@spiderTT
i will forward your message and see...
too bad you had problems...honestly who needs poster wall 2/3 if you can have KODI ??? it plays every single format and audio! poster wall sucks ! just use player 6.7 included...forget the old desktop v3.8 or v3.9
the ATV FW is still there for older versions; i think he pulled the 2020 version simply because he is working on a the new version that comes out in a few days...
read here to see his answer http://en.egreatworld.com/comunity/inde ... 380/page-3
Désole pour cette publication en anglais les amis;
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: albator91, arsinoes00, bab1c, banjo65, Bello78, bjl36, cioran, coucouse, delennsheridan, dombell, Edis, guillaumodore, minifrix, misichavichus, nico034, Patbon21500, pem, Pilou57, shenos, Solitaire555, yoann2004, Yvounet, Zell555 et 207 invités
Egreat A5/A10 (Control4/HDR/ISO 3D/BD menu)
- nenito2k
- Inscription Forum: 20 Déc 2008 22:59
@nenito2k, thanks bro for posting my problem.
I have just read E_CS answer and it has nothing to do with my problem.
As for egreat forum NEW REGISTRATION is closed I have tried many times but in vain.
As for my problem I'm not interested in KODI and I always prefer POSTER WALL 2.
Again my problem is that after applying the patch to get egreat desktop 3.8.4, the box reboots then an application called CLEANER pops up and it PREVENTS any access tom the MENUS so I can't perform any kind of FACTORY RESET.
I have tried all the buttons in the remote to EXIT this app and I tried to unplug it from the power source but this app always pops up and prevents any access to the menu.
Regards
Regards
- SpiderTT
- Inscription Forum: 18 Avr 2020 19:21
try this :
- apply new V 3.0 FW once in main egreat menu...reboot; all apps will be installed (as for me i had to do this!)
- once in main menu again, uninstall the app that creates problems or disable it !
- apply egreat desktop patch
this MIGHT work
this MIGHT work
- nenito2k
Nenito2K :
Il va falloir que tu traduises un peu et que tu expliques aux newbee comme moi comment mettre à jour l'EGREAT A5 avec la derrniére version du firmware qui va bien car j'avoue me tater depuis un moment pour aller chez ZIDOO ...
- pascal20vt
- Inscription Forum: 30 Sep 2009 0:12
@pascal
En fait il n'y a rien de sorcier :
1- si tu es sur android 5: tu installes ce nouveau CFW android 7 3.0 via la procedure d'urgence (en gros au demarrage du egreat - voir leur forum)
2- si tu es sur android 7 beta : tu installes ce nouveau CFW via le menu egreat
si ensuite tu veux faire le hack KODI+lecteur egreat, consulte le forum ou reviens ici une fois sur le bon FW deja
NB: meme si maintenant le Egreat est enfin finalisé (ouf!!!) il reste en dessous des nouveau zidoo...mais contrairement a ce que @roucasse dit; j'ai causé a d'autres possesseurs qui ont les deux...et la qualité d'image est juste legerement mieux; pour l'audio c'est kifkif
le zidoo reste devant car le software est mieux, et le wifi aussi et surtout DV & HDR10+
- nenito2k
nenito2k a écrit:@pascal
1- si tu es sur android 5: tu installe ce nouveau CFW android 7 3.0 via la procedure d'urgence (en gros au demarrage du egreat - voir leur forum)
Effectivement j'ai les deux mais la mise à jour pour le A5 JE PASSE , pour les films pour ma fille c'est bien comme ça .Et oui l'image pour moi est meilleur sur le Zidoo Z9X et je dirais même que le Poster et top le lecteur également pour l'audio je passe par l'ampli avec une installation 5.1.2 atmos comme tu dis kifkif mais avec plus de détailles .
- roucasse (rie)
- Inscription Forum: 14 Oct 2005 17:39
@roucasse :
franchement je ne comprends pas ton raisonnement...en quoi une MAJ te pousses a PASSER ?! elle marche sans souci ! ne pas la faire franchement....enfin comme tu veux tant que tu es heureux
- nenito2k
nenito2k a écrit:@roucasse :
Bon tu m'as convaincu je vais la faire et je te tiens au courant et je pourrais faire des testes avec le ZIdoo Z9X .
Je sais plus tu as mis le lien ou pas ??? Pour la mise à jour .
- roucasse (rie)
haha cool
non j'ai pas mis de lien moi meme; mais il est ici https://www.mediafire.com/?df6zpori2fxu6
et...le zidoo restera superieur
- nenito2k
nenito2k a écrit:haha cool
Okay merci
- roucasse (rie)
roucasse (rie) a écrit:nenito2k a écrit:haha cool
Okay merci
bon j'ai fait un bug ça marche pas la mise à jour sur clé usb faut il mettre un ancien FW ??? Je viens de faire une mise à jour sur un autre appareil qui c'est bien passé mais la je
- roucasse (rie)
Aucun bug coco..jespere que tu sais que la maj depuis android 5 et 7 c'est pas la même procédure...et 2) que egreat est capricieux pour le choix des clés usb...
- nenito2k
[quote="nenito2k"]Aucun bug coco..jespere que tu sais que la maj depuis android 5 et 7 c'est pas la même procédure...et 2) que egreat est capricieux pour le choix des clés usb...[/quote
Ben justement la ça marche avec une clé de 64go je cherche même plus à comprendre .
- roucasse (rie)
sur mon Egreat A10, je n'arrive pas à installer ce nouveau firmware. Au milieu de l'installation, un message d'erreur s'affiche. J'ai essayé depuis le firmware 1510 et également depuis une version 1107 de 2017, avec la méthode du reset et également depuis l'interface. Rien n'y fait. Quelle était votre config de départ pour installer ce nouveau Firmware?
- joshua
- Inscription Forum: 09 Mar 2002 2:00
@nenito2k
do you have any link to download POSTER WALL 2 apk only, not the whole launcher?
i searched inside all update.zip files but couldn't find.
- SpiderTT
