AnyDVD HD 6.5.7.4
http://www.slysoft.com/fr/download.html
Change log depuis la 6.5.5.5 :
6.5.7.4 2009 08 06
- New (Blu-ray): Added support for new BD+ protections
- New (Blu-ray & HD DVD): Added option to enable/disable
protected ISO ripping warning
- Fix (DVD): Bug introduced with 6.5.7.1, AIscanner could
include unwanted parts of a disc
- Some minor fixes and improvements
- Updated languages
6.5.7.1 2009 07 24
- New (Blu-ray): Added support for AACS MKB v14
- New (DVD): Added support for new copy protection,
e.g. "Haunting in Connecticut", R1, US
- New (DVD): AI scanner improved
- Fix (DVD): Structural repair with some discs, e.g.
"Transporter 3", R2, Germany
- Fix (DVD): Bug introduced with 6.5.5.9, "IFOTitles 0" error with some
titles, e.g. "Seven Pounds", R2, Italy
- Fix (DVD): Bug in AI scanner, causing parts of a DVD not to be included with
some discs, e.g. "Aujourd'hui, c'est Ferrier!", R2, France
- Updated languages
6.5.5.9 2009 06 11
- New (HD DVD): Added workaround for authoring error on French
HD DVD "Zidane"
- New (Blu-ray): Added PowerDVD "virtual drive" blacklist workaround
- New (Blu-ray): Added option to enable/disable PowerDVD "virtual drive"
- New (Blu-ray): Added option to enable/disable update server warning
- New (DVD): Added support for a new pathetic copy protection called
"DVD Sequr Copy Protection"
- New (DVD): Added support for new protections, e.g. "Underbelly -
a tale of two cities", R4, Australia
- New (DVD): Added option to enable/disable DVD ISO ripping warning
- New (DVD): Added additional information to logfile
- New: Added option to enable/disable "no drive present" warning
- Fix: AnyDVD ripper failed, if volume label contained the character '*'
- Fix (HD DVD): "Error reading ADV_OBJ", if two identical discs are inserted
in two different drives at the same time
- Fix (DVD): Brute force CSS decryption (region code mismatch) could fail.
- Updated languages
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: BangoO, imotep27000, stef44 et 135 invités
AnyDVD HD !
- AlexScan
- Inscription Forum: 27 Déc 2005 20:57
Petite question
Je pense qu'il est possible de télécharger AnyDVD sur mon PC bureautique connecté à internet et de le transférer (à l'aide d'une clef USB par exemple) sur mon PCHC non connecté à internet.
Mais cela est il possible pour les mises à jour ?
Alain
Alain
- ALBO
- Inscription Forum: 04 Mar 2001 2:00
Petite question
OUI sans problème
OUI sans problème
- 974eric
- Inscription Forum: 08 Mai 2007 16:00
974eric a écrit:Petite question
OUI sans problème
Merci Eric
Alain
- ALBO
ANYDVD-HD 6.5.8.2 2009 09 10
- New: When waking up from standby or hibernate, the discs in the drives
are no longer re-scanned, drives containing a CSS protected disc are
re-authenticated
- New (DVD): Workaround for bug in some drive firmware, e.g. Lite-On
IHOS104 BD-Rom drive, CSS decryption didn't work
- Fix (Blu-ray & HD DVD): Downloaded decryption keys were lost
after AnyDVD restart
- Fix (Blu-ray & HD DVD): Some stability issues
- Updated languages
re-authenticated
- Updated languages
- coldhand
- Inscription Forum: 11 Fév 2007 13:15
Pour info
20% de réduction jusqu'à fin 09
Alain
Alain
- ALBO
Je pense qu'il faut choisir la version lifetime qui doit être valable durant toute la vie du logiciel ?
Alain
Alain
- ALBO
Retour jusqu'au 31/12 de la licence Lifetime (= à vie) chez Slysoft
http://www.slysoft.com/fr/purchase.html
- ph75
- Inscription Forum: 16 Juil 2006 13:18
