To get a 1:1 HT bypass simply select the HT input source, set the gain
to 0dB, and then turn the volume control all the way up. Done. The
Purist is now operating exactly at 0dB, put another way it's operating
at a 1:1 ratio, or yet another way if the HT input provides 1V the
Purist sends 1V to the amplifier. This is exactly what a simplified 1:1
HT bypass does. No difference.
Effectivement...
Bien vu
