Release date : 23 September 2013
Firmware version : 05-03-130923-23-POP-421-000
Known Issues
- BD switching audio track is still not stable (still working on new SDK to get it stable)
Firmware
- Added Access-Control-Allow in Davidbox-Api
- Added allow user to uninstall NMT App
- Added Prompt Online update for NMT Apps
- Added .home package support for Skinning
http://www.networkedmediatank.com/wiki/ ... home_theme - Updated Translations
Filebrowser
- Fixed unable to access MAC shared folder when only user name is required
- Fixed cannot access NMJ
- Added support to load [folder name].jpg when focus folder
- Added storage info for both local and network
- Improve fetch subtitle download ability
- Improve fetch movie info more accurate
NMJ
- Fixed unable to back to NFS/Samba file browser after perform switch-back-to-File-Browser function in NMJ
- Added support for Automatic start-NMJ when power on
- Added option to turn off tooltips and tips box at NMJ setting
- Added option to customize default media view when access video, music and photo
- Added option to disable capture last watch scene
- Added option to customize pane opacity for video info pane and episode pane
- Added option to auto launch NMJ when boot up
- Added support to fetch on line subtitle
- Added auto focus at last watch episode at episode list
- Added auto focus at last watch season at season list
- Added show video fps info, aspect ratio, external subtitle format
- Added show episode file info
- Added show song file info
- Added support to have full view of fanart by press i key or down key at video info
- Added return key function to rating box, delete box & subtitle box.
- Added return key function to open menu at wall, list and category view
- Enchance Video details
- Enchance Music details
Apps Market
- Added return key function to Keyboard.
- Added URL to error message when login failed with error code 107.
- Added show the token again when add token failed.
- Removed "your credit" from Apps Details.
- Fixed Remove single app from private apps instead of remove whole private store.
