mako a écrit:Quelqu'un pourait il me donner la marche à suivre pour dézoner ce lecteur sur sa partie dvd ?
bon voila Noël avant l'heure code de dé zonage pour la partie dvd How to set RF for 8004 and 9004 DVD part?
1. Press together “STOP” and “PAUSE” buttons of main unit.
2. During pressing these buttons, insert AC power plug to the rear panel.
(Check!)
The unit power will be “ON” automatically (“STAND-BY” will be skipped)
As well as normal mode, unit FL display shows
“BrandName” “DISC MODE” “Please wait…”,
after that the FL display shows “NO DISC”
3. Open the disc tray by “OPEN” key on the unit.
4. By 10 keys of remote hand set, press these numeric keys.
7 3 1 9 4 6 2 8
(check)
After the setting is done and around 5 second later, the disc tray will close automatically
Then it sooner becomes to “STAND BY” mode automatically
Finished!
How to confirm the setting?
1. Turn on the power of unit as well as normal usage
2. Press 3 buttons “STOP”, “SOUND MODE”, “OPEN” (of the unit) together few second
(“SOUND MODE” button is located inside of Hidden panel)
3. Confirm the FL display. It must be showed “ B A 2 “
Tip: if you try this confirmation mode as normal setting, the FL display shows just “B 2”.
Confirm the letter of “A” before “2”. It means “ALL”
How to cancel (release) this setting? (to back default setting)
There are two ways
1. Use “Initialize” of “SET UP” menu in the OSD (refer the user guide)
2. Use hidden key combination command.
3. Press 3 buttons on the unit together few second “PLAY”, “SOUND MODE”, “OPEN”
4. FL display shows “INITIALIZING” after few second, it will show “INITIALIZED
