Telos 400 inside.Power
• Nominal power : 350 W RMS (2 - 8 Ohms), 175 W RMS (1 - 16 Ohms).
• Instantaneous power (8 Ohms) : > 400 W
• Maximum instantaneous power : 1000 W
• Maximum voltage swing : 70 V peak.
• Maximum current swing : 10 A peak.
Frequency Response
• These figures are valid for the amplifier circuit alone, loaded by 8 Ohms and working at any level between 0 and nominal power.
• +/- 0.1 dB, 0 - 300 kHz
+/- 1 dB, 0 - 800 kHz
+/- 3 dB, 0 - 2.5 MHz.
Input Sensitivity
• Nominal level : 1.45 V RMS.
• Voltage Gain : 29dB, adjustable by rear panel.
• Input impedance : 51 kOhms.
Distortion
• Figures valid for all levels from 0 to 40 V / 8 Ohms :
• Dynamic : TID < 0.01 % (- 80 dB) unweighted.
• Static : THD < 0.01 % (- 80 dB) unweighted.
Circuit Speed
• Slew rate : > 200 V/us.
• Rise time : < 300 ns.
Noise
• Signal-to noise ratio : > 110 dB (0.01 Hz - 1 Mhz).
• Weighted ASA A : > 120dBA.
Operating Temperature
• Room temperature : -30 to +40 degrees Celsius .
• Internal temperature : +45 to +65 degrees Celsius .
Power Supply
• Nominal line voltage : 117, 234 V (switchable).
• Input voltage range : +/- 10 %.
• Maximum power consumption : 1200 W.
• Power used in standby : 90 W.
• 4 toroidal transformers
• 4 separated power supplies
Grounding
• Separated ground and earth.
• Chassis connected to mains earth.
Safety Features
• AC voltage fuse : min 10 A slow-blow for 220 V / 16 A slow-blow for 110 V.
Front Panel Controls
• 1 control key (Muting/Standby and 2 sec tempo for ON/OFF).
• Red Led display for Over-heating, DC offset or HF protection and Overload.
• Green Led display for Power on, operating mode (blinking in standby).
• Yellow Led display for signal connection and digital Lock.
Rear Panel Connectors And Controls
• Power cord: universal socket 3 lugs.
• Main fuse (10A slow-blow 220V / 16 A slow-blow 110 V).
• Green-yellow AC earth binding post.
• Output speaker 2 x 5 ways post in parallel.
• Output speaker 2 x Coaxial for Goldmund Speaker wire in parallel.
• Analogue Input connector RCA.
• Input connector XLR for analogue balanced input.
• Digital Spdif input and output RCA connector.
• Switch between analog or digital input
• Switch of right or left channel selection from the Spdif input
