et en plus Hyundai répond aux emails
Réponse reçue le 20 mai :
1. The option "Front Display" in the System menu is always re-enabled after turning on the MBox.
It is our intention to have it back when turning off and on because
1) Users should be noticed M-Box is turning on, otherwise it has risk consuming the power of users for nothing
2) Users could misunderstand that M-Box is damaged if they do not see any light and VFD when it is turning on.
Therefore, it is the same in all the F/W release.
2. Your Suggestions
Thank you very much for your kind suggestions. We will study and refer them to our further F/W updates.
Les suggestions sont :
- have an option for turning off the led on the front display when the m-box is in Stand-by mode (the luminosity of this led is too strong for a sleeping room).
- timer record menu :
Improve lines readibility (the HYUNDAI logo takes too much place in the height of the display)
Display the name of the TV channel (e.g. TF1 instead of DTV1)
Display the date in format dd-MMM-yyyy when France is selected (e.g. 10-Mai-2010 instead of 2010/05/10)
Replace the duration of the record by the end time
- At startup, return to the same status as when it was turned off (e.g. display directly a TV channel instead of always displaying the Guide/Home menu).
- DTV button on the remote control should allow to directly watch a TV program without having to select the TV option in the Home menu
- DISPLAY button on the remote control should display date with format dd-MMM-yyyy when FRANCE is selected.
