lcdmen a écrit:The Ultra HD Alliance talks 4K, HDR and the future of television
https://www.avforums.com/article/ultra- ... sion.11916
Les pourparlers Ultra HD 4K Alliance, HDR et l'avenir de la télévision
https://translate.google.com/translate? ... t=&act=url
Merci !
C'est un soulagement que l'Ultra HD Alliance ne préconise pas un autre format HDR, ce que certains comme Technicolor le pensaient.
post178627553.html#p178627553
"Ultimately we’re trying to create a quality bar and not an underlying format."
So if somebody wants to use Dolby Vision and meets our quality criteria that’s great, or they want to use Technicolor or Philips Technology and it meets our quality bar that’s also great. If somebody else decides that HDR 10 is the right solution they can do that as long as they meet our brightness, contrast, colour gamut, bit depth and a couple of other parameters like tone mapping, if that’s all there then people can use whatever format they like to distribute content."
L'Ultra HD Alliance ne définit que des critères de qualité, plus précisément des mesures de qualité HDR.
Pour obtenir la certification Ultra HD Alliance, un TV UHD HDR, quelque ce soit son format HDR, doit se soumettre à des tests, qui mesurent entre autres le niveau (minimum) du "colour volume" (requis).
The criteria mainly are peak brightness, contrast, 10-bit depth and the colour gamut but if you combine these parameters you’re also basically addressing a much bigger concern which is called 'colour volume'.
http://www.dvinfo.net/article/misc/scie ... day-4.html
"We’re also representing the CEA, so we’re working with them and they’ve set a baseline standard for HDR but again not saying anything about a specific quality target, so we’re addressing that."
Le format HDR défini par la CEA (notamment capacité de recevoir et de traiter un signal vidéo HDR10, capacité de recevoir et de traiter les metadata définies par CEA-861.3 (d'où HDMI 2.0a)) ne spécifie pas les critères de qualité requis, qui sont pris en compte par l'Ultra HD Alliance.
Certifié HDR X = Spécifications HDR au niveau du protocole + critère de qualité
"Certifié HDR10" = Spécifications HDR de la CEA + critère de qualité = dalle 10 bits
post178635622.html#p178635622
Certifié HDR Ultra HD Alliance = Spécifications HDR de la CEA (pour le format HDR10) + critères de qualité définis par l'Ultra HD Alliance (minimum colour volume, ...)
Il reste une énorme incertitude pour le futur format HDR de télédiffusion.
"Yes and the way this started, we solved the easy problem first which was HDR for movies but I think the broadcast issue is a bigger issue and that’s step two."
Hollywood et la Blu-ray Disc Association ont décidé pour les formats HDR (HDR10, Dolby Vision, ...), basés sur la fonction de transfert PQ spécifiée dans le standard SMPTE 2084 (d'origine Dolby) ; mais Hanno Basse, CTO de Fox et président de l'Ultra HD Alliance, n'exclut pas que le futur format HDR de télédiffusion soit basé sur la fonction de transfert Hybrid Log-Gamma proposée par BBC & NHK.
"So for example we’re not really in that debate of which EOTF (Electro-Optical Transfer Function or, as it's otherwise known, gamma) is best, the BBC curve versus the PQ curve because for studios with movie content we made the decision a long time ago and the BDA as well that it’s going to be PQ. However personally I wouldn’t exclude there to be another function being adopted for broadcast for example and I don’t believe that we necessarily are the ones to make that decision.."
A mon avis, lorsque le futur format HDR de télédiffusion sera défini par les organismes de normalisation, la viabilité des formats HDR dont la post-production n'est pas en temps réel (HDR10, Dolby Vision, Philips HDR, Technicolor HDR), sera alors fixée.
Un pronostic sur les formats HDR qui survivront : HDR10 et Dolby Vision (Technicolor HDR étant plus effacé, Philips HDR étant en mode furtif)
. HDR10 : parce que c'est le format HDR obligatoire du Blu-ray UHD
. Dolby Vision :
.. parce qu'il est compatible HDR10 qui est sa couche de base : un TV Dolby Vision pourrait traiter le signal vidéo HDR10 de 10 bits, un TV HDR10 pourrait traiter le signal vidéo 10 bits de base d'un disque Dolby Vision de 12 bits
.. parce que c'est un format HDR optionnel du Blu-ray UHD
.. parce que c'est un format de 12 bits (le plus grand nombre de bits vidéo des formats HDR)
.. parce que son écosystème est le plus complet : beaucoup d'outils compatibles au niveau de la post-production (ce qui sont compatibles Dolby Vision sont aussi compatibles HDR10) ; beaucoup de puces vidéo SoC compatibles Dolby Vision & HDR10 ; tous les majors d'Hollywood ont sorti leurs films en Dolby Vision dans les salles de cinéma compatibles.
Pour le moment, les deux favoris pour le futur format HDR de télédiffusion sont Dolby Vision et BBC-NHK. Espérons que le gagnant sera Dolby Vision ou HDR10.
