Update en 1.8.6.0
http://sandbox.slysoft.com/beta/SetupReClock1860.exe
1.8.6.0 - 12/01/2010
* New: Config.exe has an improved design, thanks to yesgrey3!
* Change: Removed "original speed x0.75"
* Change: Renamed "original speed x0.96" to "original speed - 4%"
* Change: Instead of simple quality settings, Config.exe displays the used algorithm of the resampler plugin.
* Change: Replaced default resampler plugin with libresample by Dominic Mazzoni & Julius Smith, as it is licensed under LPGL instead of GPL.
Sound quality & CPU load should be similar to the SCR resampler quality settings "Fastest Sinc Interpolator" (good) and "Medium Sinc Interpolator" (very good).
With the new resampler there are only two quality settings available: "Fast Sinc Interpolation" (good) and "High-quality Sinc Interpolation" (very good).
* New: The option to expand mono to both front speakers now works with the AC3 encoder, too.
* New: Added "original speed + 4.2%" so that everyone in a NTSC country can check, that "PAL speed up" really sucks.
* New: Timestretch sound quality improved in 5.1 and 7.1 speaker setups, thanks to Rodney Clinton Chua!
* Fix: Memory leaks in AC3 encoder and Timestretch plugin
* Some fixes and improvements
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: minifrix et 81 invités
Reclock 1.8.6.1 by Slysoft
- Kaotech
- Inscription Forum: 02 Aoû 2006 11:46
Dominic Mazzoni. Connait ce gars, c'est une pointure en audio, c'est lui le créateur d'Audacity.
Son resampler a une très bonne réputation. A tester.
Patrick
Patrick
- Lansing
- Inscription Forum: 23 Mai 2005 21:01
Bah dis donc la cosmétique a carrément changé :
Xavier.
Xavier.
- tobal
- Inscription Forum: 13 Sep 2001 2:00
L'interface est beaucoup plus intuitive qu'avant.
Beau boulot.
Beau boulot.
- Kaotech
reste à savoir à quoi ca sert et où ca intervient tous ces paramétrages
- kbil69
+1 je l'installe aujourd'hui !
- AlexScan
- Inscription Forum: 27 Déc 2005 20:57
Attend demain ou après demain, il y aura surement une autre version
- kbil69
Ah oui c'est vrai ... m'en fou celle-là elle me plait avec la nouvelle interface.
- AlexScan
Première impression sur mon install, le son pète le feu, dans le mode High quality une sensation de dynamique supérieure qui me fait baisser le volume. La première fois que ça m'arrive depuis le début il y a 5 ans.
Une répartition de charge CPU (P4) différente, les deux threads sont à 50/50. Avant, en qualité médium Reclock étais à 8% de CPU. Avec High quality je suis à 14% mais l'équilibre sur les deux threads fait que la charge totale n'a pas bougé. Nickel.
Reste une sortie Asio et c'est parfait.
Patrick
Patrick
- Lansing
Comme on parle de resample , je prends la balle au bond.
J'utilse depuis quasiment toujours le mode "slave reference clock to audio ".
Bien que non recommendé par reclock cela fonctionne parfaitement chez moi ...
By coulinec at 2010-01-14
Dites moi si je me trompe , mais cette option permet de s'affranchir de tout resample (bit exacte) que ce soit en DS , KS ou Wasapii .
La charge CPU est ridicule comparée à cette option décochée .
- TANTRUM
- Inscription Forum: 10 Sep 2006 16:31
Lansing a écrit:Première impression sur mon install, le son pète le feu, dans le mode High quality une sensation de dynamique supérieure qui me fait baisser le volume. La première fois que ça m'arrive depuis le début il y a 5 ans.
Patrick
Perso, je m'en fous du resampling vu que je le squeeze pour passer en bitperfect mais c'est vrai que les librairies ont changé.
C'est une bonne nouvelle par contre s'ils ont réussi à équilibrer la charge au meilleur du resampling.
Ceci dit le dev. pense qu'il y a une erreur de filtrage dans le resampling qu'il a intégré.
Marrant que tu trouves ça meilleur, Patrick.
Tiens un truc en passant pour ceux qui utilisent le dxva avec leur player, reclock gère la vsync dans ce mode, vmr9 ou evr : ça marche parfaitement bien.
Xavier.
- tobal
Salut Tobal,
Dis, tu fais comment pour le sqeezer et te retrouver en bitperfect qui, ceci dit, semble être le cas au vu du premier screen de TANTRUM.
cdlt,
guy.
cdlt,
guy.
- Guy59
- Inscription Forum: 04 Mar 2007 17:13
ya une dll en beta du resampler en multithreadé (une thread par channel) donc sur un bon quadcore avec/sans hyperthreading ca peut vite le faire
Le lien direct
http://forum.slysoft.com/attachment.php ... 1263511787
La page ou ya la discussion associée
http://forum.slysoft.com/showthread.php?t=37598&page=8
Le lien direct
- pbmtp
- Inscription Forum: 04 Mai 2008 19:50
tobal a écrit:...
Je suis toujours très prudent en audio. J'ai dit "sensation de dynamique supérieure", je ne sais pas si c'est meilleur ou simplement différent. Il est à rappeler que le resampler est déjà un plugin ancien, quand au filtre si c'est le passe bas à 20khz rien à péter, j'ai pas de tweeter.
Patrick
- Lansing
Dit moi tantrum , les screens de reclock sont issu de ton PC ?
- AlexScan
