Marque : BRYSTON
Modèle et options : 4B ST
Prix de vente : 1200€
Département où la marchandise est visible : 91 ESSONNE
Montant des frais d'expédition : A DEFINIR
État de la marchandise : TRES BON ETAT
Première main : NON
Facture disponible : NON
Date, pays et lieu d'achat : ALLEMAGNE 2015
Garantie et date d'expiration : OUI NOV 2017
Description:
Solid-state stereo power amplifier.
Output power: 250W continuous into 8 ohms (24dBW),
400Wpc rms continuous into 4 ohms (23dBW);
800W continuous into 8 ohms in bridged mode (29dBW).
Current delivery: 16A continuous, 48A peak, per channel.
Frequency response: 1Hz–100kHz, ±3dB for 1W output.
S/N Ratio: hum and noise, 108dB below rated output, 90dB IHF.
Input sensitivity: 1.4V for 250Wpc into 8 ohms.
Voltage gain: 30dB. THD+noise: 20Hz–20kHz, 0.01%.
IM distortion (60Hz+7kHz, 4:1, SMPTE method): less than 0.01% at rated power.
Damping factor: greater than 500 at 20Hz, at 8 ohms (equivalent to an output impedance of less than 0.016 ohms).
Input impedance: 50k ohms unbalanced, 30k ohms balanced.
Polarity: non-inverting.
Dimensions: 16 3/16" (411mm) W by 7 1/8" (181mm) H by 13½" (343mm) D. Weight: 40.1 lbs (20.2kg) net.
Site web du constructeur : http://www.bryston.com/
Je me sépare de cet excellent 4B pour simplifier mon installation.
Liens divers : BRYSTON 4B ST
