Modérateurs: Modération Forum DIY, Modération Forum Installations, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 47 invités
MJR7-Mk5 Renardson
Message » 07 Juin 2014 23:03
bonjour,
depuis quelques jours le nom de cet ampli revient assez souvent sur le forum.
voici le lien sur le site du concepteur.
http://www.renardson-audio.com/
voici le schéma d'une voie.
Part list:
Code: Tout sélectionner
T1 2SC2240BL - NPN low noise TO-92 (July 2013 listed as discontinued) possible substitute BC550C.
T2 BC560C - PNP low noise TO-92 (ON Semiconductors)
T3 2SC2911 - NPN 160V 140mA TO-126 (Sanyo) or 2SC3503 or KSC3503D (Mouser-USA)
T4 2SA1209 - PNP 160V 140mA TO-126 (Sanyo) or 2SA1381 or KSA1381E
T5 2SA1209 - PNP 160V 140mA TO-126 (Sanyo) or 2SA1381 or KSA1381E
T6 2SK1058 - N-channel lateral mosfet 160V 7A TO-3P (Renesas)
T7 2SJ162  - P-channel lateral mosfet 160V 7A TO-3P (Renesas)
T1 and T2 need high current gain, 500 or more if possible, and T2 needs high fT, 100MHz at least.
Check data sheets for the pin number connections for alternatives.
D1, D2, D5, D6 - 3mm Red LED HLMP-1301
D7, D8, D9, D10 - 12V 500mW Zener diodes
D3, D4 - BAV20 200V 200mA diodes
L1 0.4uH. 13 turns 18swg enamelled copper wire, inside diameter 1cm length 1.6cm.
   Wire diameter 1.2mm, total length of wire about 50cm.
F1 2A-T fuse, 20mm x 5mm. (one only for 2 channels)
Vr1 220R Preset potentiometer
Vr2 4k7  Preset potentiometer
All resistors are metal film 1% 500mW apart from those listed as 2W, 250mW or 0.125W.
The power ratings listed here are just those supplied in the first kits, but few are critical.
The colour codes are listed later on this page.
R1 560k  0.125W (small size needed to fit on board)
R2 5k6    250mW
R3 5k6    250mW
R4 10k
R5 56k
R6 1k
R7 1R5  250mW
R8 200k
R9 470R  250mW
R10 470R 250mW
R11 68R
R12 300R
R13 300R
R14 56k
R15 1R5  2W  5%
R16 1R   2W  5%
R17 470R   500mW
C1 2u2 polyester 7.5mm lead pitch e.g. Epcos B32560J1225K
C2 470p polypropylene 5mm pitch (I used WIMA 1000V)
C3 470p polypropylene 5mm pitch
C4 470u 63V electrolytic 5mm or 7.5mm lead pitch
C5 1n polypropylene 5mm pitch
C6 10p COG/NPO 200V ceramic (The ones I used are marked 100J)
C7 1n polypropylene 5mm pitch
C8 100u 16V electrolytic radial 5mm dia.
C9 100p polypropylene 5mm pitch
C10 100n polyester 5mm pitch
C11 470u 63V (for 60V supply) 5mm pitch (one only for 2 channels)
C12 4700u 63V electrolytic, Panasonic TSUP. 10mm lead pitch, 25mm diameter, 2mm dia mounting holes
C13 10u non-polar electrolytic
C14 100n polyester 5mm pitch
C4, C11 and C12 need to have voltage rating greater than the supply voltage.
63V rating is suitable only for up to a  60V supply.
Using 100V electrolytics there may be a problem fitting them on the board. The 470u should have
diameter no more than 16mm, and the 4700u no more than 30mm. (e.g. Panasonic TSUP)
The transistors are rated 160V so in theory this is the upper limit, but I don't recommend this.
I only tested up to 94V. At anything much more than 60V some or all of the TO-126 transistors
may need heatsinks.
je profite donc de mon 1000eme post pour créer un topic sur cet ampli.
ayant très peu de compétence en électronique je ne saurai jugé la conception de celui-ci.
mais en tant que modeste dIyeur voici quelques raison qui m'on fait franchir le pas.
-- Faible consommation au repos.
-- "Belle" courbe en sortie, avec une distortion assez basse.
-- Peu cher a la fabrication.
Donc idéal pour faire de la multiamplification avec une integration dans un meme boitier.
J'ai commander les composants nécessaire pour m'en monté 4.
je suis en train de reprendre le routage de la carte, pour une version plus compacte et 1 seule voie par pcb.
Voila,
ce serait pas mal si on pouvait parler de cet ampli sur ce topic, afin d’eviter de "pourrir" d'autre topic.. :thks:
leo
-VIDEO-Epson Qb1000 / LG 65G1 SOURCE:PCHC 12400F+3080 12Go + Jriver
-AUDIO- FRONTALE:Jriver-Passtrought->Marantz AV10->Ram Audio Bux -> Troel.G DTQWT SURROUND: 8x 3eAudio 260-2 >JBL 8320 CAISSON: Sub Asservi GT120
Casque Fiio K5 Pro Dt-1770 Pro
athoriac
Inscription Forum: 24 Mar 2007 22:59
Message » 07 Juin 2014 23:16
Hello,
il me semble qu'un "animateur de colonies" s'est amusé à souder les 6 composants.
sur le feu forum Audax.
faut-il le rappeler ,HCFR est le forum des Bisounours,Mary Popins,Casimir, selon les bêtes matheuses du forum dead.Audax
thierry38efd
Inscription Forum: 18 Sep 2013 7:36
Message » 07 Juin 2014 23:23
Ha voilà encore un truc intéressant pour m'amuser dans le futur!Je vais me mettre ça sous le coude,mais pour l'instant je savoure trop mon JLH pour avoir envie de passer à autre chose! :D
Grand_Floyd
Inscription Forum: 01 Mai 2005 21:28
Message » 10 Juin 2014 21:59
j'ai quasiment fini le routage , j'ai integrer un petit ina134 pour desymetrisé le signal d'entrée.
vous voyer d'autre chtit modif à integrer sur le pcb ?
je me pose egalement la question pour la petite inductance de sortie, je n'ai pas sous la main de fil de 1.2mm de diametre ,
sur le net on trouve des petit calculateur d'inducance, je pense pouvoir me faire cette petite inductance avec un fil d'une plus grosse section, non ? en respectant le nombre de spire calculé.
qu'en pensez vous ?
athoriac
Message » 10 Juin 2014 22:32
Bien entendu tu peux faire cette inductance avec du fil plus gros!La valeur en plus n'est pas critique!
Grand_Floyd
Message » 10 Juin 2014 22:35
Tu nous montres un peu ton boulot ?
androuski
Message » 10 Juin 2014 23:08
le routage n'est pas totalement fini, il manque les vis de fixation je n'ai pas encore arreté la position des mosfet horizontal / vertical.
le point d'intersection des trois branche de l’étoile de masse est a finir.
bref plein de petit truc a revoir.
Au depard j'avais prevu de faire un double couche, j'ai des plaques double face en stock, mais a force de simplifié j'ai rendu le pcb quasi simple couche, et fianelement je vait peu etre utilisé un double couche, uniquement pour la serigraphie.
je ne sais pas encore si je fait un plan de masse.
athoriac
Message » 11 Juin 2014 7:26
Il s'agit donc d'une moitié de Renard désymétrisé ?
Les masses signal et power ne sont pas isolées par une R on dirait.
androuski
Message » 11 Juin 2014 8:27
pour la masse signal, j'ai un doute vu la topologie un peux speciale. typiquement R14+VR2 ajoutent une composante continue qui va recentrer les sorties mosfet a VCC/2, si on a une resistance entre la masse signal et la masse de retour HP, j'ai l'impression que le bruit lié au ground-loop entre les 2 voies risque de se retrouver amplifié sur la sortie. A simuler
EDIT: 10ohms entre la pieds de C2 & C3 ca doit pas etre mal
maxidcx
Membre HCFR Contributeur
Inscription Forum: 25 Avr 2007 10:50
Message » 11 Juin 2014 9:42
merci de vos retour, effectivement il sagit d'une carte pour une seule voie.
pour la resistance de 10ohm, je la prevois, je susi toujours a temps de ne pas la cabler, est t'il possible d'avoir un peu d'explication sur le role de celle ci.
léo
athoriac
Message » 11 Juin 2014 9:57
Si elle n'est pas sur le schéma d'origine j'aurais tendance à ne pas la mettre ; si tu suis le fil du Zenquito tu vas te foutre ma pomme puisque moi je l'ai implantée alors qu'elle n'est pas sur le schéma de JM Plantefève et que ça marche très bien comme çà, mais c'est pour faire plaisir à maxidcx, si on ne la veut pas il suffit de la straper et on se retrouve avec un bonne vieille étoile :grad:
androuski
Message » 11 Juin 2014 10:06
androuski a écrit:Si elle n'est pas sur le schéma d'origine j'aurais tendance à ne pas la mettre ; si tu suis le fil du Zenquito tu vas te foutre ma pomme puisque moi je l'ai implantée alors qu'elle n'est pas sur le schéma de JM Plantefève et que ça marche très bien comme çà, mais c'est pour faire plaisir à maxidcx, si on ne la veut pas il suffit de la straper et on se retrouve avec un bonne vieille étoile :grad:
yes, c'est ce que je me suis dit aussi, mais j'aimerai bien comprendre sont role.
de plus le fait d'avoir integré le desymetriseur ina134, ne va t'il pas perturber sont role ?
actuellement mon etoile a 4 branches.
une regroupant les masse de l'ina134, r1 c2 c3 r7
une autre pour r10 c4 t4
une pour T7
et une dernière pour le hp, confondu avec le centre de l’étoile au niveau du bornier.
athoriac
Message » 11 Juin 2014 11:38
Je ne comprend pas vraiment pourquoi il faut ajouter un "desymetriseur" ?
R.C.
CIU
Inscription Forum: 16 Mai 2005 12:09
Message » 11 Juin 2014 14:02
Tout simplement parce que mon unique source " rme hdspe aio" sort en symetrique et que souhaite conserver le signal symetrique jusqu au ampli.
Il y a contre indication ??
Ou pas tres utile ??
athoriac
Message » 11 Juin 2014 14:50
Non, aucune contre-indication
Pour moi, un transport de signal symetrique se justifie dans un environnement "pollué" , ou pour acceder à un ampli avec une architecture BTL.
Est ce "pas tres utile" ? ...Le mieux est l'ennemi du bien, alors autant faire simple et inter-changeable, car le jour ou tu veux installer ton ampli chez un pote.....ou changer de source ...
R.C.
CIU
