Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 21 invités
achat groupé pour un vrai son cinema
Message » 12 Mai 2002 2:07
j'aimerai savoir si cela pouvait interresser du monde un achat groupé sur du materiel jbl pro
du type
3637 Screen Channel System
Frequency Range: 40 Hz to 20 kHz (-10 dB)
Frequency Response: 45 Hz to 12 kHz (+/- 3 dB)
Power Capacity
(Continuous Pink Noise): 250 Watts
Sensitivity: 99 dB (1W, 1m)
Nominal Impedance: 8 Ohms
Crossover Frequency: 1.2 kHz
Nominal Coverage: 90° Horizontal, 40°Vertical
Half-Space Reference Efficiency: 3.2%
Maximum Acoustic Power Output: 7 Acoustic Watts (Sine Wave Input)
System Polarity: Positive Voltage to RED produces forward cone motion
Input Connectors: Barrier Strip Screw Terminals
Dimensions (HxWxD): 765 x 651 x 292 mm (30.125 x 25.625 x 11.5 in)
Net Weight: 39 kg (85 lbs)
3310 Surround Speaker
Frequency Response: 100 Hz to 12 kHz (+/- 3 dB)
Power Capacity
(Continuous Pink Noise): 75 Watts
Sensitivity: 89 dB (1W, 1m)
Crossover Frequency: 2.5 kHz
Nominal Coverage: 100° Horizontal, 100°Vertical
Dimensions (HxWxD): 446 x 483 x 267 mm (17.5 x 19 x 10.5 in)
Net Weight: 13 kg (29 lbs)
3635 Subwoofer
[/img]http://www.jblpro.com/images/cinema/3635.jpg[/img]
Frequency Range: 28 Hz to 500 Hz (-10 dB)
Frequency Response: 38 Hz to 100 Hz (+/- 3 dB)
Power Capacity (Continuous Pink Noise): 300 Watts
Sensitivity: 100 dB (1W, 1m)
Recommended Crossover Frequency: 100 kHz
Half-Space Reference Efficiency: 5%
Maximum Acoustic Power Output: 15 W IEC Standard (Sine Wave Input)
Dimensions (HxWxD): 1168 x 651 x 368 mm (46 x 25.625 x 14.5 in)
Net Weight: 51 kg (113 lbs)
8330A
Three-Way Cinema
Surround System
Low Frequency Driver: 203 mm (8 in)
High Frequency Driver: Mid: 130 mm (5 in)
High: 25 mm (1 in)
High Frequency Horn: N/A
Frequency Range: 40 Hz - 20 kHz (-10 dB)
Power Capacity (Continuous Pink Noise): 100 Watts
Power Capacity (Continuous Program): 200 Watts
Sensitivity: 91 dB SPL (1W, 1m, 3.3ft.)
Crossover Frequencies: 650 Hz, 3.1 kHz
Horizontal Beamwidth: 110° Nominal
Dimensions (HxWxD): 457 x 457 x 260 mm (18 x 18 x 10.25 in)
Net Weight: 8.6 kg (19 lb)
et aussi les amplis.
pour l'instant j'ai trouvé un fournisseur je suis dans l'attente de ses tarifs.
si vous etes interessés, merci de me le faire savoir des maintenant afin de pouvoir negocier un prix de groupe.
merci j'attends vos reponses
j'aimerai quelles soit du type (afin d'y voir plus clair)
oui je suis interessé
marque/model
e-mail
si vous avez des questions merci de me les poser uniquement sur mon e-mail stefx@wanadoo.fr
ne me demandez pas si j'ai deja entendu le son de ces enceintes, cela voudrait dire que vous etes jamais allé au cinema, puisque jbl equipe de nombreux cinemas
a+
stefx
Inscription Forum: 22 Avr 2002 20:27
Message » 12 Mai 2002 10:20
je suis trés interessé egalement par le matos JBL PRO :
il me faudrait la config suivante : 2 x 8330A , 1 x 4645C , pour les frontales a voir...
marc_ll
Inscription Forum: 19 Aoû 2001 2:00
Retourner vers Divers
