Hello Johnny,
I have been looking at their web and cannot figure out which RC code they are using.
On my side I implemented in the UGS the RC5, NEC and SIRC codes that are supported in the latest binary v2.4 soon published (current v2.3 support only RC5).
As I understand most of the remotes uses NEC or RC5 so there is a great chance to support the remotes that you plan to buy.
Programming is very easy, I implemented a code learning procedure in the firmware (setup menu)
Modérateurs: Modération Forum Installations, Modération Forum DIY, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: franck660, lionel83 et 36 invités
UGS - Muse edition
- Alex_twn
- Inscription Forum: 10 Nov 2008 6:02
Hi Alex ,
I have sendt Bent Audio an e-mail, and asked them to specify which code they are using.
Sorry for all my stupid questions/postings, but it seems to me that most of you guys have already buildt the first edition of this pre-amp,
and therefore have some experience with this pre-amp . I have NOT
More stupid questions to come !
Kind Regards
Johnny
Kind Regards
Johnny
- Ine
- Inscription Forum: 02 Fév 2016 10:53
Remote control
Hi Alex
Which remote are you using ? Brand and type ? If I get a brand and type, I can program my Logitech programmable remote to test, and see if it works. Tried with a Philips remote for a Tv-set with no luck. Philips use RC5 codec ??
Kind Regards
Johnny
Kind Regards
Johnny
- Ine
Hello Johnny,
I use several remotes to validate the soft.
The one I am using for RC5 code (current UGS firmware) is a Philips SRP5004 but it won't help you as it is a programmable one as well. I am programming it with the Philips 2195 code and it generates RC5 frames.
I cannot guarantee that Philips is using always RC5 protocol (your Philips TV remote set).
To see if the commands are detected, rather than trying to control the UGS, you should enter the menu and go into the learning mode (RC settings) and see if when you press a button, the command is detected (will be displayed on the screen).
If not it means that the code is not RC5, if yes then you can reprogram each key and it will work.
PS: I think moderators are not too much in favor of writing in English on the forum, I have no problem on my side to answer but we should follow the rules.
Could you post next time your questions on DIY audio UGS Muse topic? I am also answering there
Thanks.
Thanks.
- Alex_twn
A tous,
N'ayant définitivement pas le temps de me lancer dans un tel projet, je vais me séparer de mon kit de cartes UGS Muse. Dommage mais d'autres projets rendent impossible le travail, mais je continue à suivre !
Il s'agit du kit 1, "la totale", que je livre en entier :
- cartes UGS
- cartes mères UGS Muse
- carte contrôleur front panel
- carte alim externe
- carte alim interne contrôleur
- cartes triggers
- carte subwoofer
+ les 2 circuits Muse
Je fais d'abord la proposition ici pour donner une priorité à ceux qui suivent le topic. Ensuite je mettrai en vente sur les PA DIY. J'espère qu'il n'y a pas de problème chers modérateurs, sinon dites-le moi et je fais le nécessaire tout de suite.
- cartes UGS
- cartes triggers
- carte subwoofer
- cyberced
- Inscription Forum: 28 Sep 2001 2:00
Je viens de programmer mon STM et ça marche !! (afficheur Noritate)
J'avais des doutes parce que je l'ai un peu chauffé le bougre et c'était la première foi que je soudais une puce CMS !
Alors une première remarque : j'ai un afficheur VFD et le régulateur 6V (boitier to220) malgré son dissipateur chauffe pas mal !
Il faudra que je redimensionne ça ...
J'ai un soucis avec l'encodeur optique ; le switch fonctionne mais pas la montée et descente de volume
J'ai cherché un peu , mais j'ai rien remarqué d'anormal
Par contre pour des questions de disponibilité j'ai pris un encodeur (de la bom) à 32 pas au lieu 64
Le problème viendrait il de là ?
FRED
FRED
- FRED HF
- Inscription Forum: 23 Nov 2002 14:29
cyberced a écrit:A tous,
- cartes UGS
- cartes triggers
- carte subwoofer
Tu n'auras pas grand mal a le vendre, j'ai reçu pas mal de demandes en MP après la CG. Je dois pouvoir d'ailleurs te retrouver des contacts si tu veux.
- Alex_twn
FRED HF a écrit:Bonjour
FRED
Top . Je n'avais jamais essaye avec un Noritake donc heureux de voir que tout fonctionne bien.
Le VFD consomme beaucoup donc la dissipation est bien plus élevée qu'avec les OLEDs. Quelle est ta tension d'entree sur le régulateur 6V?
Pour l'encodeur bizarre... Le pb doit être hardware de ton cote. Tu as bien l'alimentation 5V? Le fait qu'il soit 32 pas ne change rien car je decode un pas.
Par contre je vois que tu as fait varier le volume par défaut a l'affichage, tu as utilisé la télécommande?
- Alex_twn
Salut Alex
Oui , j'ai une télécommande Sélectronic (de mon actuel UGS simple) au code RC5
Elle permet le M/A , la sélection des entrées , la sélection des sorties avec la touche "monitor",
le mute et enfin , le réglage du volume .
Par contre, une fois dans le menu de configuration ,elle ne permet pas de modifier les paramètres !
- FRED HF
Salut Fred,
Oui la configuration se fait uniquement avec l'encodeur.
Pour ton encodeur vérifie les connexions. As tu une reference a me donner pour que je contrôle la datasheet?
- Alex_twn
La référence de l'encodeur : Bourns EM14R0D-R20-L032S
J'ai utilisé la nappe du fabricant pour le relier à la carte de contrôle et les connexions sont OK
Demain je démonte un peu plus et je vérifie les soudures et les pistes
- FRED HF
Alex_twn a écrit:cyberced a écrit:A tous,
- cartes UGS
- cartes triggers
- carte subwoofer
Salut Alex,
Je veux bien des contacts, merci, pour qu'un UGS Muse de plus se fasse.
- cyberced
Bon , Alex , j'ai trouvé !
Je suis désolé , c'est moi qui ai fait une ... , je ne sais pas pourquoi , je n'avais pas soudé R36 et R37
alors évidemment , ça ne pouvais pas fonctionner !
merci encore
Il me restera maintenant à installer les modules UGS (qui tournent dans mon UGS simple) et tester tout ça !
FRED
merci encore
FRED
- FRED HF
Salut Fred,
Oui sans les R ça fonctionne difficilement .
Ton UGS muse est en 16V? Il te faudra dans ce cas revoir la polarisation mais essayer comme cela ne craint rien.
- Alex_twn
Salut Alex,
Ok je t'envoie un MP
- Alex_twn
