Modérateurs: Modération Forum DIY, Modération Forum Installations, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: lionel83, Zbymar et 173 invités
UP-Grade
Message » 14 Fév 2020 13:00
pleindastuss a écrit:Thank you to share your 2 projects!
It might be a great satisfaction for Alex_twn and all the team who has worked on the UP and UP Grade to see that people still benefit of their production and share!
Very nice pictures. Hope it will sound great!
JPh
Indeed, I did not followed this topic for a while but congrats to all of you.
You now have to move to the UGS muse :wink:
Alex_twn
Inscription Forum: 10 Nov 2008 6:02
Message » 28 Fév 2020 0:02
gionag a écrit:For my own needs, i am redesigning the power supply unit.
keystone screw terminal for the AC in and active rectification (LT4320) for the power lines. tracks are a little bit wider too to accomodate a little bit more current.
A little bit wider, but same hole spacing for both hex-nuts anchors and diodes positions.
with this setup i hope to achieve a better integration in my build, a little bit higher voltages (expected drop ~30mV) and much cooler operation.
if anyone is interested, maybe we can arrange some sort of group buy.
Image Image
    50mm/22.5LS (M5-SCREW) main caps
    25mm/10LS (SNAP-IN) for the front-end
    LT4320 for active rectification
    ST STP130N6F7 as IDEAL-DIODES
Happy soldering ! :D
UP & Running.
Image Image
gionag
Inscription Forum: 20 Oct 2019 12:11
Message » 28 Fév 2020 10:05
great job as usual, i haven't had time to use my LT4320 yet
UltimateX86
Inscription Forum: 27 Oct 2002 21:13
Message » 29 Fév 2020 15:02
UltimateX86 a écrit:great job as usual, i haven't had time to use my LT4320 yet
thnks mate :D hope you will be back soon
gionag
Message » 23 Mar 2020 19:49
désolé mais je n'ai pas bien compris x remplacer ua7812 et mc7912, que dois-je mettre? quel modèle? Merci :siffle:
Bronto70
Inscription Forum: 11 Juil 2019 18:13
Message » 24 Mar 2020 18:33
Il faut les remplacer par les mêmes en boîtier TO220 (LM7812/7912) et les monter sur le radiateur pour mieux dissiper la chaleur.
Alex_twn
Message » 24 Mar 2020 19:09
Alex_twn a écrit:Il faut les remplacer par les mêmes en boîtier TO220 (LM7812/7912) et les monter sur le radiateur pour mieux dissiper la chaleur.
salut, dois-je utiliser lm7812 / lm7912? l7812 et l7912 sont faux ?? devez-vous également y insérer des condensateurs supplémentaires?
Bronto70
Message » 26 Mar 2020 1:44
LM7xxx ou L7xxx ça va fonctionner.
Et en effet ajouter condos sur les pins directement sinon risque d'oscillation.
Voir photos en première page.
Alex_twn
Message » 01 Avr 2020 13:57
Alex_twn a écrit:LM7xxx ou L7xxx ça va fonctionner.
salut, ici et comment dois-je monter ces condensateurs? Merci
:lol:
Bronto70
Message » 01 Avr 2020 14:06
je cherche pcb up; en avez-vous pour me vendre?
Bronto70
Message » 02 Avr 2020 11:06
bonjour Faame, j'envisage de faire votre version Up-Grade de UP, quelque chose n'est pas clair pour moi; x les régulateurs, dans ce que vous utilisez votre petit pcb, dervo ajouter les condensateurs sur les régulateurs et éliminer les smd sur le pcb ou comment pouvez-vous me demander? Merci
Bronto70
Message » 03 Avr 2020 3:56
:lol:
Je pensais avoir mis une photo mais apparemment non. C'est simple il suffit de mettre des capacités CMS entre pins, voire une petite charge sur la sortie pour tirer un peu de courant.
Alex_twn
Message » 03 Avr 2020 3:58
Bronto70 a écrit:je cherche pcb up; en avez-vous pour me vendre?
Il doit m'en rester quelques kits. Il te faut quoi exactement ?
Alex_twn
Message » 03 Avr 2020 13:07
pcb up n. 2 , n.2 pcb psu up-grade :)
Bronto70
Message » 16 Avr 2020 14:04
salut, quelqu'un peut-il m'aider avec des photos ou des dessins, sur la façon de connecter les condensateurs sur lm7912 et 7812? Merci
Bronto70
