Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: alexrs4, Anotherdaylight, Aussie, Bavuong, bazzzzzzzz, Bedouille69-CX-Denon, Bing [Bot], blopper, Calypso29, Coolos, cubitusmetz, eleanor, fastmanu, fiffou95, Fredo69, gege50, ggregg, groot57, Guichamp, Icaro, indebeul, infobm, jarod692001, jeankigrogne, jp_78, Kevin26, lcdmen, manax, manimal95, Manson79, Mark0x, Nicocoon, octodurus, passager57, patychard, philboun, Puppy75, Reivaxor, ro2v, sigfrid, Smooth Jazz, sportman, Teybb, totodede666, toubeau, WarC0zes, x0freeman0x, xplo, ymlik, ZOZOSLOREN et 206 invités
2019 - Panasonic GZ2000 OLED 4K HDR10+/DV 55/65 (màj)
Sans compter sur les produites pro HDG x0.000
Comme il n'y a pratiquement jamais d'occasion sur ce genre de produit il y a peu d'alternative.
je-debute/quelle-centrale-dans-un-salon-t30104836.html
Fafa - Administrateur Suppléant de l'Association - Secrétaire Adjoint & Superviseur Forum Univers TV
CALMAN BETA FOCUS AREAS
There are areas throughout the software that we would like you to test. Please see the list below for the specific features you should assess:
Bodner Method meter profiling option
Calman Ready AutoCal support for LG 2020 series TVs
Calman Ready AutoCal support for Panasonic 2020 HZ series TVs
Calman Ready AutoCal support for ASUS ProArt monitors
Support for IP based communication for Samsung 2019 series
TVsSupport for X-Rite i1Pro 3
Updated report printing to PDFIncremental save option to save a calibration in progress
MadVR LUT Integration
Et aussi
Jvc RS2100, Xtrem 1.1gen2, Lg 77g3, chambre 65s95b, sources: pana ub9000 +pchc+chinoppo+z1000pro,atv4k, XSX, PS5/ 3 Arendal monitor 1723S, 4 Divatech diva18, 6 Svs prime elevation atmos/ Denon Avc-a1h/ sub arendal 1723 1S
- david555
- Superviseur Forum Univers TV & Contributeur HCFR
- Inscription Forum: 02 Oct 2005 18:13
david555 a écrit:Calman 2020 bêta dispo, prise en charge de la i1 display pro plus.
Et aussi
reçu mail aussi .
Nouveautés assez sympa
faut un yeti par contre...
Par rapport à mes propos pour le WRGB ( nouveauté donc ) :
Trinnov Altitude 16,Trinnov Amplitude 16,Enceintes : Front b&w 803D4 , centrale b&w HTM2 D3 , Front wide : b&w 805D3 surround b&W 804D3 , Surround Back :Moniteur audio Apex 10 , ATMOS 6xSVS Prime Elevation,Lecteur Bluray : Pionneer Lx500
- Masterwarzombie
- Inscription Forum: 26 Déc 2012 21:13
- david555
david555 a écrit:Bien vu!
tu as vu faut bien mettre RAW XYZ au lieu de OLED pour diffuseur comme sur l'ancienne version
- Masterwarzombie
- Masterwarzombie
A vos sondes !
- Masterwarzombie
- squall049
- Inscription Forum: 27 Fév 2010 13:34
squall049 a écrit:vous me direz les différences wue vous observez, et si y'en a qui testeront avec la display pro Plus !
il semble que la display pro plus soit plus précise dans les " niveaux de noirs"
- Masterwarzombie
est-ce l'on peut utiliser la barre de son du GZ2000 comme voie centrale avec un préamplificateur home cinéma ?
- unicorn
- Inscription Forum: 21 Déc 2019 12:22
unicorn a écrit:Bonjour,
Toi , tu t'es trompé de sujet...
- JOJO54
- Inscription Forum: 11 Mai 2005 19:57
Et non (je l'indiquais dans le CR de HCFR), et c'est bien regrettable.
Fafa a écrit:unicorn a écrit:Bonjour,
merci Fafa pour ta réponse
- unicorn
theChild a écrit:theChild a écrit:
Je me réponds à moi-même, ayant trouver de nouvelles informations. Cela pourra sûrement servir à d'autres galériens...
Je suis tombé sur ce document :
https://www.rtings.com/tv/tests/inputs/5-1-surround-audio-passthrough
Qui explique en gros que c'est la jungle concernant le passthru HDMI ARC. Et que le passthru DTS n'est pas systématique, c'est une feature que le constructeur peut implémenter dans la TV ou pas.
Malheureusement, les Panasonic n'apparaissent pas sur le tableau, donc je ne peux rien prouver ici.
Et plutôt troublant, TOUTES les TV OLED qui ont été testé dans le tableau ont du passthru DTS via ARC. Toutes marques confondues. Vraiment intriguant...
Donc en gros, il manque le codec DTS sur toutes les TV Panasonic. On est tous d'accord là dessus.
Mais il manquerait également le "passthru DTS over HDMI ARC" sur la série GZ. Sûr à 99%.
J'ai contacté le SAV Panasonic - par mail, et par téléphone, pour tenter d'en avoir une confirmation officielle. Le SAV est bidon, probablement délocalisé au vu de l'accent, et se contente de copier coller la notice en étant hors sujet. Dialogue de sourd.
2 solutions :
- Racheter un ampli 4K HDR Dolby Vision et tout le bordel = 400€ environ
- Passer par un splitter HDMI = 40€
- (les adaptateurs optiques pour Shield ne peuvent faire passer que du 2.0 pour info !)*** Partie SPLITTER***
J'avais laissé la solution du splitter de côté, car j'avais lu ici et là que si l'un des 2 appareils en sortie n'était pas compatible 4K, alors le splitter ne pouvait pas balancer du 4K d'un côté et du 1080p de l'autre. Il se calait sur le maillon le plus faible des appareils en sortie.
Sauf que finalement, ce n'est pas aussi simple.
Là encore c'est la jungle dans les appellations : splitter, séparateur, répartiteur, commutateur, switch, switcher, distributeur. Entre les mauvaises traductions, et les fausses descriptions, il faut se méfier.
Mais à priori, il existerait des splitter "EDID", qui permettraient de dupliquer puis splitter le signal dans 2 sorties indépendantes avec des résolutions différentes.
Ce qui donnerait :
-----------------------------| HDMI OUT 1 - 4k@60 + Signal Audio 5.1 HD vers TV (pour l'image uniquement)
Shield ---> Splitter EDID |
-----------------------------| HDMI OUT 2 - 2K@60 + Signal Audio 5.1 HD vers AVR (pour l'audio uniquement)
Ce type d'appareil coûte entre 10€ et 50€. Souvent des marques chinoises proches du noname.
Ceux proches des 10€ sont 1080p. Ceux proches des 50€ sont 4K@60. Beaucoup de modèles 4K@30 dans la fourchette intermédiaire donc faites attention.
Par contre, pas de Dolby Vision sur 99% d'entre eux. Seule la marque HDFury en font, mais on est proche des 200€
La marque Portta semble sortir du lot.
Exemple :
48€ - Portta 4 Ports Splitter HDMI 4K avec EDID Répartiteur Séparateur HDMI 2.0 1x4 4K @ 60Hz HDR Chaleur Basse Cascadable Support HDCP 2.2 Full 3D Ultra HD 1080p LPCM for Roku 4, 4K TV, Amazon Fire TV
https://www.amazon.fr/Portta-Splitter-R%C3%A9partiteur-S%C3%A9parateur-Cascadable/dp/B07K316HB8/ref=sr_1_7?__mk_fr_FR=%C3%85M%C3%85%C5%BD%C3%95%C3%91&keywords=portta+splitter&qid=1579706774&s=electronics&sr=1-7
Si cela fonctionne, c'est LA solution la plus économique (si on accepte de perdre le Dolby Vision).
Il y a également des splitter avec fonction "Audio Extractor".
Cela sépare le signal HDMI entrant avec d'un côté l'image +son qui part vers un HDMI OUT, et de l'autre une sortie optique 5.1 qui contient uniquement le signal audio (non HD pour rappel via de l'optique).
Exemple :
60€ - Portta Switch HDMI Commutateur 4K@60Hz 4x1 avec Audio Extractor Toslink SPDIF Optique Coaxial Stereo & Arc, Commutateur HDMI Splitter 4 Entrées 1 Sortie avec Télécommande Soutien HDCP2.2 HDR 3D 4Kx2K
https://www.amazon.fr/Portta-Commutateur-Extractor-TOSDLINK-surround/dp/B075G9HH6F/ref=sr_1_5?__mk_fr_FR=%C3%85M%C3%85%C5%BD%C3%95%C3%91&keywords=portta+splitter&qid=1579706774&s=electronics&sr=1-5
J'ai également croisé celui ci compatible Dolby Vision (sur Amazon US) :
50€ (fdp in) - ViewHD Newest Ultra HD HDMI Audio Extractor Support 4K@60Hz, HDR, Dolby Vision | HDCP 2.2 | HDMI 2.0 | 18Gpbs | SUHD | Ultra HD | Model: VHD-UHAE
https://www.amazon.com/ViewHD-Newest-Extractor-Support-Vision/dp/B06XRT9VGL
Par contre, dans les commentaires, c'est indiqué que si la piste est en DTS-HD, aucun son ne sort via l'optique, alors que normalement, il devrait sortir en DTS downrez.*** Aparté sur le downrez ***
Il faut voir les signaux HD comme des poupées russes.
Le DTS HD - contient un core DTS.
Le Dolby True HD - contient un core AC3
Le Dolby Atmos - contient un core AC3
(En réalité, Dolby n'intègre pas toujours le core AC3 dans toutes les pistes TrueHD / Atmos) - je n'ai pas creusé ce sujet...
Un signal DTS HD contient toujours un core DTS, qui permet une rétro compatibilité, avec les appareils non audio HD.
Certains anglophones appellent cela le "downrez".
Donc si vous avez un film en .mkv avec piste DTS-HD, un lecteur DTS-HD type Nvidia Shield, une TV équipée d'un passthru DTS over ARC, connecté à un ampli (audio HD ou non - peu importe) :
La Shield envoie le DTS HD en Bitstream à la TV
La TV passthru le son vers la prise HDMI ARC
L'ARC downrez le DTS-HD en DTS
L'ARC envoi le DTS à l'ampli en Bitstream, qui affiche un joli DTS à l'arrivée !
Idem en optique, si optique capable de balancer du 5.1.
Il ne faut pas confondre, downrez et downmix. Le downmix consiste à réduire le nombre de canaux de sortie (7.1 vers 5.1, ou 5.1 vers 2.0)*** Fin de l'aparté ***
Et pour les radins , il y a moyen de trouver ce type d'appareil à 10/20€ sur AliExpress/Banggood, mais la publicité mensongère autour des normes et certifications a l'air d'être monnaie courante. Donc méfiance
Je vais interroger des vendeurs du boncoin qui vendent des splitter, pour avoir des retour d'expériences de personnes qui ont réellement pu tester ce type d'appareil.
D'ailleurs, si des possesseurs de splitter HDMI lisent cela, merci de m'indiquer si cela fonctionne chez vous ou pas.
(Et félicitations aux lecteurs qui ont réussi à aller jusqu'au bout de ce pavé indigeste )
Bon, je me réponds de nouveau à moi même. Je me rends compte que je suis carrément dans un monologue là, mais je crois en l'utilité de mes posts
C'est toujours frustrant de tomber sur un post d'un mec qui a exactement le même problème que nous, mais que le topic n'a aucune réponse.
Nouvelles infos :
C'est le Firmware qui détermine si la TV est capable de passthrough le DTS ou pas. Donc c'est un problème/oubli software et non hardware.
Par exemple, sur la EZ950, le passthrough ne fonctionnait pas sur les premières versions de Firmware. C'est le FirmWare 3.143 qui a ajouté la prise en charge du DTS via ARC (pas le codec DTS hein, juste le pass through DTS over HDMI ARC).
Il ne reste plus qu'à Panasonic de MAJ le FW pour implémenter cela. (Je les ai contacté, j'ai enfin une interlocutrice qui parait comprendre un peu plus ce que je lui raconte, malgré qu'elle pense que le passthru DTS est impossible sans codec DTS. Dans tous les cas, je vois mal Panasonic sortir un FW juste pour moi )
Je vais m'acheter le Splitter Portta EDID pour tenter de régler cette histoire une bonne fois pour toute :
https://www.amazon.fr/Portta-Splitter-R ... r=1-6&th=1
Je vous en dirais des nouvelles bientôt
Je suis très intéressé par ton analyse et par les tests que tu fais.
J'ai deux questions :
- Tu dis que la gamme EZ950 de Pana a subit une update qui rend possible l'audio DTS over hdmi (pour enfin bénéficier du DTS sur un ampli, une barre de son, etc...). Je ne trouve l'info nulle part. D'ailleurs, est-ce que d'autres modèles ont eu droit à ce genre d'update ? Je suis intéressé par le 65GZ1000 mais sans cette info, j'ai du mal à me décider !
- Dans le cas où ça reste impossible, je regarde les audio extractor.
Concernant tes tests, ça donne quoi ? Je vois plein d'avis qui divergent sur le net.
En règle général, ça semble bien gérer le flux video (jusqu'au Dolby Vision). Pour l'audio, si je comprends bien, les modèles basiques envoient via l'optique (mais les formats les plus gros ne seront pas gérés (DTS-HD par exemple)). Ou alors, un audio extractor avec HDMI-out 2 qui envoie une image noire en 720p mais tous les formats audio.
J'aimerais vraiment avoir des retours bien précis de ce genre :
https://www.amazon.com/gp/customer-revi ... B06XRT9VGL
Encore merci pour ton analyse et merci d'avance pour tes retours.
- alcarazromain
- Inscription Forum: 08 Juil 2010 9:28
