Rudy A-Traxx a écrit:Thanks for your inquiry. Unfortunately we haven't been able to update the homepage yet, because the large demand for the Light-Manager Air. But the content will be updated within this week.
The Light-Manager Pro does not have RF receivers, so it is impossible to connect an RF wall switch to it. However, you can connect the RF wall switch as another transmitter to the actuators of your choice. Each actuator can be connected to up to 6 transmitters. However, you are probably looking for a more advanced setup and want to trigger real light scenes.
This is possible with the Light-Manager Air. It has both 433 and 868 MHz transceivers, so it can receive and transmit RF signals. The reception feature has not been integrated yet, but will be in the next few days. Then you can learn signals from RF remote controls as well as all kind of other RF signals (e.g. air condition) and trigger light scenes with it or transmit these signals again. Also the Light-Manager Air supports learning and sending of IR signals.
It might be important to mention that the transmission power of the Air is at least twice as much as it was for the Pro and the Mini. This is true for RF as well as IR signals. In other words it sends very powerful signals, which results in a much larger range.
Best regards,
Your JBMedia Team
Merci pour votre requête. Malheureusement nous n'avons pas été en mesure de mettre à jour la page d'accueil à ce jour, suite à une forte demande pour le
Light-Manager Air Mais le contenu sera mis à jour dans la semaine.
Le Light-Manager Pro n'a pas de récepteurs RF, donc il est impossible d'y connecter un interrupteur mural RF. Cependant, vous pouvez connecter l'interrupteur mural RF comme un autre émetteur pour les actionneurs de votre choix. Chaque actionneur peut être connecté à un maximum de six émetteurs. Or, vous êtes probablement à la recherche d'une configuration plus avancée et vous voulez déclencher de vrais scénarios de lumières.
C'est possible avec l'Air Light-Manager. Il possède à la fois des émetteurs-récepteurs 433 et 868 MHz, de sorte qu'il peut recevoir et transmettre des signaux RF. La fonction de réception n'a pas encore été intégrée, mais ce sera chose faite dans les prochains jours. Ensuite, vous pourrez apprendre des signaux depuis des télécommandes RF ainsi que toutes sortes d'autres signaux RF (par exemple de climatisation) et déclencher des scènes d'éclairage avec elle ou de transmettre à nouveau ces signaux. Aussi le Light-Manager Air favorise l'apprentissage et l'envoi de signaux IR.
Il pourrait être important de mentionner que la puissance d'émission de l'air est au moins deux fois plus que celle des Pro et Mini. Cela est vrai pour le RF ainsi que des signaux infrarouges. En d'autres termes, il envoie des signaux très puissants, qui se traduit par une gamme beaucoup plus vaste.
Cordialement,
Votre équipe JBMedia
Je suis allé ce week-end sur leur site,
une nouvelle version - en fait un nouveau logiciel de gestion du
Light-Manager Air - est en ligne (en revanche en bêta).
Le FS-20 est bogué (d'où la bêta je suppose - je vais remonter l'info) car le LM n'active plus mes lumières FS20 ; en revanche, il fonctionne sur les Chacon.
Comme ils sont un peu avares de notices et d'information sur les développements, j'ai vu qu'on pouvait enfin déclarer des telco RF ou des interrupteurs muraux - ce que j'ai fait - mais je n'ai pas trouvé comment leur associer un scénario (probablement en cours de developpement aussi).
Mais ça semble aller sur la bonne voie.
P.S. : : j'ai l'impression même qu'il est prévu qu'il envoie un mail selon certaines actions (différence de température ? scénario particluier ? capteur de présence activé ?)
et pourquoi pas - si la température augmente, prévenir d'un d'incendie en cours)
A ce propos savez-vous si des Détecteurs de fumée sont compatibles avec ce LightManager ou si l'on doit passer impérativement par une box domotique différente ?
