Images of the excellent sounding speakers - Rockport Mira - €17000
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: damien8549, djeudo, Juju94, PETER77, Pileelectrique37 et 418 invités
caisse
ça parait pas son poids
- P.LM
- Contributeur HCFR 2018
- Inscription Forum: 30 Avr 2007 19:30
P. le maudit a écrit:ça parait pas son poids
53 kg poids plume
Câblage interne Transparent.
- reyle
- Inscription Forum: 23 Déc 2006 17:44
Midrange - 5.25", custom-designed midrange went through 23 different iterations before the final design, which uses a mineral-filled poly-cone with a sophisticated motor system built to Rockport’s specs by Denmark’s Audio Technology. This handles frequencies from 140Hz–2.5kHz. Features “Symmetric Drive,” to reduce rise time by a factor of ten, resulting in greater linearity regardless of the cone’s position. Moreover, “Symmetric Drive” is lowers voice coil inductance, creating a more stable impedance and therefore simpler crossover topology, making the speaker easier to drive for high-impedance tube amps.
Tweeter - 1", Scan Speak Revelator motor system. Chosen for its low resonant frequency (1.5–2kHz) and ability to deliver the natural body of instruments.
Woofers - 10" Danish-made Vifas. As with the $91,500 Hyperion, the Mira’s 24dB-per-octave acoustic slope crossover is hand-built, and point-to-point wired with custom film/foil caps (made exclusively for Rockport), custom inductors, and Caddock resistors. All are spec’d at 1% tolerance, and the unit is epoxy-potted for mechanical stability as well as reduced microphonics.
Wiring - Internally wired with Transparent cable and connected via Cardas rhodium posts.
Enclosure - Danish-made enclosure of pure MDF. The front baffle is 3"-thick and the walls are 1"-thick. Seven individual braces lock the cabinet’s panels together, while at the same time creating separate acoustic chambers for each driver. The side-firing woofer housing has a 2" thick panel for the driver mounting surface and is rear-vented “with deeply radiused edges to prevent port turbulence.” (Payor believes that a properly designed vented enclosure allows for both lower driver distortion and higher motor strength, and can couple to room boundaries as well as sealed cabinets.)
The front-driver baffle uses a laser-cut Steinway-felt insert to reduce reflections from the midrange and high-frequency drivers. Long-fiber wool is used to damp the midrange enclosure, and a mixture of anechoic wedge foam and polyster is found in the bass cabinet.
Finish - high-gloss piano black polyester, an eleven-step process performed by the same European company that finishes Steinway grands.
Specifications - Rockport Technologies Mira
Retail Price: USD 16,999 (as at Oct 2005)
Floorstanding, 3-way vented loudspeaker
Driver complement: 1.1" soft-dome tweeter, 5.25" mid/bass driver, 10" side-firing woofer
Frequency response: 30Hz–20kHz
Sensitivity: 88dB
Impedance: 4 ohms
Recommended amplifier power: 50 watts minimum
Dimensions: 10.25" x 44.75" x 19.5"
Weight: 115 lbs. each / 52.16 kg each
Sensitivity: 88dB
Impedance: 4 ohms
- reyle
Voilà les miennes à peine sorties du carton
Photo floue due à l'excitation, d'ailleurs les images en général ne lui rendent pas justice, élégantes, élancées, racées, superbes, tels sont les premiers mots qui me viennent à l'esprit tant pour qualifier leur look que pour leur première écoute
- reyle
Félicitations
très belle prise que tu nous as fait là, vivement la suite
- Goan
- Pro-Commercant.
- Inscription Forum: 01 Avr 2007 23:31
Merci Goan
Ce qui est sûr c'est qu'avec ce genre de pétoires, toujours pas importées en France, ce qui est plus que surprenant, je vais pouvoir dire et écrire à peu près n'importnawak .
- reyle
Enfin mon flair me dit qu'on ne devrait pas tarder à en entendre parler enfin, car j'ai cru comprendre que la maison lors de sa dernière participation à Vegas a montré des signes de marketing plus agressif et volontariste et que, quelques importateurs français sont sur les rangs depuis belle lurette
- reyle
