Voici la nouvelle carte son de la marque AuzenTech, j'ai nommé la HDA X-Meridian 7.1.
Elle ressemble vaguement à ça :
Le plus interessant maintenant pour les spécialistes, les spécifications :
Source: www.auzentech.com
- The C-Media Oxygen HD CMI8788 Audio Processor is the heart of the AUZEN X-MERIDIAN 7.1.
- 4 pcs 24-bit/192kHz AK4396VF (120dB-part spec.) DACs for 7.1channel output. (24-bit/192kHz in 7.1channel playback)
- 1 pc 24-bit/192kHz AK5385VF(114dB-part spec.) ADC input (24-bit/192kHz recording)
- 1 pc CMI9780 AC'97 2.3 CODEC for AUX input, CD input, MIC input (16bit/48kHz playback/recording)
- Integrated up to 192k/24-bit S/PDIF transmitter for 44.1kHz,48kHz, 96kHz, 192kHz SPDIF output.
- Supports onboard high grade special COAX+OPTIC combo type transmitter module for up to 192kHz SPDIF out.
- Integrated up to 192k/24-bit S/PDIF receiver for 44.1kHz,48kHz, 96kHz, 192kHz SPDIF input.
- Supports onboard high grade special COAX+OPTIC combo type receiver module for up to 192kHz SPDIF input.
- Standard 10PIN Front Panel Audio supports connectivity for stereo audio output and a microphone input from most new chassis. (All 7.1channel analog output muted by jack connection sense of front panel headphone out / Dual MIC input available by back panel mic input and front panel mic input)
- DTS® Interactive - A real-time 5.1 channel encoder.
- DTS® Neo:PC - An upmix matrix technology.
- Dolby® Digital Live (DDL) - A real-time 5.1 channel encoding.
- Dolby® ProLogic IIx surround processor spreading stereo audio into 7.1 channel surround sound.
- Dolby® Headphone technology, conveying 5.1 surround and 3D gaming audio over stereo headphones.
- Dolby® Virtual Speaker solution, bringing amazing virtual surround sound fields via general two speakers.
- C-Media FlexBass™ - LFE channel crossover frequency setable from range 50 to 250Hz in Small speaker mode and Small/Large speaker selectable.
- C-Media Magic Voice™, popular feature for disguising your tone in online chatting.
- C-Media Xear 3D™ 7.1 Virtual Speaker Shifter technology.
- C-Media’s unique Karaoke functions: Microphone Echo, Key-shifting.
- Individual 10-band EQ for each channel,.27 global reverberation environments.
- Supports most industrial standards of 3D sound for PC gaming, including EAX™ 1.0 & 2.0, A3D™ 1.0, and DirectSound™.
- Swappable DIP type OPAMP controlled preamp out circuit (4pcs output control OPAMP IC with DIY socket)
- Surface mount type OPAMP controlled preamp input circuit (2pcs input control OPAMP for ADC and 1pc MIC input gain control)
- 5Vrms (Differential DAC output with gain adjustment / approximately full swing from +/- 8V dual power supply)
- Proper OPAMP control circuit (large capacity 1A +8V, -8V, dual power supply circuit) for high quality audio quality, prevent audio distortion at high volume level.
- Upgrade Extension available (Extra 6.35mm MIC / Extra Digital I/O sold separately)
Possibilité d'ajouter des cartes d'extensions (vendues séparéments) :
- Extra COAX + OPTIC Combo S/PDIF Input (Up to 24-bit/192khz support)
- Extra COAX + OPTIC Combo S/PDIF Output (Up to 24-bit/192khz support)
- 3.5mm minijack MIDI IN / MIDI OUT with 2pcs special 3.5mm miniplug-5-pin standard DIN jack cables
- S/PDIF DIN(Gold Plated 9-pin MINI DIN jack) for 8CH Pure PCM Ouput - all channels up to 24bit/192kHz support. Compatible with Creative Lab's Digital DIN 6CH PCM SPDIF Input connection.
- 6.35mm TRS jack MIC Input - 6.35mm plug type mic (compatible with TRS/TS plug) and 5V power jumper allows you to supply auxiliary MIC power, if needed. (Move the jumper cap from open to pins 1-2).
o 4-pin-4-pin shield wire connection required between onboard's 4-pin EXT_MIC connector and extension board's 4-pin EXT_MIC connetor.
o Triple MIC input available - back panel, front panel(FP_AUDIO), extension board's extra 6.35mm TRS jack MIC input- Compatible with Creative Lab's Digital DIN 6CH PCM SPDIF Input connection
Elle est déjà disponible en précommande sur le site du fabriquant pour 199$ pour les impatients.
