Il n'y a pas de browser dans le Tvix donc tu ne peux pas naviguer sur internet.
Ce que tu peux faire c'est mettre l'url d'un flux musical de type Shoutcast PLS.
Tu trouves ces adresses sur internet et tu copies le fichier PLS sur ton disque.
Exemple, chaîne de jazz de Smoothjazz.com (tu fais un copier-coller dans une fichier blocnote et tu sauvegardes en .pls)
[playlist]
numberofentries=11
File1=http://64.236.34.99:80/stream/1005
Title1=(#1 - 177/24978) SmoothJazz.com
Length1=-1
File2=http://64.236.34.106:80/stream/1005
Title2=(#2 - 294/22363) SmoothJazz.com
Length2=-1
File3=http://scfire-ntc0l-1.stream.aol.com:80/stream/1005
Title3=(#3 - 41/500) SMOOTHJAZZ.COM - The Global Home for the Smoothest Jazz 24/7 - Live from Monterey Bay
Length3=-1
File4=http://scfire-nyk0l-2.stream.aol.com:80/stream/1005
Title4=(#4 - 42/500) SmoothJazz.com
Length4=-1
File5=http://scfire-chi0l-1.stream.aol.com:80/stream/1005
Title5=(#5 - 45/500) SMOOTHJAZZ.COM - The Global Home for the Smoothest Jazz 24/7 - Live from Monterey Bay
Length5=-1
File6=http://scfire-dll0l-1.stream.aol.com:80/stream/1005
Title6=(#6 - 45/500) SMOOTHJAZZ.COM - The Global Home for the Smoothest Jazz 24/7 - Live from Monterey Bay
Length6=-1
File7=http://scfire-dll0l-2.stream.aol.com:80/stream/1005
Title7=(#7 - 48/500) SMOOTHJAZZ.COM - The Global Home for the Smoothest Jazz 24/7 - Live from Monterey Bay
Length7=-1
File8=http://scfire-ntc0l-2.stream.aol.com:80/stream/1005
Title8=(#8 - 52/500) SMOOTHJAZZ.COM - The Global Home for the Smoothest Jazz 24/7 - Live from Monterey Bay
Length8=-1
File9=http://scfire-chi0l-2.stream.aol.com:80/stream/1005
Title9=(#9 - 58/500) SMOOTHJAZZ.COM - The Global Home for the Smoothest Jazz 24/7 - Live from Monterey Bay
Length9=-1
File10=http://207.200.96.226:8052
Title10=(#10 - 86/100) SmoothJazz.com
Length10=-1
File11=http://scfire-nyk0l-1.stream.aol.com:80/stream/1005
Title11=(#11 - 500/500) SMOOTHJAZZ.COM - The Global Home for the Smoothest Jazz 24/7 - Live from Monterey Bay
Length11=-1
Version=2
http://bois-pigeons.miniville.fr
