Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: PhilippeCVN et 114 invités
AuzenTech HDA X-Meridian 7.1 : peut être HDMI 1.3
Message » 24 Oct 2006 22:33
Salut :)
Voici la nouvelle carte son de la marque AuzenTech, j'ai nommé la HDA X-Meridian 7.1.
Elle ressemble vaguement à ça :
Le plus interessant maintenant pour les spécialistes, les spécifications :
Source: www.auzentech.com
  • The C-Media Oxygen HD CMI8788 Audio Processor is the heart of the AUZEN X-MERIDIAN 7.1.
  • 4 pcs 24-bit/192kHz AK4396VF (120dB-part spec.) DACs for 7.1channel output. (24-bit/192kHz in 7.1channel playback)
  • 1 pc 24-bit/192kHz AK5385VF(114dB-part spec.) ADC input (24-bit/192kHz recording)
  • 1 pc CMI9780 AC'97 2.3 CODEC for AUX input, CD input, MIC input (16bit/48kHz playback/recording)
  • Integrated up to 192k/24-bit S/PDIF transmitter for 44.1kHz,48kHz, 96kHz, 192kHz SPDIF output.
  • Supports onboard high grade special COAX+OPTIC combo type transmitter module for up to 192kHz SPDIF out.
  • Integrated up to 192k/24-bit S/PDIF receiver for 44.1kHz,48kHz, 96kHz, 192kHz SPDIF input.
  • Supports onboard high grade special COAX+OPTIC combo type receiver module for up to 192kHz SPDIF input.
  • Standard 10PIN Front Panel Audio supports connectivity for stereo audio output and a microphone input from most new chassis. (All 7.1channel analog output muted by jack connection sense of front panel headphone out / Dual MIC input available by back panel mic input and front panel mic input)
  • DTS® Interactive - A real-time 5.1 channel encoder.
  • DTS® Neo:PC - An upmix matrix technology.
  • Dolby® Digital Live (DDL) - A real-time 5.1 channel encoding.
  • Dolby® ProLogic IIx surround processor spreading stereo audio into 7.1 channel surround sound.
  • Dolby® Headphone technology, conveying 5.1 surround and 3D gaming audio over stereo headphones.
  • Dolby® Virtual Speaker solution, bringing amazing virtual surround sound fields via general two speakers.
  • C-Media FlexBass™ - LFE channel crossover frequency setable from range 50 to 250Hz in Small speaker mode and Small/Large speaker selectable.
  • C-Media Magic Voice™, popular feature for disguising your tone in online chatting.
  • C-Media Xear 3D™ 7.1 Virtual Speaker Shifter technology.
  • C-Media’s unique Karaoke functions: Microphone Echo, Key-shifting.
  • Individual 10-band EQ for each channel,.27 global reverberation environments.
  • Supports most industrial standards of 3D sound for PC gaming, including EAX™ 1.0 & 2.0, A3D™ 1.0, and DirectSound™.
  • Swappable DIP type OPAMP controlled preamp out circuit (4pcs output control OPAMP IC with DIY socket)
  • Surface mount type OPAMP controlled preamp input circuit (2pcs input control OPAMP for ADC and 1pc MIC input gain control)
  • 5Vrms (Differential DAC output with gain adjustment / approximately full swing from +/- 8V dual power supply)
  • Proper OPAMP control circuit (large capacity 1A +8V, -8V, dual power supply circuit) for high quality audio quality, prevent audio distortion at high volume level.
  • Upgrade Extension available (Extra 6.35mm MIC / Extra Digital I/O sold separately)
Possibilité d'ajouter des cartes d'extensions (vendues séparéments) :
  • Extra COAX + OPTIC Combo S/PDIF Input (Up to 24-bit/192khz support)
  • Extra COAX + OPTIC Combo S/PDIF Output (Up to 24-bit/192khz support)
  • 3.5mm minijack MIDI IN / MIDI OUT with 2pcs special 3.5mm miniplug-5-pin standard DIN jack cables
  • S/PDIF DIN(Gold Plated 9-pin MINI DIN jack) for 8CH Pure PCM Ouput - all channels up to 24bit/192kHz support. Compatible with Creative Lab's Digital DIN 6CH PCM SPDIF Input connection.
  • 6.35mm TRS jack MIC Input - 6.35mm plug type mic (compatible with TRS/TS plug) and 5V power jumper allows you to supply auxiliary MIC power, if needed. (Move the jumper cap from open to pins 1-2).
    o 4-pin-4-pin shield wire connection required between onboard's 4-pin EXT_MIC connector and extension board's 4-pin EXT_MIC connetor.
    o Triple MIC input available - back panel, front panel(FP_AUDIO), extension board's extra 6.35mm TRS jack MIC input
  • Compatible with Creative Lab's Digital DIN 6CH PCM SPDIF Input connection
Elle est déjà disponible en précommande sur le site du fabriquant pour 199$ pour les impatients.
pildoy
Inscription Forum: 18 Juin 2003 18:37
Message » 25 Oct 2006 18:07
Elle me plait bien. Ca fait un moment que je suit son évolution. Ce qui m'interesse c'est l'encodage AC3 ou DTS en live. Malheureusment je ne sui pas un technicien et niveau qualité je ne sais pas si ses spécifications sont bonnes. Si un spécialiste passe par la....
ropiav
Inscription Forum: 08 Mar 2006 2:38
Message » 10 Déc 2006 21:46
Salut :)
Même si apparament cette carte n'interesse pas grand monde, j'ai une bonne nouvelle :) Bacata, le distributeur français, vient d'ajouter la carte à son catalogue. On devrait donc trouver la carte en France d'ici peu, sns être obligé de passer par la case import ;)
pildoy
Message » 13 Déc 2006 8:40
Intéressant! Ce sont 4 DAC stéreo HDG (le top de chez AKM). Et puis les 4 Ampli OP sont swappables...
Attendons de voir s'il y a des drivers Vista complets avec DRC (à défaut de drivers ASIO :( )
NFC
Inscription Forum: 30 Mai 2004 13:38
Message » 13 Déc 2006 11:29
Deckard2019
Inscription Forum: 11 Sep 2004 11:31
Message » 25 Déc 2006 10:38
En fait si, elle dispose de drivers ASIO aussi...
Les drivers Vista sont en cours de développement.
Le manuel de cette carte
NFC
Message » 26 Déc 2006 19:51
J'ai acheté cette carte qui correspond parfaitement à mon utilisation jeux/HC. Néanmoins j'ai un souci sur le passtrough de source DD ou DTS. J'ai parfois et aléatoirement des mini-coupures très désagréable. J'èspère un simple problème de driver. Sinon aucun problème pour lire la musique ou les jeux EAX.
ropiav
Message » 29 Déc 2006 17:16
Tu l'as acheté où ?
Je n'arrive pas à la trouver en France et payer 60$ de fdp, merci ! :evil:
funkyMat
Inscription Forum: 15 Nov 2006 20:04
Message » 29 Déc 2006 20:59
Je l'avais précommandée à l'époque.
Maintenant tu peux la trouver la :wink:
ropiav
Message » 09 Jan 2007 0:02
Je l'ai commandé chez Bacata la ou je bosse... c'est vrai qu'elle a l'air pas mal j'ai déja su en vendre une rien qu'avec ses caractéristiques techniques... par contre la ou j'ai un gros doute c'est sur les adaptateurs coax->optique qui font vraiment plastoc bas de gamme...
Scoual
Inscription Forum: 03 Mar 2005 17:52
Message » 12 Jan 2007 20:52
Quelques fils intéressants sur la X-Meridian:
http://www.avsforum.com/avs-vb/showthread.php?t=765317&page=1&pp=30
http://hardforum.com/showthread.php?t=1113796
http://forums.anandtech.com/messageview.aspx?catid=27&threadid=1885218&enterthread=y
On pourra noter dans le post AVS que la comparaison entre X-Meridian et X-Fi elite pro semble en faveur de la Meridian, surtout si on change les ampli-ops (LM4562 chaudement recommandés apparemment). Par contre l'elite pro permet le décodage DD/DTS de l'entrée spdif (pour connecter une console de jeux par exemple) et pas la Méridian (en tout cas, je ne sais pas encore comment faire ça avec un décodeur soft du type AC3filter).
On notera aussi qu'une personne à réussi à installer les driver beta pour Vista d'une façon qui permet la DRC de Vista (post #147 du fil AVS)
NFC
Message » 12 Jan 2007 21:39
Bizarre, à lire la documentation on a l'impression que la carte est capable de décoder nativement un signal DD/DTS via le S/PDIF... enfin entre le marketing et la réalité... moi qui pensait que cette carte était mieux fichue que celle à base d'Envy24HT.
depanneur chef
Inscription Forum: 16 Avr 2005 22:33
Message » 13 Jan 2007 11:42
Où ça dans la doc?
NFC
Message » 13 Jan 2007 12:56
Oups, j'ai mal lu effectivement :oops: :(
depanneur chef
Message » 13 Jan 2007 13:33
En même temps ils laissent sous entendre que le signal n'est pas modifié, donc il doit être récupérable dans un logiciel quelconque de type MPC !
Mork
Inscription Forum: 30 Nov 2002 21:12
