Audioholics a écrit:The RX-Z7 shares many of the same virtues as their RX-Z11 flagship but with an improved implementation of Anchor Bays top end video processor which does mosquito noise reduction, block noise reduction and fine detail and edge enhancement. The RX-Z7 incorporates Anchor Bay's PReP (Progressive ReProcessing) for improving progressive video signals and artifact removal. Their video processing also provides seven different video adjustment parameters with six independent storage settings to ensure all of your video sources can be properly calibrated through this receiver.
On the audio side, all of the latest hidef formats are supported for decoding and the RX-Z7 features a digital system clock generator which is said to isolate the DSP devices and DAC's from digital inputs to prevent jitter. The RX-Z7 is the only receiver of the three mentioned herein that offer this level of video and audio processing as well as a preamp mode which redirects all seven internal channels to other zones or turns them off entirely so you can use a more powerful separate multi channel amplifier when needed.
Confirmation de leur part que le Z7 utilise le dernier chip de chez Anchor Bay avec 7 réglages paramétrables et 6 mémoires pour stocker ses profiles.
Il aurait aussi un mode Preamp, désactivant réellement l'étage d'amplification lorsqu'il ne sont pas utilise pour une zone 2/3.
De mieux en mieux !
