gestion internationale :evil:
Ca peut interressant pour ceux qui ont deja un scaler Dvdo ou eventuellement une autre marque puisque dvdo fait un echange+$$$.
(pour ceux qui ont un Crystalio II, je deconseille la manip car leur scaler est estime a ... 750$ :mdr: :lol: :mdr: )
Serge.
shacard
Message » 28 Aoû 2006 15:49
En tout cas, leur démarche a énormément de succès sur AVS !
Richard.
Richard Lemesle
Message » 28 Aoû 2006 16:14
Richard Lemesle a écrit:En tout cas, leur démarche a énormément de succès sur AVS !
Je les comprends ! Si j'etais sur place, avec la reprise de mon vaillant iscan pro, le VP 50 me reviendrait a 1700€ en l'ayant commande hier :o
Serge.
shacard
Message » 28 Aoû 2006 19:00
Et bien moi j'hésite vachement entre un VP50 + preamp + amp ou une conf intégrée : Denon AVC-A11XVA pour ne pas la citer.
Bien que VP50 + AVC-A11XVA soit envisageable mais j'ai l'impression que ça fait double emploi coté vidéo.
Boris
Inscription Forum: 16 Mai 2002 23:40
Message » 30 Aoû 2006 17:40
Boris a écrit:Et bien moi j'hésite vachement entre un VP50 + preamp + amp ou une conf intégrée : Denon AVC-A11XVA pour ne pas la citer.
tu n'auras jamais autant de réglages pour l'image sur un intégré.
c'est dtu veux fignoler et calibrer à l'aide d'un colorimètre le scaler s'impose.
iceman
Inscription Forum: 07 Avr 2002 2:00
Message » 31 Aoû 2006 15:45
Le VP50 sera bien plus performant niveau traitement video, plus flexible aussi.
Le 11XVA a pour avantage d'etre exc ellent niveau correction et EQ de la salle.
Je pense tres franchement que les fonction de scaling d'un prepro ou d'un integre HC c'est du bonus, leur fonction principale reste le traitement et le decodage audio.
jacko
Message » 31 Aoû 2006 18:26
jacko a écrit:Je pense tres franchement que les fonction de scaling d'un prepro ou d'un integre HC c'est du bonus, leur fonction principale reste le traitement et le decodage audio.
Sur un point purement business, je pense tout à fait le contraire.
Historiquement, les preamp ou intégré AV étaient essentiellement utilisés avec des téléviseurs cathodiques et les fonctionnalités video n'était pas un avantage concurrentiel.
Aujourd'hui avec l'arrivée massive de diffuseur HD ready ou full, cette fonctionnalité devient vraiment un atout décisif dans le choix.
Il y aura toujours des puristes pour avoir un equipement dédié à chaque fonction.
Mais le marché de volume n'est pas là et la demande des utilisateurs se tourne de plus en plus sur les fonctions audio ET video.
Boris
Message » 31 Aoû 2006 18:49
En ce qui me concerne, je suis du même avis que jacko et surtout je ne pense pas que l'on puisse parler de marcher de volume avec le VP50 et encore moins avec le AVC-A11XVA.
Richard.
Richard Lemesle
Message » 31 Aoû 2006 20:25
Vu les dif de perfs entre un vrai scaler et ce que les integres proposent me dire que du denon fait du 1080p via VXP pour moi c'est :
1 des depenses dans la puces pour rien vu comment elle est SOUS exploitee
2 du gros pipo marketing pour donner un avantage concurenciel mais pas d=forcement un avantage au consommateur.
Entre nous le forum sert justement a investir sans se faire dupe par les strategies "business" des constructeurs.
jacko
Message » 05 Sep 2006 2:45
juste une question : peut on envisager de sortir du PCM multicanal en optique ou en coax du VP50 avec en entree un HD-DVD ou blu-ray en HDMI. Je pose la question car je n ai pas d entree HDMI sur mon lexicon et le fait d avoir cette possibilite eviterait d avoir a utiliser les entrees 5.1 analogiques de mon ampli pour les nouveaux formats audio HD...
hifibuff
Inscription Forum: 15 Sep 2004 0:24
Message » 05 Sep 2006 6:53
hifibuff a écrit:juste une question : peut on envisager de sortir du PCM multicanal en optique ou en coax du VP50 avec en entree un HD-DVD ou blu-ray en HDMI. Je pose la question car je n ai pas d entree HDMI sur mon lexicon et le fait d avoir cette possibilite eviterait d avoir a utiliser les entrees 5.1 analogiques de mon ampli pour les nouveaux formats audio HD...
Je ne pense pas car pour une sombre histoire de protection ces formats ne seront à priori pas disponibles en natif sur des sorties standards spdif ou coax. C'est comme le flux du SACD qui n'est disponible que sur le ilink actuellement.
iceman
Message » 05 Sep 2006 12:24
Non l'oppo 970h délivre le SACD sur le HDMI en PCM... très bien bour un D2 par exemple ;) (reste plus qu'à envoyer le cheque en CAD dès que je l'aurais reçu)
poup
Inscription Forum: 05 Jan 2005 12:58
Message » 05 Sep 2006 17:28
oui sur une HDMI on peut avoir ces flux
Mais en optique ou coax j'en suis moins sur
si un spécialiste des protections merdeuses passe par là
merci pour son avis
iceman
Retourner vers Processeurs Vidéo
