Je suppose que non, ce serait trop simple et j'en aurais entendu parler mais je préfère demander.
Je n'ai pas la possibilité de faire le test pour l'instant.
Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 14 invités
There will be no support for alternative filesystems such as NTFS, exFAT or ext2/3.
This release is for the OPPO BDP-103 and BDP-105 Blu-ray Disc players.
Special Notice:
Once this firmware version is installed on the player, you will not be able to revert back to any previous official or public beta firmware. There will be no problem upgrading to any future official or beta firmware release.
Due to the extensive changes in this major firmware update, it is required that the user performs a "Reset Factory Defaults" operation after the firmware is installed. Please write down your special settings before doing this, and remember to re-apply your settings and adjust the proper volume level (if applicable) before you play any content. You may experience stability issues if this step is not performed.
This version is based on the latest Public Beta release version BDP10X-50-0323B. Comparing to the previous Official release version BDP10X-38-1220, the major changes included in this version are:
Added support for Direct Stream Digital (DSD) file playback from local storage. The DSD files can be either stereo or multi-channel. Both the DFF and the DSF formats are supported. (The channel mapping error reported in the beta firmware that affects PCM conversion of multi-channel DSD file has been corrected in this official release.)
Added support for CUE file playback. This function can be applied to music files on local storage and supported audio formats include FLAC, WAV, APE and MP3.
Added a feature that allows the creation of playlists while accessing music files from local USB storage. When navigating these music files, pressing the OPTION button will bring up a menu with a prompt to either "Add to playlist" or "Goto playlist". The created playlist file is stored within the local USB storage, inside "OPPO_Media_Info/playlist".
Added support for the AIFF audio format. (Standard AIFF files are supported. AIFF files with AIFF-C/sowt encoding generated by Mac OS X are not supported.)
Added support for the ExFAT file system.
21 messages
