Bjr,
Une intéressante synthèse AVS
... more product detail about the new AVRs from Onkyo ...
1. Faroujda-enabled receivers (605, 705, 805) used largely for deinterlacing 480i -> 480p
2. HQV-enabled receivers (875, 905) enable State-of-the-Art video scaling technology and do enable the user to take any video source to your choice of: 480p/720p/1080i/1080p.
3. HDMI Audio Processing
a) Pass Through: 505, 575 (just switching, no processing through HDMI)
b) HDMI 1.3 (605 and up):
Dolby Digital, DTS, PCM 2ch, Multi-Channel PCM for DVD-A, DSD for SACD,
DD Plus, DD TrueHD, DTS-HD
4. HDMI Video Processing
a) Pass Through: (505) No processing, just switching
b) HDMI Up-Conversion (all versions, repeater-based): Analog to Digital HDMI conversion
c) HDMI Up-Conversion with de-interlacing (605 and up): Analog to Digital HDMI
480i -> 480p processing
d) HDMI Up-Conversion and Scaling (875, 905): Analog to Digital HDMI Conversion, and
1080p Up-Scaling
Deep Color: 12-bits for each color on V1.3 (vs. 8-bits on V1.2)
Higher Frame Rate: V1.2 has up to 60Hz, V1.3 has up to 240Hz (current
chipsets only support up to 72Hz)
5. RIHD (Remote Interactive over HDMI)
One-Touch Play: Click DVD Play...DVD Player, Onkyo AVR and CEC-enabled
Display all automatically Power On and DVD Plays
(DVD is Master, AVR and TV are Slaves)
System Standby: Click DVD Standby...DVD Player, Onkyo AVR and CEC-Enabled
Display all automatically go into Power Standby mode
(TV is Master, AVR and Source are Slaves)
System Audio Control: (TV is Master, AVR is Slave)
Input Expander: Click Video Input Button, TV automatically setups the source
in the display and the AVR
Auto AV Sync: AV Lip Sync is automatically adjusted in the AVR
Thus far, the only displays that are compatible with ALL of these features are the Toshiba CE Link-equipped models.
6. Audio Feature Set
THX Ultra2 Starts at $999
Real High Current
(HICC High Instantaneous Current Capability at 10kHz, 0.1ohm):
Onkyo 805 Denon AVR2807 Yamaha RX-V2700 Pioneer VSX-84TXSi
130W 110W 140W 140W
65A 14A 38A 15A
Current is what drives your speakers cleanly.
7. Separate Construction on 805, 875 and 905
The Pre Processor and Power Amp Sections are modularly constructed on separate interior blocks for better noise isolation and cleaner sound.
8. Advanced Parts
Top of the line Burr-Brown DACs on 805, 875 and 905
Onkyo: PCM 1796 123dB S/N
Denon 3806, Yamaha 2700: PCM 1791 113dB S/N
Better Power Supply
Toroidal Transformer on 905
- Low Impedance Ability to drive any type of speaker
Independent Power Supplies (4)
Toroidal: For Power/Pre Amp Stage
2nd: For Digital Audio Stage, like DSP
3rd: For Video, HD Radio, Network, other
4th: For Stand-by Status
Advanced Feature Set (TX-NR905)
Plays for Sure: Supports WMA DRM Audio Streaming
USB Input: Play Audio Files on USB Memory
HD Radio Capable
FYI, the TX-SR705 is rated at 100W/channel, the TX-SR805 and TX-NR905 are rated at 140W/channel.
BTW, HD DVD player is tentatively scheduled for October...$1199
AMHA et s'il remplit tout ce qui est listé ici, l'Onkyo 905 risque tout simplement d'être une GRANDE machine d'anthologie!!!
Hugo
