The THX Certified Home Theater Program
Ci dessous le cahier des charges officiel que je viens tout juste d'avoir de THX. Une liste de spécifications très élitistes bien sûr, mais qui donne le but ultime à atteindre, aussi bien en audio qu'en vidéo que concernant a pièce elle-même, etc... A méditer
In partnership with selected THX Certified Home Theater dealers, THX is now offering an audio, video and usability performance standard for dedicated Home Theater rooms. THX Certified Home Theaters will provide the following benefits:
o THX Certified Home Theater rooms guarantee the finest possible picture and sound experience at every seat in the theater
o The THX Certified Home Theater program specifies every aspect of the user experience, including the effect the room itself will have on the sound and picture
o The THX Certified Home Theater program provides a serially numbered, registered THX Certified Home Theater plaque on the wall, offering homeowners a guarantee of the finest entertainment experience
Here are some of the THX requirements for a Certified Home Theater:
The THX Certified Home Theater Experience, Image:
Size
• 16:9 with horizontal width occupying 36˚ of main viewers field of vision.
Resolution
• Native HD capable. 1080p.
Technology
• Digitally driven pixel projectors only.
• Projection screen shall be THX certified and acoustically transparent
Color
• Must meet or exceed ATSC Rec 709 standards
B&W
• THX default must be capable of D65 ±2IRE 0-100 IRE
• Screen luminance not less than 16ft lamberts.
• Contrast ratio 1000:1 or better
Processing
• Video processing shall not degrade the quality of any type of input signal.
Visual Environment
• The view from any seat shall not be blocked
• Room colors or decorations shall not visibly degrade the picture
• Air movement in the theater shall not cause visible picture distortion
Light Control
• Ambient room light shall never degrade a 0 IRE black picture.
• Room lighting control systems shall be automated
• No distracting lights shall be visible in the viewers’ normal field of vision during a screening.
User Controls
• Picture aspect ratio shall be correct automatically
• Screen deployment shall be automatic.
• Screen curtains shall be automatically activated
• Screen masking for 1.33, 1.77 and 2:39 image ratios shall be automatically selected
The THX Certified Home Theater Experience, Sound:
Clear Dialog:
• LCR speakers that meet or exceed THX Ultra2 Certification requirements
• Unobstructed audio path from LCR speakers to listener
• LCR speakers in an acoustic environment free from degrading reflections,
Refractions or resonance
• Acoustically transparent screen THX Certified and properly EQd
Precise sound localization:
• As above plus...
• LR speakers spread 45 degrees horizontally
• All speakers properly oriented to the audience
Spacious, enveloping surround sound:
• THX Ultra2 certified controller or receiver shall be used
• Four (or more) surround speakers—two side, two back in 7.1 configuration
• In THX Cinema mode, no direct surround from a surround speaker shall exceed average level of the mid-band reverberant field (400Hz – 8KHz) by 10dBA when measured at each seat
• Mid-band reverberant field power response shall not vary by more than ±4dBC referenced to the main seat
Smooth sound movement:
• Mid-band response of LCRs shall not deviate more than ±2dBA speaker to speaker
• Mid-band power response linearity of surround speakers shall match within ±3dBA
• System shall be equalized for most accurate response
Even tonal balance:
• As above plus….
• Default channel-to-channel level calibration per industry standard
• Bass response variation (20Hz-200Hz) not to exceed ±5dBC between any two
listening positions
• Pink noise stepped from channel to channel including the subwoofer system must not exceed ±3dBC from 20Hz to 20KHz when referenced to the main listening position
Full dynamics:
• No audible distortion playing program material at 115dBA peak
• Background noise NR20 and free from audible periodicity
• No intrusive transient noise to exceed NR22 including footfall, door closing, plumbing noise, HVAC motors, etc.
Transparency:
• Subjectively, nothing in the system should distract from the owners enjoyment of the presentation.
Every seat a good seat:
• A slight compromise in measured performance at the main listening position is acceptable to insure that every seat is a good seat
The THX Certified Home Theater Experience, Controls:
Visibility
• Buttons and labels properly separated and identifiable in dim light
Layout
• No confusing columns and rows of similar buttons or touch screen symbols
• Button or symbol shape and layout follows function as appropriate
• Useable with one hand
Integration
• One remote only.
• Key functions always available within two key strokes.
• Program Selection sets up input, mode and environment automatically.
• Volume control, mute and pause/play always on top
• Default setting overrides always grouped in logical tiers.
Modérateurs: Modération Forum Installations, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 8 invités
Spécifications du THX Certified Home Theater Program
- Bastien Cluzet
- Inscription Forum: 26 Aoû 1999 2:00
Please Bastien, peux tu nous en faire une traduction en français ?
bobim - Membre HCFR
Comme cela le propriétaire de la salle pourra se palucher en admirant sa plaque THX numérotée et enregistrée
On voit quand même le côté marketing et ratissage d'argent de l'affaire ( même si le côté technique est sérieux ).
- sonatine
sonatine a écrit:On voit quand même le côté marketing et ratissage d'argent de l'affaire ( même si le côté technique est sérieux ).
Tout à fait, il ne faut pas être dupe Mais bon, c'est une sorte d'état de l'art du home-theater "à moyens infinis" en quelque sorte. D'ailleurs les gens de THX n'ont pas caché qu'ils visaient là le très très haut de gamme ... > de 200000 $ en tout cas. Je suis pas sûr qu'il existe un home-theater potentiellement certifiable THX en France
Une liste de recommandations qui est toutefois fort instructive, même si beaucoup relèvent du simple bon sens, et qui vont sans dire ... çà va toujours mieux en le disant
J'essaye de traduire quand j'ai un moment. Vous remarquerez qu'il y a aussi des specs "image", et pas seulement "son".
- Bastien Cluzet
Merci bcp Bastien
bobim - Membre HCFR
Je passe en curieux
Juste vu ça qui me fait bizarre :
Technology
Si je comprends bien le VP doit être seulement de type "pixel", exit des tritubes ?????
Parceque la démo de salle THX que j'ai vu l'an dernier à un salon à Paris, il y avait un gros tritubes Barco série 900 je crois.
Comprends pô
Je passe en curieux
Technology
Comprends pô
- artefact
- Inscription Forum: 18 Mai 2003 10:24
artefact a écrit:Parceque la démo de salle THX que j'ai vu l'an dernier à un salon à Paris, il y avait un gros tritubes Barco série 900 je crois.
Comprends pô
Pourtant la réponse est dans ta question : la salle de démo que tu as vue à Paris n'était pas certifiée THX, tout simplement
- Bastien Cluzet
Heu si c'était l'an dernier le salon où LAL exposé la voiture de la ligue des gentlemens extraordinaire. Si je me rappel bien le gros cube près du stand de HCFR, c'était bien une démo de salle THX.
M'enfin peux me tromper.
La salle était un cube noir avec série de siéges "bougeant", démo de HD, image cinéma et DVD.... et un TT au plafond !
Une belle claque d'ailleur sur l'image et le son.
- artefact
artefact a écrit:Heu si c'était l'an dernier le salon où LAL exposé la voiture de la ligue des gentlemens extraordinaire. Si je me rappel bien le gros cube près du stand de HCFR, c'était bien une démo de salle THX.
Oui, je connais très bien cette salle. Non, la salle de démo D-Box/ Soft ADS/ etc... n'est pas certifiée THX. Elle pourrait éventuellement l'être, mais le programme vient tout juste d'être mis en place. il faudra donc attendre un peu
- Bastien Cluzet
Bastien Cluzet a écrit:Resolution
Technology
En clair, a ce jour il faut avoir un JVC HD2K ou un Sony Qualia !! (les seuls "domestiques" en 1080p)...
Et encore, ce sera pas forcément simple d'atteindre 16fL avec ceux ci
Finalement je ne sais pas si c'est si marketing que ca... s'ils avaient tapé moins haut, là oui, il y aurait eu beaucoup plus de candidats...
--Patrice
Adherez à l'association HCFR pour que le site vive et reste indépendant... HCFR for ever...
- laric
- Membre d'Honneur - Webmaster
- Inscription Forum: 19 Juil 2000 22:13
Bastien Cluzet a écrit:The THX Certified Home Theater Program
Bien sur que ca sent un peu la promo. Mais je suis tres favorable a toute info permettant de faire progresser nos salles, meme si je n'irai jamais demander l'agrement THX pour ma prochaine salle. Donc voila voila.
- LeBouffon
- Inscription Forum: 21 Aoû 2002 18:14
Layout
Pour les films de fesses labelisés THX, probablement.
- Marc-Etienne HUNEAU
- Inscription Forum: 09 Sep 1999 2:00
Laric a écrit
Ben non tu peux pas mettre un hd2k ou un qualia c'est des trucs de pauvres, pour atteindre 16 foot lambert, faudrait pas dépasser 2.50m de base( ou écran à gain mais ça le fait pas), dans une salle comme ça il faut plus grand.
Donc tu es obligé d'installer un dila QX1 ou je sais pas quoi d'autre d'ailleurs .résultat:200000$ juste pour le projo... on est pas pret d'avoir une salle THX à la maison.
Resolution
Technology
- Dendarii
- Inscription Forum: 01 Mai 2004 10:02
28 messages
Retourner vers Intégration, Domotique, Stockage et Réseau |
